Old 11-07-2014, 10:09 PM
Held for Ransom's Avatar
Originally Posted by takid455 View Post
Anyone know of a recent 12k mile 73 SD 4 spd sale in MN or WI?
Nope, missed it. I wonder if it's green...
Old 10-13-2014, 07:25 AM
Brewster's Avatar
Brewster Brewster is offline
Cool, most of them came with a/c making this car a little more desirable.
John, the lineman used jigs as starters regarding the placement of all decals however once experienced that diminished. Bottom line anything was possible when it came to the locations of these decals as we have seen.
Old 10-13-2014, 07:53 PM
Brewster's Avatar
Looks like the auction has been cancelled
Old 10-14-2014, 08:27 AM
johnta1 johnta1 is online now
Getting a little off-topic.
Was that our Mr. Winkles getting print in the new Hot Rod mag?
(no Poncho content unfortunately )
Old 10-14-2014, 08:49 AM
superdutybob's Avatar
superdutybob superdutybob is offline
Talking
One in the same! He's famous!
Bob Woodard
Brighton, MI
2012 SRT8 Charger - 12.70 @ 111mph
Old 10-14-2014, 06:44 PM
Brewster's Avatar
Hey Bob,
Good to see your still surfing the site. Hope this finds you well! Tell Dick Hey from us poncho pals would yaah, miss those ripping good times we had cutting up at duh shows.
Cheers bro, Brew
Old 11-02-2014, 10:13 AM
The Boss's Avatar
The Boss The Boss is offline
Yes, been posted before.
And go racin' in the street.
Old 11-02-2014, 01:28 PM
Wareagle's Avatar
Wareagle Wareagle is offline
Cool - Thanks
Old 11-02-2014, 07:17 PM
SD Formula's Avatar
SD Formula SD Formula is offline
Default SD cam shaft
Here's a couple of pictures of my SD 455 cam shaft, I wrapped it up for storage and possible future use. It was included in an engine rebuild back in the 80's before I owned the car. From the numbers can you tell if it is a factory spec SD cam or something else. Just curious! Thanks 493323 CRANE BN2655 1674
Name:	1974 Super Duty Formula camshaft  #3.jpg
When removing an unreplaceable washer, the part will be heard hitting the floor and then vanish from the face of the earth!
Old 11-02-2014, 09:02 PM
493323 is the factory number for the SD cam.
I would think it is a stock replacement cam for the SD?
Maybe measure the lobes and see what the lift might possibly be?
Might be a 'high lift' type of stock cam replacement.
Old 11-07-2014, 05:33 PM
takid455 takid455 is offline
Send a message via AIM to takid455
Hell yeah steve! Thats the fellow from or works in Lebanon right? Dave is his name?
Be neat if this one coming is red. red , white, blue and green. All with original paint or whats left of it . That has to be media print worthy. I am not sure of the color. May be white. Not sure if he mentioned that.
Old 11-07-2014, 08:38 PM
njsteve's Avatar
njsteve njsteve is offline
Is it the red one with the flames that was for sale a couple months back?
Old 11-07-2014, 09:35 PM
I doubt it. Again, I dont know any more than posted at this point about the car besides selling price which I wont disclose. Hopefully old man winter holds off for a little.
Old 11-08-2014, 09:22 AM
Brewster's Avatar
No, but there is or was a white one in Minnesota that used to be in Wisconsin. The guy that has it owns just white cars. Not sure if this is the car or not???
Old 11-17-2014, 01:10 PM
mscicluna007's Avatar
mscicluna007 mscicluna007 is offline
I have posted in the wanted section but someone may be able to help. I am looking for an SD 455 Distributor date coded for a 73. Would like it to be complete.
Maybe someone here may ne able to help me.
Michael.
Old 11-17-2014, 05:35 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Default Super Duty runs 12's
I wanted to share an excellent experience I had with my SD TA. Three years ago I took the car to the track hoping to get a 13 second time slip. The car was mostly stock with the exception of 1.65 rockers, exhaust and carb/dist.tuning. I ran 13.9@100 mph and was quite happy. Then the racer in me kept thinking about a project Cars Magazine did back in '74 trying to get an SD to run 12's, and I wondered if I could accomplish this using a different approach. Since I had a spare SD block laying around, and enough parts to assemble another engine, I decided to see what could be done. I ordered a set of trick custom flat top pistons from CP, rebuilt a set of rods using ARP bolts, had the crank nitrated and the rotating assembly balanced. I just did the standard performance blueprinting prep to the block. I spent a lot of time on the flow bench testing different valves and valve seat combinations. The heads were milled .060 and an HFT cam was designed to match the flow characteristics of the heads, and hopefully accomplish my goals. I never touched the heads with a grinder, nor did I port match or modify them in any way. Other than an efficient valve job and milling, they are stock. I used a '72 455 HO intake manifold that I gasket matched, and I ported the exhaust manifolds.
I figured I would need to update the chassis a bit, so I clamped the rear springs and installed a set of performance shocks in the rear. I believe my front shocks are original. When I scaled the car, it weighed 4100 lbs without the driver. I figured I needed to remove a little weight, so in addition to the aluminum intake, I removed the spare tire and jack assembly, installed the thinner fender to core support braces and painted up a set of Rally wheels I could use at the track instead of the heavy honeycombs. The car still weighs over 4300 lbs. with the driver.
I got my chance to race the car at a local track this past May. I was very happy when I got the time slip and saw that I ran 12.7. I made four runs and didn't get a chance to try and dial-in the combination. I ran three 12.7s and a 12.8 all at 107 mph.
Super Duty 455's are the best!
I've attached two video links of my runs that day.
http://youtu.be/7SvcXv8YvEE
http://youtu.be/iT9oOBH6JRU
Go fast, see Elvis!
Old 11-17-2014, 06:00 PM
SD POWER RULES !!!
One thing that really wakes up the SD heads is a bigger cam.
Try a roller cam and it will fly!
Old 11-17-2014, 06:08 PM
PAUL K's Avatar
SD POWER RULES !!!
Yes, you are correct. I ran well into the 9's with a roller cam SD 455:
http://youtu.be/0f7edXFN2XY
Go fast, see Elvis!
Old 11-18-2014, 01:19 PM
Wareagle's Avatar
Thumbs up
Awesome - if Pontiac had the SD-455 In 1970 with high compression etc. it would have ruled
Old 11-19-2014, 12:33 PM
PAUL K's Avatar
Thank you; I agree with your comment. It kinda makes you pity the guys with Ram Air IV's
Go fast, see Elvis!
