Old 06-25-2016, 06:57 AM
71 T/A 71 T/A is offline
Originally Posted by ta man View Post
I've used the 2.5 inch pipe it fits well.
They say you have to use offset inlet/center outlet mufflers to make the Flowmaster tailpipes work.
  #382
Old 06-25-2016, 10:15 AM
ta man ta man is offline
I just saw that..I must have had a old set..I know they fit well..
466 Mike Voycey shortblock, 310cfm SD KRE heads, SD "OF 2.0 cam", torker 2,generic one inch open spacer
  #383
Old 06-25-2016, 01:16 PM
Pontiac Derek Pontiac Derek is offline
And By the way Ernie's motor has a max of 10.25:1 but im sure its acually 10.07:1 just needs to know how far down the pistons are in the hole!
He can see what it is whenever he freshens it up, Not bad for an engine that is not even zero decked lol!
Build it Right Build it Once!!!
Just another Engine Builder from the Northwest lol
  #384
Old 06-25-2016, 03:15 PM
It's the cold Canadian air I tell you. LOL!
  #385
Old 06-25-2016, 11:28 PM
I love running in the fall when its cold..tricky to hook up but free horsepower!
  #386
Old 06-26-2016, 11:46 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Yea in Houston that is about 1-2 weekends a year!
Skip Fix
  #387
Old 06-26-2016, 02:57 PM
ponjohn's Avatar
ponjohn ponjohn is offline
TA MAN - did you get out last night?
  #388
Old 06-26-2016, 07:00 PM
No but have done some backroad testing with the new carb body...hard to tell if there is a power increase...within a couple weeks be back at the track...
  #389
Old 06-26-2016, 07:16 PM
So TA Man, you prove that the KRE 290 heads are providing good enough performance so that you may not have much to gain if at all by getting your heads ported to 305 or so.
  #390
Old 06-27-2016, 08:16 AM
pastry_chef's Avatar
Odds are high it would run faster with a little more head.
  #391
Old 06-27-2016, 04:24 PM
I had a good discussion last time at the dragstrip about headflow...Another fellow Pontiac racer insisted more head flow is always good...I disagreed it is not always better..all depends on the combination...
  #392
Old 06-27-2016, 05:20 PM
Yep, look at original Ram Air V heads.
  #393
Old 06-27-2016, 07:12 PM
More CFM is far from always better!
Velocity is an extremely important consideration.
Agree about balancing factors in the combination.
  #394
Old 06-27-2016, 07:32 PM
ponjohn's Avatar
More cfm may not be beneficial if the cam is too small for the head flow.
  #395
Old 06-27-2016, 10:44 PM
grandville455's Avatar
grandville455 grandville455 is offline
290's is enough for 10's, i went 11.50@117 in 4550 lbs... Ernie will do it!
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,[email protected]@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected]
M/T 275/60 ET SS Drag Radial
2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's
  #396
Old 06-27-2016, 11:19 PM
slowbird's Avatar
slowbird slowbird is offline
What gear?
  #397
Old 06-28-2016, 01:11 AM
I'm going to try and do it the hard way first!In decent air it would have went 11.1's..thats getting pretty close...and I've never expected to run 121/122...just the matter of getting to the track more..the 60's will come down a bit thinking 1.60's,still not leaving as clean and hard as it can.,testing this annular main body next..I have a small list of things to do this year..hopefully everything can get tested.
  #398
Old 06-28-2016, 07:35 AM
ponjohn's Avatar
Has anyone tested this combo with a well adjusted q-jet?
If so what intake?
And, Ernie what size headers?
  #399
Old 06-28-2016, 05:46 PM
77 TRASHCAN's Avatar
If so what intake?
Andy (Torquewar) has a similar combo with a RPM and a Q-Jet. His last post here was post #195, there are several before that. All good reading!
Shut it off
Shut it off
  #400
Old 06-28-2016, 06:04 PM
Torquewar's Avatar
Torquewar Torquewar is offline
I have been running a Q Jet and a self ported RPM.
My best MPH is 122.3 with a 11:44 and spinning for 3-4 ft limited traction.
Car has always ran flawless on the street and track.
Have a T-2 and a Shaker(Jeff)) 455 4150 to bolt on very shortly.
Im also trying to get the 60ft s down but im eager to see what the intake combo will do.
