Old 11-17-2008, 12:09 PM
RAFormulas's Avatar
RAFormulas RAFormulas is offline
Arrow 1970 One year only parts
Just a start... lets add all the "known" differences in the 1970 cars.
01 stainless roof drip edge moldings
02 stainless door edge guards screw in type
03 Washer bottle cap
04 brackets that hold seat belts in.
05 covers for front seat bolts
06 black plastic deflectors at the base of the windshield corners
07 Alternator/power steering/air conditioning brackets
08 core support
09 evap cannister and bracket if it had EES (California car)
10 Hood hinges
11 Low back buckets with headrests
12 Quarter panel dimples (in door jamb)
13 Trunk extensions (with two drain plugs)
14 package / speaker shelf (blower defroster cutout different)
15 Exhaust extensions
16 EES system (I think every component is 70 only!)
17 12 bolt rear
18 Formula hoods don't have metal bracing on sides.
19 Formula Ram Air cleaners are one year only (Pins and dimples for holley)
20 Very early 70 cars have pot metal rear filler panels
21 Early 70 cars have 4 trunk pan drain plugs
Steve
1970 Formula 400 (YS) M40 (67-Castillian Bronze / 215-Deluxe Medium Saddle)
1970 Formula 400 (WT) M20 (67-Castillian Bronze / 213-Deluxe Dark Brown)
1970 Ram Air III Formula 400 (YZ) M40 (26-Lucerne Blue / 201-Standard Medium Bright Blue)
1970 Ram Air III Formula 400 (YZ) M40 (26-Lucerne Blue / 211-Deluxe Medium Bright Blue) *SOLD*
Old 11-17-2008, 12:37 PM
GETRIDAONE's Avatar
GETRIDAONE GETRIDAONE is offline
How about thin dash gauge bezels ?
Old 11-17-2008, 12:57 PM
bird72's Avatar
bird72 bird72 is offline
What is different on the roof drip moldings?
72 Bird
Old 11-17-2008, 12:58 PM
2manyT/A'S's Avatar
I'm getting a bit rusty on this stuff,but as I recall,
- waterpump pulleys are specific to 70 Firebird V8 (both A/C & non)
-Also power steering pump? (one year in second gen.anyways)
-power brake proportioning valves,brackets,lines,etc. (one year in second gen only)
Old 11-17-2008, 01:20 PM
CaptCrunch CaptCrunch is offline
great thread...........
Old 11-17-2008, 01:12 PM
Norwood's Avatar
Norwood Norwood is offline
Carpet hold down clips
Window blow out clips
JW wheels
Thin lip Shaker
Single snorkle air breather
Old 11-17-2008, 01:27 PM
68bird400HO's Avatar
Headlight Bezels
Front Seat Belt Retractors
The thin dash bezel rings (and accomodating dash bezel) were used through '72.
Old 11-17-2008, 01:58 PM
tajunkman's Avatar
tajunkman tajunkman is offline
Last year for high compression
Blue trunk release button ?? 70 only ??
Different Firebird fender script.
Early inside A pillar moldings have that extra screw hole.
Black center PMD caps.
70s are the coolest Good thread.
Old 01-28-2009, 04:38 PM
giles's Avatar
giles giles is offline
70s are different. Coolest? There are pluses and minuses....but then I'm partial to 71s!
Old 11-17-2008, 02:17 PM
Dens71TA's Avatar
Dens71TA Dens71TA is offline
Stainless side window weatherstrip channel
Trunk floor different above rear axle for EES clearance.
Old 11-17-2008, 04:43 PM
giles's Avatar
Substituting plastic for steel plug wire standoffs
removing the sunvisor center tabs
outboard front seat belts (retractors in 70, flat in 71)
eliminating the chrome engine dress for 71
Old 11-17-2008, 05:23 PM
2manyT/A'S's Avatar
ONLY year for code 10 Polar White (69 + 71 - 81 are code 11 Cameo White)
Old 11-17-2008, 06:37 PM
blue71ta's Avatar
blue71ta blue71ta is offline
Angle cut on chrome exhaust tips is '70 only
Radiator support is different than '71/'72, correct?
Old 11-17-2008, 08:52 PM
blue71ta's Avatar
Oops! Core support was already mentioned.
Another one is the manual trans shift knobs (black ball for standard interior, red insert w/shift pattern for deluxe interior/4 spd and red insert w/arrowhead for 3 spd)
big matt: I believe that started in late '72 and went into the '73 model year...
Old 11-17-2008, 10:00 PM
rock rock is offline
If I new that the 70 bird was so special I woundn't have bought one! I think that photos of these parts would be benificial for all firebird owners.
Old 11-18-2008, 10:11 PM
OK... if we're going to throw colors into the mix, you have to also mention the eye-popping psychedelic bright blue interior option. Just like the white paint going from polar to cameo in '71, the blue interior was toned WAY down. If you see a nicely restored white/blue '70 sitting next to an equally correct white/blue '71, the '71 has this sort of "hey... who turned off the christmas lights" look! The red '70 interior was much brighter than in '71, too.
Overall, the list looks pretty full. Not much else I can think of other than:
1) '70 woodgrain instrument cluster bezel had a lighter woodgrain tone than '71+
2) Through about the middle of the '70 model year, the trunk floor had 4 ecoat drain holes (later cars all have only 2).
3) Not sure I saw the chrome gauge ring bezels for T/As mentioned. I know some early '71s got them as well, and many '70s seem to have not got them, but this is still mostly a "70 thing".
4) '70 rear quarter side trim pieces had no ash trays.... did '71s have ash trays?
5) And for some reason I was thinking the rear seat back frame was a bit different on a '70, too?
Old 11-17-2008, 07:29 PM
big matt's Avatar
big matt big matt is offline
Don't the 71 and up cars have a seat belt light in the dash as to where the 70's do not? That might be another one but I am not near my car to look.
1970 Formula 400 4 speed
2006 Gto. Ls2/m6
1972 Gto 455ho/th400 post coupe
1973 Grand Am 400 4 speed
Old 11-18-2008, 12:48 PM
160 speedo with seat belt warning was required for cars produced 1/1/72 & later. A few late Dec of '71 car were prob built with seat belt warning light as well.
Old 11-18-2008, 12:51 PM
Have examined original '70 1/2 T/A's with two different sized rear swaybars.
All the original & complete '71 & '72 T/A's I've ever looked at def had the 7/8" rear swaybar.
Old 11-18-2008, 12:55 PM
Whats the deal with a blue trunk release button?
I've only examined green ones in 2nd gens up till the changeover in mid '74 (yellow).
