Old 08-02-2012, 11:43 AM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
Originally Posted by mechanickeith View Post
WOW!!! Are you kidding me!!!! Were the rocker studs loose?? Is that a crack just to the right of the weld?
The rocker studs were tight, however the first few threads on some of the rocker stud holes seem a bit sloppy and will need to be checked once the engine is back from the chassis shop. Yes, that is a crack in the guide-plate.
  #382
Old 08-02-2012, 11:50 AM
RAIV-Z's Avatar
Originally Posted by BruceWilkie View Post
Aluminum in the guide plate stud hole shouldnt be there... does look like a crack next to the weld but could be only a scratch, the pics arent 3D...but it does look cracked.
WTH... did they hire a guy that was down the road with a sign will "work for food"?
Hi Bruce,
The gray stuff in the left hole is "Valco Products OEM silicone" gasket sealer.
  #383
Old 08-02-2012, 11:58 AM
cgeise's Avatar
cgeise cgeise is offline
Just makes you want to send in a bunch of money for that new 600 plus cid engine huh - -
  #384
Old 08-02-2012, 12:28 PM
GTO Dan's Avatar
GTO Dan GTO Dan is offline
There are generally three sides to every story...with that said...I don't understand the double standard around here.
If your issues were with "certain" product manufactures or builders then the posts, support and indignation would be never ending, yet in this case...crickets from most who live to opine on this stuff.
If you are an active member on YB, post it up on TOBT. The have a unique way of getting to the truth and help with resolution in many instances.
Good luck on sorting through this.
  #385
Old 08-02-2012, 01:30 PM
67'7F6'Bird's Avatar
No ones opinion matters at this point, Resolution has been turned down on many occasions by Lynn Mccarty.
RAIV-Z purchased complete engine through McCarty Racing who Sourced the Build and Assembly through BES. Said engine received is a bunch of crap put together as ALL the pictures show. Said supplied parts changing throughout the build, Cam Specs changed multiple times. No Customer Support after the Sale, No Opinions just facts.
Why doesn't Lynn just step up and Fix this engine?
  #386
Old 08-05-2012, 10:05 PM
RAIV-Z's Avatar
Can anyone guess who didn't show up at Norwalk this year?
  #387
Old 08-06-2012, 12:25 AM
jdw_poncho's Avatar
jdw_poncho jdw_poncho is offline
I didnt have time... oh wait a minute, you probably was talking about someone else?
Did you get my text?
  #388
Old 08-06-2012, 12:31 AM
RAIV-Z's Avatar
I got it, I'll give you a call later today.
  #389
Old 08-06-2012, 10:20 PM
RAIV-Z's Avatar
1 replacement header flange showed up in the mail today, sent by the shop that Lynn contracted to build the 321 stainless turbo headers.
  #390
Old 08-06-2012, 10:42 PM
mechanickeith's Avatar
Were you expecting it??
Keith Collier
61-63 Pontiac Tempest
Tech advisor
POCI.org
  #391
Old 08-07-2012, 08:46 PM
RAIV-Z's Avatar
I've been waiting for it since the engine was delivered in March.
  #392
Old 08-08-2012, 08:16 PM
RAIV-Z's Avatar
Default Drivers Side Header Doesn't Fit
Here is why I needed another header flange....
Before the header build started, IndyCartel the fabricator Lynn selected was specifically told I’ll be using tall billet valve covers and to make sure there was plenty of room to get a box wrench on all the headers bolts.
  #393
Old 08-08-2012, 09:07 PM
I might try a bit of modification first. On valve cover clearance,,what if you took a cut off wheel & sliced through about 3/4 of the tubes coming up from the bottom, then bend the collector out & away from the valve cover & weld back up. Dont know if that sounds right. The bolt issue can get a little dimple to make the wrench fit. Just the thickness of a cut off wheel will make a big difference up top.
Keith Collier
Tech advisor
POCI.org
  #394
Old 08-08-2012, 09:19 PM
Scott Roberts Scott Roberts is offline
So has anyone threatoned to sue you over posting your findings and your concern for safety? Just curious?
  #395
Old 08-08-2012, 10:13 PM
RAIV-Z's Avatar
The 321 stainless headers weren’t cheap, they should have fit without any major modifications. You can't install all the header bolts. If you install all the top row header bolts, the bottom ones don't line up, the holes will need to be enlarged. Could be because either the head or header flange bolt holes were not located accurately. Both will need to be measured in order to determine which is incorrect.
Cutting and tipping them back will cause clearance issues with the suspension. Below is the spacing required to allow the header to fit with minor valve cover contact.
  #396
Old 08-09-2012, 12:41 AM
R 70 Judge's Avatar
What about some stainless header studs?
To be honest, if they don't fit, they should fix them. Being stuck with fancy looking sh*t that don't work isn't cool.
James
1970 Trans Am
  #397
Old 08-09-2012, 12:46 AM
R 70 Judge's Avatar
Double post
James
1970 Trans Am
  #398
Old 08-09-2012, 01:22 AM
Interesting,,, You going to double up the flange & use 2 gaskets?
Keith Collier
Tech advisor
POCI.org
  #399
Old 08-09-2012, 04:24 AM
RAIV-Z's Avatar
No, due to clearance issues the existing header will need to be cut up and modified to fit or completely replaced.
  #400
Old 08-09-2012, 04:29 AM
Never easy!! Waiting to see the modifications. Always something on a one off piece.
Keith Collier
Tech advisor
POCI.org
