I'm late to the party but what a great saga!
RediRad circuit designs, branding and intellectual property are for sale. Serious inquiries only. |
You're really doing a wonderful job with the car GW.
Greg Reid Palmetto, Georgia |
Your doing a great job & the car looks great. Keep it coming.
Looking good Greg! Can't wait to see it on the road!
1969 GTO 4spd. Antique Gold/black, gold int. 1969 GTO RAIII 4spd. Verdoro Green/black, black int. 1969 GTO 4spd. Crystal Turquoise, black int. 1970 GTO 4spd VOE Pepper Green, green int. 1967 LeMans 428 Auto. Blue, black int. |
Did you have some of the bolt re-oxided? I see what looks like fresh black and grey phosphate oxiding.
I do some bolts myself ...but not always happy with the results and not sure of the longevity ... I use the 200 degree soak in Mag Phosphate etc. method. JohnnyB |
Nice work Greg, even if you live in Sherwood.
Practicing social distancing for 65+ years |
Awesome job GW... What's the deal on the brake lines at the MC? are you going to connect at the flare nut on the end of that stub or is that just for bleeding purposes?
There will be a rear brake hold off valve under the master?
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core.
Johnny, yes refinished the bolts using a zinc phosphate method. I outlined the procedure earlier in this thread. Sounds like you do the same thing.
Greg, that damn little line won't fit it's too short. Purchased from Inline Tube years ago when I restored the frame. Going to have to call them to see what's up.
I see that Ames lists front line kits. I may try that out.
^^ Oh yeah...I shoulda known that. ^^
Nice Greg! Won't be long now!
Ya, right, been saying that to myself for some time! Well the goal is still to get er to the GTOAA nationals this coming July in Seattle.
Looking real good GW!! I'm sure you are getting anxious to see her completed. I really do like that color gold it really stands out! Your Grandmother had good taste, I'm sure she would be very proud of how you are restoring her car. When you go to Seatle I'm sure you will have no problem bringing home the concourse gold award. Post pics when you can.
Thanks. CB
1966 GTO Vert automatic. 1969 CR Judge Ram Air III 4sp Pattern Car. 1969 GTO standard 350HP TH-400. 2006 GTO Phantom Black 6spd. 1972 Formula 455HO Ram Air. 1976 LE Trans Am 50th Anniversary Edition with T top. 1976 Formula 350. 1977 Grand Prix Model J 350. 1978 Trans am 400 Pontiac. 1979 Trans am 403 Olds. 1968 Olds 442. 1971 TR6. |
Inline is hit and miss in my opinion ... good selection, but much of what they describe as absolutely "correct" is barely close.
Just installed a set of their wheel cylinder to flex hose hard lines ... PITA, had to do considerable bending to get them right. Ended up removing them because they were not spring wrapped like "correct" originals. Installed some from a different company ... Right Stuff I think ...fit quite a bit better, still needed tweaking. PS. Love this thread |
The spring wrap is the only reason I was going to buy any in the first place. Otherwise, I'd just make some to replace the highly visible ones between the MC and the distribution block on the frame rail. I may do that anyway...If I could figure out a good way to simulate the wrap.
http://www.ebay.com/ulk/itm/191718147670 They sell just the spring shielding. I've used it before. Just slip it on, add your fitting and flare the end. Helps with tight bends too to keep the line from kinking. |
