Old 06-28-2016, 06:32 PM
ta man ta man is offline
Originally Posted by Torquewar View Post
I have been running a Q Jet and a self ported RPM.
My best MPH is 122.3 with a 11:44 and spinning for 3-4 ft limited traction.
Car has always ran flawless on the street and track.
Have a T-2 and a Shaker(Jeff)) 455 4150 to bolt on very shortly.
Im also trying to get the 60ft s down but im eager to see what the intake combo will do.
Over the last 2 years Andy's car has always had a faster mph than my car with his quadrajet setup which is quite impressive!Up until this year I've only ran 120 once with a tailwind..
466 Mike Voycey shortblock, 310cfm SD KRE heads, SD "OF 2.0 cam", torker 2,generic one inch open spacer
  #402
Old 06-28-2016, 06:33 PM
Originally Posted by ponjohn View Post
Has anyone tested this combo with a well adjusted q-jet?
If so what intake?
And, Ernie what size headers?
1 3/4 inch Hooker Super Comps
Cliff has ran a similar combo for years..
  #403
Old 06-28-2016, 07:19 PM
torqjunki's Avatar
torqjunki torqjunki is offline
Don't know if it has been mentioned, but MPH will always be high when spinning off the line.
1971 Base Firebird..505ci IA 2A Round port E-heads by Butler 348 cfm.. Comp street SR 266/[email protected] Victor intake/Quick Fuel Q950. 1 7/8" Dougs headers..3" mandrel bent exhaust with Hooker Max Flow mufflers, T-350 well built with 10" 4000 stall nitrous Continental converter..3.73 posi . Caltracs and 10" slicks. Belt driven water pump, alternator, Pwr steering and brakes,Flex fan. 11:1compression, straight 93 octane pump fuel. 10.35 @ 129.88 with 1.45 60ft N/A at 3700lbs race weight.
  #404
Old 06-28-2016, 08:54 PM
MUSLCAH MUSLCAH is offline
Question....why do yous guys run a 350 auto ..instead of the big brother 400 auto ?
  #405
Old 06-29-2016, 07:17 AM
Usually but not always true...Ok I will restate when we both were hooking he had a higher mph,when we both were spinning he had a higher mph..
  #406
Old 06-29-2016, 07:21 AM
I run a 350 because I've had decent luck..I've had one go a few years ago due to driver error,the last one held up pretty good no real issues..the current one is a Hughes with a low gear set.Also the 350's eat up a little less power,I can use the same crossmember and stock location,same driveshaft..
  #407
Old 06-29-2016, 09:19 AM
torqjunki's Avatar
I'm running the T-350 because it came with the IA motor. It is a mystery trans because I got no information on it when I bought the car. It came with JW ultrabell, and was running low 10's, so I assume it was very well built. So far it has been flawless. I will be installing a cheater nitrous kit soon, so I am going to swap to a T-400. Trolling the web, it appears 800hp is the max the T350 is recommended for. I don't want to hurt it or the converter. The T400 may hurt ET a little, but I need the strength. May put the T350 up for sale here soon.
  #408
Old 06-29-2016, 09:43 AM
slowbird's Avatar
slowbird slowbird is offline
Depends on the tire.
  #409
Old 06-29-2016, 10:02 AM
Torquewar's Avatar
Torquewar Torquewar is offline
Its a crap shoot with transmissions, big torque and sticky tires will make u find the weak link. Sometimes its assembly or part failure.
My th 350 broke(carnage) one Friday night. Cant remember if Ernie was there? Sucks being on a flat bed with everyone watching.
After the 140 tow bill i re evaluated . Went to the 400...
  #410
Old 06-29-2016, 11:30 AM
Pontiac Derek Pontiac Derek is offline
It will definitely make more power!
And you will lose a little power before 3500-4000 with the T2 but that might help your car hook!
Its Very Difficult getting near 600lb ft or torque and 550hp to hook out of the hole!!
Ernies Car Would Pick up from a head swap especially if he had Dave do the 305 package on his heads, that plus bumping up the compression from 10.2:1 to at least 11.00:1, But on a combo like his you almost never want to trade low end power for top end power, there is a couple things you can do but not a whole lot with out moving the power higher in the RPM Range.
I want to do a 501 or 523" cid engine with similar parts to see if i can get my
Land Barge into the 10's, it wont be easy!
Build it Right Build it Once!!!
Just another Engine Builder from the Northwest lol
  #411
Old 06-30-2016, 12:18 AM
Garry Sr Garry Sr is offline
I ordered a set of 3:73 gears yesterday. Still thinking about sending them back for a set of 4:10s. 3:08 doesn't cut the cake.
  #412
Old 06-30-2016, 01:01 AM
Silver Judge's Avatar
TA Man, I just read through all of this info about your low 11 sec ETs with this cool ride. Way to go, that's awesome performance Congratulations TA Man !
501 HP, 554 ft lbs TQ
  #413
Old 06-30-2016, 11:00 AM
71 T/A 71 T/A is offline
TA Man, how much compression do you run?
  #414
Old 06-30-2016, 12:15 PM
I dont think a PONTIAC "needs" all that gear? That's reserved for weak torque Chevies! What are you trying to accomplish? I am finding I just want to cruise. A 3.08 gear is what I think I want. Of course it needs to be mated to a M22Z. These guys doing 11.00's with a 3.08 gear get my utmost respect. I my opinion with a high gear like that, the engine is well past its torque band an just buzzing high rpm for no reason. If I'm wrong, tell me why. ; )
Bill Nye.
  #415
Old 06-30-2016, 12:53 PM
10.25
  #416
Old 06-30-2016, 01:49 PM
Yea I probably should have kept my mouth shut. While I'm impressed with ta mans times with that gear I need more out of my car. P.S. I had a 4:10 in my 69 Firebird and it was a blast.
  #417
Old 06-30-2016, 04:10 PM
What is your ET/MPH/Weight/Gear now?
Bill Nye.
  #418
Old 06-30-2016, 04:20 PM
My 73 hasn't been to the track yet. The gear at present is a dog and doesn't work with my combo.
  #419
Old 06-30-2016, 06:34 PM
So what is the present gear? I'm just asking because 3.08 does'nt seem to slow a lot of these guys down! What is the Combo? Is it all a secret? ; )
A friend put 4.33 in his car from 3.73, it slowed down. Every car has its sweet spot.
Bill Nye.
  #420
Old 06-30-2016, 09:22 PM
Weather permitting hitting the track next Friday afternoon..its a track rental day for the next day's small tire shootout guys..and I'm going to join in on the rental.Will be running a new set of rear tires ET street pros..and my carb now has an annular main body.Should be a nice relaxed atmosphere to test...Torquewar is keen too so we can help each other..track prep is promised to be great!
