I was impressed when Morris took the time to cut apart the spark plug to read it and added the spacer for the next step to lean it up a little. Seems like he makes pretty logical steps in the video on the dyno pulls. I appreciate posting up the link to watch it, good stuff.
What I've seen time & time again is that aftermarket D port heads need like in the 38 degree range of timing, think that would have made a significant difference.
Since there was a dip/drop in TQ at a lower RPM with the manifolds, bet a Perf RPM intake would have taken care of that. Single planes would probable do better once you get over say 310cfm or so. As for the SD testing, it was pretty common knowledge OE exhaust systems were restrictive, especially considering the constraints of regulations at the time. One of the top day-one mods were headers & true dual exhaust. Being an F body was considered the main recipient of the SD, it was well known the exhaust was even more restrictive than most, with the bends and crossover muffler. At least that's some of my thoughts on the topic, in general. .
| The Following User Says Thank You to HWYSTR455 For This Useful Post: | ||
What you expect. Morris a top pro expert 1000 hp builds.
Same disappoint nicks garage same thing Mopar 30 yrs Both where mild builds. Least both spent whole day testing and tuning most othrr shops wouldn't. .
Ya its for show but ..
Id love see Butler or Kuffman do dyno tests m
From Pontiac.
Stan
| The Following 4 Users Say Thank You to Stan Weiss For This Useful Post: | ||
I have long tube Hookers on my 470 in my 2nd gen. They ARE a pain for sure. Down tubes are wrapped, Wrap never stays on collectors tho. Dual 3" all way to splitters. I wanted some RARE manifolds. But cost for me, being on Canada, couldn't justify it
I've run headers 3 times, manifolds twice. On my current engine done by SD Performance at approx 462" 570 HP, Dave said headers were worth 30-50 HP. Noticeable difference in the car, slower revs and different sound with 2.5" manifolds to a 2.5" stainless exhaust system. Back to Doug's headers again.
| The Following User Says Thank You to 73ta For This Useful Post: | ||
I'd like to see back to back timeslips, I've never pulled into the beams and seen a dyno in the other lane.
| The Following User Says Thank You to SRGN For This Useful Post: | ||
I had hooker 1 5/8 4 tubes on my stock 70 RAIII bird and raced it for a while that way. Went back to the RA exhaust manifolds years ago and have raced it extensively that way. Never changed the exhaust system just added the mandrel bent down pipes
The car never ran a tenth or two either way depending on the DA. So it was a wash for me but we're talking about a car that's completely stock, only 400 cubes, and only runs bottom 13's with a best corrected 12.76. maybe a bigger engine with more HP might see a different outcome but that's not what determines the choice for me. It all depends on what the goals are for the car. |
| The Following User Says Thank You to Formulajones For This Useful Post: | ||
Finally had a chance to watch the video. Attention needs to be paid to the exhaust ports if one wants to make big power with a d-port head. This isn't breaking news it's always been that way. Pontiac figured it out in the mid 60's.
Curious what folks opinions are with a trade trading power for conviencece when deciding between headers and manifolds? With tuned collectors the headers would've been good for about twenty horsepower and two tenths at the track. |
| The Following 2 Users Say Thank You to PAUL K For This Useful Post: | ||
I agree, there was 20 HP improvement left on that engine with header tuning, on a really hot day I would expect the RA manifolds to loose even more power versus Morris’s climate controlled shop, and the octane required might start to climb on the manifold combo to. At 3700 RPM the RA manifold combo made 417 HP and 590 TQ, and the headers was 442HP and 628 TQ. That is a 25HP/38TQ difference, and probably gets worse when the pull starts earlier yet. It is also where a street engine spends most of its life. It must have had lot of a lot of intake reversion to create that much difference at 3700 RPM, probably needed a RPM intake for the RA manifolds?? If that engine was brought to our shop to install the engine you would have to tie me to a chair to let someone put exhaust manifolds on it. LOL Last edited by Jay S; 05-25-2026 at 10:23 AM. |
| The Following User Says Thank You to Jay S For This Useful Post: | ||
If it's a cruiser, or more of a restoration, or some sort of sneaky build made to look stock, it'll have the manifolds on it. So it's really a pretty simple decision for me. |
I didn’t spend the money to port my heads to 322cfm, and upgrade the intake valves to 2.19”, to wonder how many ft/lbs of TQ I’m losing by running manifolds. No one makes them to fit my ‘65 Lamnas anyway….so it’s a moot point for me.
The 1-7/8 Dougs fit great and tuck up nicely, so there’s really no downside. When my engine was dynoed, I was more interested in how much I was leaving on the table due to intake choice….hood clearance, single vs dual plane, etc. So we dynoed 4 intakes and found out. This summer, I hope to correlate the engine dyno results to the 1320 dyno….gonna have an intake shootout day. |
| The Following 2 Users Say Thank You to 65 Lamnas For This Useful Post: | ||
The lower torque down low with manifolds doesn't surprise me. That's pretty typical of every engine going from short tube to long tube headers.
Short tube headers tend to do ok for higher rpm power and lack a bit in low rpm torque production. Long tubes favor low rpm torque production. Every engine Ive ever seen on the dyno shows a similar result. So what you saw on Steve's video with low rpm torque differences is pretty normal. |
For me it's a decision between extracting every hp possible or sacrificing some hp for the stock look of RA manifolds. I have about a 415 hp 455 in my '72 LeMans right now with RA manifolds and will start on a 600 hp 494 ci motor soon to replace it. I'm struggling with should I use RP RA manifolds or headers? I have both, but I don't really want to move my brake lines and metering block that's on the frame in the way for headers. It's a 50/50 right now, but I'll probably end up with RA manifolds (2.5") since I'll never race the car.
1967 Firechicken, 499", Edl heads, 262/[email protected]" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. [email protected] mph with a 1.45 60'. Still WAY under the rollbar rule. |
| The Following 3 Users Say Thank You to AG For This Useful Post: | ||
That engine Morris had on the dyno loosing about 40 lbs of torque at 3700 was showing a bad mix of parts someplace with the RA manifolds, the headers solved it. Which would be easy to overcome, but running that engine as it is with the RA manifolds would not have been very ideal at all. |
I agree, 600 hp with headers and I know I'll be killing hp with the RA manifolds. That's why I am struggling with the decision. I'll either use a TII or an RPM intake and dyno the motor with headers first and then with manifolds and then make my decision.
| The Following User Says Thank You to AG For This Useful Post: | ||
