Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 12-03-2015, 08:09 PM
potentpontiac's Avatar
potentpontiac potentpontiac is offline
Thumbs up Cam Plate worn 12 passes
Scott is making up a new torrington bearing set up for my 505. We did 5 dyno pulls and 12 actual passes on the motor. Upon tear down the cam had 12 thou movement for and aft. It was a Brand NEW tool steel cam plate with 50mm Roller cam bearings. The result was a heavily grooved cam plate. Scott is making up a set up that will be compatible with the roller bearing set up. Make sure you upgrade when using roller cam bearings. You need to get oil feed to the cam plate.
  #402
Old 01-23-2016, 07:31 PM
simsb52 simsb52 is offline
Hi All .... 2015 was crazy to say the least. Quitting my job with Cummins Inc. and pursuing my dreams has proven to be the right move. I do miss the people there at the big C but when faced with the decision of staying there or going off on my own...well...the only thing I might regret in life would have been NOT following my dreams. I haven't looked back and with no regrets.
I know that I said I would try to make some oil pump drive shafts last year but the jobs and time on the cnc okuma lathe was filled up. I haven't forgot, I have the material right here next to my desk so I wont forget. I will get to them! Promise!
The Roller cam plate business seems steady .. picking up a little for the winter builds going on. I do still make these. Making up one special for the 50mm cam that blocks off the oil on the face of the block to feed it through the roller bearings first, then to the timing chain.If you need one of these or a standard one, let me know.
thanks for all the support and patience...
Scott
Sims Performance Machining, LLC
PO Box 184
Elizabethtown, Indiana
47232
812-350-8637
Scott Sims
Sims Performance Machining LLC
P.O. Box 184
47232
phone... 812-350-8637
[email protected]
  #403
Old 02-16-2016, 08:49 PM
vidguy's Avatar
vidguy vidguy is offline
Sent you an email about a gear and plate set. Im in for another.
James
Work
'67 GTO Convertible "Koerner Built 413 500 hp with a Victor!.. I'll run a stock intake."
'75 Formula 400 - Daily Driver -
Running with my Home Built 455 and TH400
Details here:
http://forums.maxperformanceinc.com/...d.php?t=588372
  #404
Old 02-16-2016, 08:57 PM
vidguy's Avatar
Here is a great write up on this part.
http://www.hotrod.com/how-to/engine/...haft-retainer/
James
Work
Details here:
  #405
Old 03-24-2016, 04:53 PM
Hi All...I have 3 standard length timing sets and 1 - .005 under set ready to ship. Let me know....thanks...Scott
Scott Sims
P.O. Box 184
47232
[email protected]
  #406
Old 08-19-2016, 11:36 AM
JC455 JC455 is offline
Scott,
I PM'd you about a set.
Let me know,
John
John
IG: @crawdaddycustoms
YouTube: https://www.youtube.com/channel/UCK9...Nc_lk1Q/videos
  #407
Old 08-19-2016, 08:10 PM
bendutro bendutro is offline
I could use a set too please..
  #408
Old 08-19-2016, 08:13 PM
TimeWarp TimeWarp is offline
Guys...you are MUCH better calling him at the # right in his signature. He rarely gets on the forum and easily misses a notification from PY...but will always answer or get back with a phone call.
  #409
Old 08-25-2016, 01:04 PM
^^^ Cool, thanks!
John
  #410
Old 08-25-2016, 02:15 PM
rohrt rohrt is offline
How much do these run now?
  #411
Old 08-26-2016, 02:17 AM
If I recall its around $275. Best to call him and ask directly though.
  #412
Old 03-09-2017, 12:25 PM
bump
Scott Sims
P.O. Box 184
47232
[email protected]
  #413
Old 03-09-2017, 01:56 PM
leeklm's Avatar
leeklm leeklm is offline
I just installed mine last weekend. Very nice piece!
Sent from my XT1585 using Tapatalk
68 Firebird-- Street/Strip - 400/461 Eagle Forged Bottom End & Ross Flat top pistons. KRE 325 CFM D port, Ultradyne 263/271 @.050, .4267 lift. Crower Solid roller lifters and 1.65 stainless rockers. Quickfuel 1000 on Torker2 intake and 2" open spacer. Hedman 1.75" headers. TH400 w/brake. Ford 9" w/3.80 gears & 28x9 Hoosier pro bracket drag radial. Best ET: 1.35 60ft, 6.29 @ 107.20 mph, 9.99 @132.33 mph. 3,300 race weight
  #414
Old 03-09-2017, 06:27 PM
ErikW's Avatar
ErikW ErikW is offline
Me too. This will be my third from Scott. Excellent component.
1964 GTO
9.76 @ 137mph
2009 G8 GT
  #415
Old 05-10-2017, 03:50 PM
I have 2 STD. Sets and a 5 under if anyone needs one....email [email protected]
$285 to your door
Thanks for all the business,
Scott
Scott Sims
P.O. Box 184
47232
[email protected]
  #416
Old 05-11-2017, 07:38 AM
sharkbite's Avatar
sharkbite sharkbite is offline
What's the cost to have my cam gear milled and existing bearing setup checked for proper end play?
This world is your world, so take it, but take it easy.
  #417
Old 05-13-2017, 04:06 PM
Can you be more specific?
Thanks...Scott
Scott Sims
P.O. Box 184
47232
[email protected]
  #418
Old 05-15-2017, 10:27 AM
sharkbite's Avatar
Thanks...Scott
I sent you a PM, thanks
  #419
Old 05-16-2017, 04:37 PM
pm back at you...sorry for not getting back to you....
Scott Sims
P.O. Box 184
47232
[email protected]
  #420
Old 01-02-2019, 03:40 PM
Hi there everybody....I have a new .005 under rollmaster timing set with the roller set up installed....$285 to your door in the lower 48
Scott Sims
P.O. Box 184
47232
[email protected]
