Oil leak found! Last bolt driver's side wicking down bolt. But the hole is in the bell housing area, must be wicking between gasket form the inside.
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
Bolt in front of it was loose . Pulled them both and no bolts and not dripping. I do not think the brace was hitting pan like the Milodon on my new 400. had to grind it in the curve.
Nice numbers Skip. I have the Stump puller going in a 400 stroked with KRE heads in the future. I'm curious on the spring pressures. You said you shimmed to get 174 on the seat. Do you have any open pressure numbers? Thanks
68 Firebird. IA2 block, 505 cu in, SD Performance E-head, Solid roller 3600 weight. Reid TH400 3:90 gear. 28" slick. Best so far 9.95@135 mph. 1.39 60 ft. 76 Trans am, TKX .81 o/d, 3.73 Moser rearend, 468 with KRE D-ports, Doug headers, 3" Exhaust 950 Quickfuel. |
I.m not sure is I have open. In fact cleaning out a drawer the other day I found my sheet of IH and seat pressures.
I did not hear any ticking but the dyno room was kind of loud.
| The Following User Says Thank You to Skip Fix For This Useful Post: | ||
Testedf or the oil pan leak after tightening bolts and some extra RTV. That is good but at the 'tilt test" looks like the rear main seal is leaking! Dead center drip .
