Old 12-22-2013, 06:32 PM
David Holmberg's Avatar
JC, Jack said it was an option.
  #462
Old 12-22-2013, 06:54 PM
J.C.you's Avatar
J.C.you J.C.you is offline
Post
ok, how did I miss that?
  #463
Old 12-22-2013, 09:09 PM
Daniel Barton Daniel Barton is offline
WOW!!!!
Guess not.
Pro Stock Truck hasn't ran for over 10 years.
I didn't follow it anyway, have no clue what their specs were.
Just using 2300 weight and 7.43 ET, around 1100 HP.
That was good of you to put your figure up to show just how inaccurate you are on these sort of things! You honestly believe that a overhead valve traditional American V8 with pushrods makes over 3 horsepower per inch??? I appreciate you showing that you know absolutely nothing about these type of engines and their applications. By the way... you should NEVER figure horsepower off of ET. Just wow!
Life is hard, it's even harder if your stupid- John Wayne
The Following User Says Thank You to Daniel Barton For This Useful Post:
  #464
Old 12-22-2013, 09:14 PM
Dragncar Dragncar is offline
OK fellas, What do you think these heads would do in very high effort power plants like Rodney Butlers, the Dirty birds or John Welters.
Boosted to the max. Maybe the added head bolts for extra durability ?
How much HP does it take to be "all in" in Pro Mod ? 3500- 4000 ?
And could the current blocks take it. I know the MR1s experience cap walk at very high HP levels. And if they do the AP blocks certainly do since they are basically the same block.
These heads on a new Pontiac block with priority main oiling, larger and higher cam tunnel, somewhat shorter deck and a LS1 style cross bolted mains. Just might be the ticket.
Hey, at this point I would still call it a Pontiac, why not. There is room for both. The iron heads and RAIV cam guys and this.
Visner said he had a non canted valve Pontiac head on one post. The head I would like to see is a Pontiac head that takes a standard Pontiac valve cover, inline valves and RAV exhaust location. Just put the intake ports/ runners where they need to be to make the most power with the room you have without any pushrods going through the middle of them. At least it would "look" like a Pontiac.
  #465
Old 12-22-2013, 09:54 PM
7000 posts to look through, I don't know it was right there.
  #466
Old 12-22-2013, 10:34 PM
LiL Jack's Avatar
LiL Jack LiL Jack is offline
nice pic....was there any thought process including a provision for extra headbolts?
There can be four extra head bolts at the 12 and 6 o'clock position above and below the cylinder on 4,6,3 and 5. If I remeber correctly.
Visner thought it up.
First Pontiac powered street car in the 7's
[email protected]. 3460#s
  #467
Old 12-22-2013, 10:48 PM
Travis Q Travis Q is offline
I think that these heads would rock and roll in a blower combination. They would also help a turbo combo, as well...but not as much as a blown combo.
We've had a grand total of zero head gasket issues since we went to the added head bolts on the E head. The billets might not even need the extra studs, especially if you had room around the stud to go to a 9/16" stud like Eric and Mike did with their Fives. That would sure be an added bonus...less crap to deal with is always a good thing.
  #468
Old 12-23-2013, 12:23 AM
Elarson's Avatar
Elarson Elarson is offline
10 head studs is plenty if you have a stiff enough head to bridge between them....and spread the combustion loads to more than just the 4 closest studs. Boss Bird has zero head gasket leakage and we're still on our first set of copper Flatout gaskets..
Eric
  #469
Old 12-23-2013, 12:30 AM
Elarson's Avatar
The Visner billet heads look pretty stiff and I think they'll probably seal great.
Eric
  #470
Old 12-23-2013, 10:44 AM
ponjohn's Avatar
ponjohn ponjohn is offline
Why not on both?
  #471
Old 12-23-2013, 01:06 PM
twinturrbo406's Avatar
twinturrbo406 twinturrbo406 is offline
[QUOTE=Daniel Barton;5091717] You honestly believe that a overhead valve traditional American V8 with pushrods makes over 3 horsepower per inch??? /QUOTE]
http://youtu.be/HihdoLYhWy8
... this one makes right on 2.9 per cube ...
The Following User Says Thank You to twinturrbo406 For This Useful Post:
  #472
Old 12-23-2013, 07:11 PM
cptinjak cptinjak is offline
[QUOTE=twinturrbo406;5092090]
2.875 to be exact
Yes we make 1140-1150 with our ANDRA pro stock stuff. Those are some sweet little smallblocks.
Jack
Visner Engine Development, LLC.
The Following User Says Thank You to cptinjak For This Useful Post:
  #473
Old 12-23-2013, 07:36 PM
Originally Posted by ponjohn View Post
Why not on both?
Would definitely pick both combinations up, no doubt.
Blown engines rely a great deal on the ability of the cylinder head and camshaft to move air through the engine; the compressor is tied to the front of the crankshaft. With a turbocharged combination, the air compressor is not tied to engine speed, so there is a little bit more latitude with what we can get away with.
You will see a lot of folks that say "bolt a bigger head on, and you'll make more power with less boost". Most times, that is a fact with a blown combination. And most (not all, but most) times, that statement is total fiction with a turbocharged engine. They are two totally different animals that are typically run in different ways on the racetrack.
  #474
Old 12-23-2013, 07:48 PM
cptinjak, thanks for the info on your head.
How long did it take to make Jack's head?
He said 3 1/2 months, but that seems long for a CNC'd head.
Also, the head still needs port work when you're done maching it?
It looks like a great head and will make some serious power.
  #475
Old 12-23-2013, 08:02 PM
2.875 per inch is bad ass, but it is not 3.0 per inch which on a 400 is a difference of 50 very expensive and time consuming horsepower to find on an engine like that! The 3.07 number per inch that was thrown out would require another 29 horsepower to be picked up,again.... by NO means a small feat! On a 358" engine the difference between 2.875 to 3.07 is 70 horsepower! In terms of engines like this, that is no mole hill, that is a mountain!
  #476
Old 12-23-2013, 08:05 PM
LiL Jack's Avatar
3-1/2 months was from start at the word go. David had to do all the CAD work on it and thankfully he had a Pontiac block there.
As I said before it would have been done in three months but there was an issue with one of Davids machines.
David said he could finish the ports, but Gaby wanted to finish them his way specifically for a PA car.
  #477
Old 12-23-2013, 08:20 PM
Scott Roberts Scott Roberts is offline
I'm sure Visner could have done a great job finishing but Gaby has a proven record that I would have gone with too. Look forward to seeing it run Jack. Best of luck to you. You are much better off with the Visner head over the Warp 6 head!
The Following 3 Users Say Thank You to Scott Roberts For This Useful Post:
  #478
Old 12-23-2013, 08:27 PM
T Syron's Avatar
T Syron T Syron is offline
Let say...these heads set the pontiac world on fire....would visner ever consider casting these heads for the common folk?
Thanks,
Tom Syron
  #479
Old 12-23-2013, 10:12 PM
65nss4spdGTO's Avatar
65nss4spdGTO 65nss4spdGTO is offline
Thanks,
Tom Syron
Visners business is making billet cylinder heads for many different brands and applications. Speaking with David at PRI, we talked at length about the cost of development and the profits associated with production.
Cast iron cylinder head cost point can be reduced based on the number of units sold, so like any business man would ask, how many cast units could be sold? High end production cast cylinder heads from Profiler, Dart and others for BBC and SBC would range from $5,000 to $8,000 ready to bolt on, so how many sets of Pontiac heads could be sold in a year at those price points? Add new manifolds, valve covers and other items and the cost to change over a race engine would be around $10k to $13k.
Calvin Hill
Hill Performance
708-250-7420
  #480
Old 12-23-2013, 10:31 PM
Like LiL Jack said, the 3.5 months was with all design, CAD, and a broken machine delay. On an order for a head that is already designed, our lead time for a set of billets is closer to 10 weeks. 90%of our heads are sold finished. That is valve jobbed, polished, and ready to assemble. We can sell them at any stage of completion though. Some people like them with little tiny ports, no seats, no guides, etc. Most people want us to do the finish polishing though.
Jack
