He finished the headliner today and it looks awesome! $500 labor and it included the sail panels. He spent at least 10hrs on that sucker and it was worth every penny!
I've been sanding like mad on all the bright work. This picture is after dents removed and sanded with 320. Only 9 more steps to go. ![]() Cordova top slated for Tuesday.
1969 GTO 4spd. Antique Gold/black, gold int. 1969 GTO RAIII 4spd. Verdoro Green/black, black int. 1969 GTO 4spd. Crystal Turquoise, black int. 1970 GTO 4spd VOE Pepper Green, green int. 1967 LeMans 428 Auto. Blue, black int. |
Can't you just put that trim work to the buffing wheel after the dents are out?
Most of the SS will buff out beautifully on a wheel. |
Nope. You have to file after you hammer out a dent then 150, 220, 320, 400, 600, 800 all by hand then 1000, 1200, 1500 all with a da. After all the sanding you get to the wheel for 3 different steps. Anyway this is what I found works for me, if you want a perfect chrome looking finish.
I've done headliners 5 times in 68-72 A-bodies, and I can tell you, it certainly is not something you learn from the first shot. A lot of the result is a matter of the headliner you start with, it has to be a quality item to begin with, those things are not flat.
I had to start over twice on the 442, the first headliner was no way going to fit right, just wasn't cut right from the manufacturer. I would get all bunched up in the sail panel areas, and no matter which way I pulled, it just got worse. Ordered the second one, and it was right, but I burned it with a heat gun. 3rd one I got as close as I could and just lived with it. It has some puckers in the sail panel area, but it's a driver quality build anyway (or so I try to convince myself!). Part of the reason the 442 was such a bear was because from the factory, the shoulder belts are held in place with these crappy plastic sleeves, and I switched to the Pontiac style clips. So the way the headliner was cut in that area was part of my problem. The LeMans I did twice, the first one had minor puckers, and didn't ever heat it. The second one I got really close with, you have to look hard in the corners to see any issues, and looks great unless you're looking hard. My success was partially due to the fact that I had no windshield or rear glass installed when I did it, which allows you more room to move around. I used a soap bar to mark the lines where the bow retainer cloth was to get trimmed, and you can use thread or string taped to the roof as a guide. That controls the 'cup' of the headliner. .
Vinyl top, check. Tail lights, check. Rear bumper, check.
Picture kinda sucks but it does look great. Took a little break to clean and paint the Century Pontiac licence plate frame. ![]() ![]()
Nice, love the dealer plate frame. Great job on the repaint!
Beautiful ... we should all get a ride when it's done!
Greg, you have PM.
Practicing social distancing for 65+ years |
Looking GOOD!!! GW, Damn GOOD! If I can say so.
1966 GTO Vert automatic. 1969 CR Judge Ram Air III 4sp Pattern Car. 1969 GTO standard 350HP TH-400. 2006 GTO Phantom Black 6spd. 1972 Formula 455HO Ram Air. 1976 LE Trans Am 50th Anniversary Edition with T top. 1976 Formula 350. 1977 Grand Prix Model J 350. 1978 Trans am 400 Pontiac. 1979 Trans am 403 Olds. 1968 Olds 442. 1971 TR6. |
I normally frequent the big car sections here, but the thread title "Restoring my Grandmas 69 GTO" caught my eye and I must say I'm happy to have taken the time to read through it all.
The work you've done is amazing to say the least! It clearly shows how much you love that car and your Grandma! Again, outstanding job! Dave
1967 2+2 hardtop 428 w/auto 1967 2+2 convertible 428 w/4 speed 1967 2+2 convertible 428 w/auto 1967 Bonneville Brougham Coupe 428 w/auto 1967 Grand Prix convertible 428 w/auto https://www.plainfieldpontiac.com/ *BE SURE TO LIKE MY FACEBOOK PAGE* https://www.facebook.com/PlainfieldPontiacRescue/ |
Vinyl top trim install tip..... don't Use to many clips, 3 across the back and 2 across the quarters is enough. We started with 7 across the back and could not get the trim to snap on. Well we could get 1 or 2 started if we worked real hard then we'd have to take it off and try over. Truth be told we spent about 10 hrs just installing the quarter marker lights, the 3 pieces of stainless on the deck lid and screwing around with the vinyl top trim and did not get any of the trim finished up. Came back to it a few days later and Mike brought some clips he's had since back in the day. We screwed them one at a time to a bench and shaped an old piece of trim over them a few times to make it easier once we went to the car. We started with 7 clips and no go! Went to 3 and it snapped right on. Took about 4 more hrs finishing up the top trim and reinstalling one piece of the deck lid trim we were not happy with.
Mikes coming over tomorrow for another day on the car. Good times!
Got the dash put together and love the way it looks! Going to put in soon with pictures to follow.
Here is some pictures of the stock dash speaker I modified to hold two 3.5" speakers. I covered it with black speaker cloth so you can't see the speakers thru the vent in the dash. I had the stock radio modified to be am/fm with outputs for Bluetooth, amp, mp3 player etc. Looks totally stock. Way over priced but very cool imo. ![]() ![]()
What a fantastic idea with the speakers!
RediRad circuit designs, branding and intellectual property are for sale. Serious inquiries only. |
Dave. ![]() Check my build thread here http://forums.maxperformanceinc.com/...d.php?t=753467 |
Great idea with the front speaker
Frank Szymkowski 1969 GTO Judge Warwick blue/blue, RAIII, 4 speed, tach/gauges, Safe T track, 3.55's, ps and radio. 1971 Torino 351c 4v GT convertible. White on white with black interior 4 speed, shaker, am/fm, ps/pdb, buckets/console, ac. One of 26 made |
Gtozy, Taman Electrical did my radio. I am happy with the way it looks but have not had a chance to hear it work.
So years ago when I started this project I bought some stock height springs from opgi. Well they left the car setting to high for my liking so I switched them out for sum UMI 1" lowering springs and I am much happier. ![]() Ordered some repo dome light switches and they are different then the originals so I cleaned up mine and used them. The one on the left is an original, one in middle is original after I cleaned it up and the one on the right is aftermarket.
Nothing like a restoration-correct reproduction...that ISN'T.
Did you rezinc the nuts on those dome switches or bead blast them ... or something else?
