Old 07-18-2016, 08:38 PM
77 TRASHCAN's Avatar
Ernie,
I'm guessing Andy and Chris were there, as well?
Jeff
Shut it off
Shut it off
  #462
Old 07-18-2016, 09:48 PM
cnc's Avatar
cnc cnc is offline
Yep We were there ....
First time for me running with any type of drag radial ever...
Best time 13.07, 60 ft 2.01, all @107.79..and I was spinning .....
I need to work on my burn out technique
I also need to get rid of the air shocks in the azz end as there is no give in the rear so not sure if that would help.....they will be off in a few weeks and hopefully we will be back in Aug.....hopefully I can borrow Andy tires again.....
I actually ran a 13.06 @108 on street tires peddling the car.........figure that one out.....
Ernie and Andys cars are ridiculous.....in a good way
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best [email protected] Lookin for 11's
  #463
Old 07-18-2016, 10:13 PM
Torquewar's Avatar
Torquewar Torquewar is offline
Yup there also with the new T-2 and Jeffs 4150 custom unit.
Not a good night.
First run blew the tires off and ran a 13:27 115.
Second was a 11:45 121 but with a hesitation. Then the alt belt ate itself and a PS belt got the result. Both out . Had one and Ernie had a spare.
Next 2 runs really bad hesitation from the line....called it.
Spent the aft on the car found a huge vacuum leak. Cant believe i missed it. wanted to crawl under a rock...It was hard to spot .
Everything reset and good to go....runs perfect.
Yes Ernie......i owe you a belt....all good. Still fun with the boys.
  #464
Old 07-18-2016, 10:22 PM
Torquewar's Avatar
TA Man]It would be a great roadtrip!I'm about 10hrs away!
Lets get a big trailer and do it.....would be a blast.
Talked to Jeff tonight , great guy covered some tech stuff and had a few laughs,
  #465
Old 07-18-2016, 11:05 PM
goathead455 goathead455 is offline
Trailer ???????
  #466
Old 07-18-2016, 11:18 PM
grivera's Avatar
grivera grivera is offline
Chris- you're knocking on 12's dude!! I assume fuel issue totally gone?
Not a good night.
Wow -Fast car!!
Will Rivera
  #467
Old 07-18-2016, 11:21 PM
It'd be easier for him to head your way... Maybe you can bribe him...get him the #3 at McDonalds AND supersize it!
Shut it off
Shut it off
  #468
Old 07-19-2016, 01:30 AM
Will Will is offline
Originally Posted by ta man View Post
...On the street the 1050 felt sluggish..the track confirmed it....On a positive note even with the car running slow for 2 runs it was still 11.34/11.36 at 120...
Sluggish. Heh.
  #469
Old 07-19-2016, 06:31 AM
cnc's Avatar
cnc cnc is offline
[QUOTE=grivera;5604067]Chris- you're knocking on 12's dude!! I assume fuel issue totally gone?
Yep Will no more falling on its face....
It was a fun Night....again....
I gotta get into the 12's ......
  #470
Old 07-19-2016, 11:06 AM
I wonder what Andy and Ernie do, sway bar wise. I've never raced, but have read in the past to loosen them or leave them off???
My buddy had a 72 GTO that was raced from day one, it had front and rear sway bars fully intact with plastic bushings in the end links. This car had some kind of drag race shocks, road like a lumber wagon on the street, mind you this was 1970's technology.
Shut it off
Shut it off
  #471
Old 07-19-2016, 12:27 PM
ta man ta man is offline
It has been years since I've pulled my front sway bar off..I didn't like the feel of it especially when if I get sideways that was with 375hp in a 13 second car..I may experiment with it a bit...but for now the car leaves very level and smooth...Once I get a proper video I will put one up..My suspension is very simple..just CE 3 way adjustables...90/10 50/50
466 Mike Voycey shortblock, 310cfm SD KRE heads, SD "OF 2.0 cam", torker 2,generic one inch open spacer
  #472
Old 07-20-2016, 10:50 PM
You're definitely going fast enough. From what I've seen you'll actually MPH a little higher with wheel spin than when you hook up. I think it's because the spinning wheels act like a loose torque converter and allow the engine to stay in a higher RPM band until the car really gets moving.
I bet some simple changes will allow you to hook better. I was getting high 1.6x to low 1.7x 60' times on street tires and running high 12.60s to low 12.70s @ 106-107 MPH with all poly bushed stock suspension and Koni shocks.
For a burnout I smoked them as hard as I could. More heat helped. Dunno if it would be the same with DRs.
  #473
Old 07-21-2016, 06:33 AM
cnc's Avatar
cnc cnc is offline
Yeah I saw. Few cars there with lower MPH than me with quicker times
Well from what I was told from a friend who watched my burnout said I didn't do it long enough .and perhaps I wasn't in the groove of the track quite right either ...so next time more burnout time......and maybe a better eye....
  #474
Old 07-22-2016, 05:51 PM
shaker455's Avatar
shaker455 shaker455 is offline
DO IT!
Carburetor building & modification services
Servicing the Pontiac community over 25 years
  #475
Old 07-22-2016, 05:52 PM
shaker455's Avatar
  #476
Old 08-31-2016, 11:20 PM
Going to do some basic jetting and timing changes for Friday night testntune..been running the same jetting and timing for 3 plus years...
  #477
Old 09-01-2016, 07:39 AM
Lee's Avatar
Lee Lee is offline
I've ran several sets of 275/60-15 drag radials (BFG, M/T, and Goodyear) on two different cars, and have a stack of 1.5x 60' times. Tire pressure is typically at 24-25psi.
For the burnout I have one of the sideview mirrors set to where I can see the smoke coming off the tire. When the smoke density turns from "light" to "dense" I ease off the throttle and end the burnout. Goigg any longer is just throwing away tire life. Get them too hot too often and seem like they turn hard and offer less traction. Usually stage somewhere around 2000rpm, then flash the converter a little.
'73 T/A (sold). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 317rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'.
  #478
Old 09-24-2016, 11:43 PM
My wife and I had a good weekend at the track..bought a cheap RV a while back and trailered the car down..ran Friday night stayed overnight and ran again Saturday..Friday night I wasn't thinking I was going to run..there was a light drizzle on the way and it didn't look too good..We arrived picked a beauty spot under a big old willow tree..they were dragging and prepping the track...I figured what the hell havent ran the car for a while..lets see how it performs..it was actually drizzling when I was driving up to tech..After tech I asked how is the track..a guy with a 9 second car told me no worries!..1st pass was the best of the night resulting in a 11.22 at 121.60 with a best ever 1.6240 60ft..next pass 11.2519 at 121.69 with a 1.6301 60ft..last pass upped the jetting spun hard ran 11.5280 at 120.95 with a 1.8210 60ft...called it a night ...track was getting greasy..
Saturday...first 2 passes spun..11.3837/121/1.737 11.3612/120.91/1.7639...dropped jetting 4 numbers front and back to test..3rd pass slop on start line..11.4612/121.53/1.7610..last pass and new best.........11.1692 with a 122.24
Meanwhile Andy (Torquewar) was there too!His first pass was 11.18!He spent time between several runs fine tuning the carb....and the result was his best on the last pass!
10.99............................................. .................................................. .................................................. .................................................. ..................................Congrats Andy!
  #479
Old 09-25-2016, 01:27 AM
grivera's Avatar
Wow! Congrats to both of you.
Will Rivera
  #480
Old 09-25-2016, 07:52 AM
cnc's Avatar
cnc cnc is offline
Yep way to go guys ,,,,,freakin cars are fast......
