Old 06-29-2026, 02:20 PM
steve25 steve25 is offline
With the average owner built street motor of whatever cid that has less then 10 to 1 with aftermarket heads that are not being fully utilized flow wise by the cam being run you can count on needed 4.2 to 4.4 intake cfm @ 28” to make 1 HP per cylinder.
Old 06-30-2026, 09:26 AM
i82much's Avatar
i82much i82much is offline
Ah, thanks for the info all. Got my shop back after a divorce, found my old T2 intake and got all excited for a minute. Then reality set in, I'm not gonna mess with the car. Gonna take the kids camping this weekend and fix sprinklers. That's life I guess!
Old 07-08-2026, 05:51 PM
74Grandville 74Grandville is offline
That large of an engine is begging for an open plane intake. no need for extra low end. torker 2 is a great intake.
1979 Firebird Trans Am 301/4spd (Now 428)
1977 Firebird Formula 400/Auto
2007 Grand Prix GXP 5.3L
Old 07-08-2026, 07:00 PM
jonmachota78's Avatar
jonmachota78 jonmachota78 is offline
My setup with OF 1.0 460cid and kre 310 D ports did not pick up with a cnc 3xtrude honed t2 by bishop. Barely seales with 2mm of meat on one runner. Basically i couldnt tell the difference. If i were you with a 502 id try a road paver and a ported t2 after you verify the head flow is there
'78 Macho T/A DKM#95, 460cid, SRP pistons, KRE 310 D ports,
3" pypes, Hooker 1 3/4" headers, hydraulic roller,
10" Continental, 3.42 gears
11.5 @117.5mph 3900lbs
([_|_] ##\|/##[_|_])
Old 07-08-2026, 11:31 PM
RocktimusPryme's Avatar
Other than having one on hand and saving money, is there a reason to use a T2 compared to one of the newer model single plane intakes? At least when talking about 455+ ci engines.
I know there isnt much data yet on the new Victor JR yet, but I think I would be thinking one of those with a tapered spacer would be the ticket for a street oriented engine with the cubic inches to still make low end power with a single plane.
Old 07-09-2026, 01:38 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
I think a single plane would probably pick it up. A T2 might be pushing it on a 505 but even my mild Stump Puller 455 using one I ported the heck out of and added weld made well over 500 hp! Heck my 470" 409 made 604hp with a dual plane dual quad! I think a SD modified Holley will do about the same.
I think hood clearance/height is the issue with others like the Victor. Even on my 500 in the Camaro with a cowl hood can not fit a spacer and an aircleaner, but it likes a 1" taper on top of a 1" open. A Northwind is lower and I bet why Edelbrock made the lower Victor Jr!
Skip Fix
Old 07-09-2026, 07:10 PM
Steve C. Steve C. is offline
Probably repeating myself, but no lack of torque on the street here with a single-plane intake...
On my 505 I dyno tested with a Victor intake that had the carb flange milled down 0.650" to help with clearance under the hood.
On the dyno with no carb spacer it made 599.9 ft. lbs torque at 4100 rpm (start of the dyno pull ).
No dyno pulls at a lower rpm, but off idle response was no issue in the car !
At 4900 rpm (peak tq) it had 639.0 ft. lbs torque and at 5700 rpm it was making 600.3 ft. lbs torque.
At 6000 peak power rpm it still made 577 ft.lbs. torque.
Old style Edelbrock heads / about 320 cfm @ .700"
10:00:1 compression
UltraDyne MSP solid roller- 255/261 @.050"
110 LSA
Old information here:
The Following User Says Thank You to Steve C. For This Useful Post:
Old 07-09-2026, 07:33 PM
For interest, and info for those interested...
Dyno tested combination:
4.250" stroke / 4.180" bore
KRE 300/305 cfm d-port heads
10.5:1 compression
SD Performance Road Paver Cam ( 246/252 @ .050" )
Using solid roller lifters and 1.52 rocker arms.
Torker II intake, cnc port match / HP950 carb / 1" super sucker spacer
3500-3600 rpm 531 ft.lbs tq (start of dyno pull )
Peak torque at 4600/4700 rpm ( 593 to 600 ft.lbs tq )
Peak power at 5800 rpm ( 588 hp )
Something to consider...
It has been touted mechanical cams usually need about 8-10 degrees more duration to have a comparable power band to a hydraulic lifter cam in the same engine.
Old 07-10-2026, 09:04 AM
Tandyman Tandyman is offline
There were interesting intake test results in this article:
https://www.hotrod.com/how-to/ccrp-1...l-alloy-indian
Glenn
Old 07-10-2026, 10:35 AM
And notice the welded Torker II intake for that build.....
https://hips.hearstapps.com/mtg-prod...75&format=webp
This because the SD Performance heads with tall intake ports.
XE hyd roller
Intake lobe 3318 / 245 @.050
Exhaust 3319 / [email protected]
LSA 112
1.65 rocker rat
