Old 04-17-2026, 08:42 AM
Mike S's Avatar
Mike S Mike S is offline
Cleaned them as I do an engine, washed them out with hose. Then brake clean and air. Coated the stems with oil when I put them together, Guess something could have got in one but 4 and only exhaust.
I will keep the timing in mind. figured 32 would be a good safe starting point.
Old 04-17-2026, 10:51 AM
Jack Ferris's Avatar
Jack Ferris Jack Ferris is offline
This happened to a friends E heads. But, it was years after the heads were built. The reason, we believe is it was run very lean due to a failing and not caught in time fuel pump and failing to re-jet for lower altitude.
Jack Ferris
RestoRacing LLC
www.restoracing.com
Sandy, UT
Old 04-17-2026, 12:16 PM
Exhaust valves have seals?
Old 04-17-2026, 10:37 PM
Mike S's Avatar
yes seals
