Old 09-25-2019, 09:05 PM
sdbob sdbob is offline
Thanks Frank. Hmm I wasnt where of pumping problem. My all original SD still has the 80 psi pump. When I built my other SD, I used the 60 psi spring in an original SD pump. I had a 421 in a 63 GP in the 70s. I pumped enough oil in the valve covers,about 5800rpm, it came out on headers,scary.
Old 09-26-2019, 10:35 AM
frank.g frank.g is offline
Turns out, in stock form, the 80 lb. pump was overkill - rule of thumb is 10 pounds per 1000 rpm. 60 lb. pump is perfect for these high torque Pontiac engines, in stock configuration. The 80 lb. pump was most likely supplied because engineers expected this engine to be modified for racing applications. Remember the motor had ports for installing an external oiling system, among other features.
The 60 lb. spring was good choice for a stock rebuild.
What year is your all-original SD? If 73, you might want to pull distributor and check wear on teeth of the distributor gear. Quite a few of the 73's seem to have suffered oil starvation at the gear, with resulting gear failure. It seems that the 74's improved the oil supply to the distributor (larger port) , as gear failure was not as common on the 74's.
Old 08-04-2019, 12:58 PM
Brewster's Avatar
Brewster Brewster is offline
Keith good deal. Now you can dip your hood spring ends in some blue/green paint to mock originals
Old 10-11-2019, 12:43 PM
Ebay.. 73 SD Formula.. Is anybody here familiar with this car?
https://www.ebay.com/itm/223699589679?ul_noapp=true
Old 10-26-2019, 03:11 PM
Transamric's Avatar
Looks like a serious flood victim.
Old 10-27-2019, 11:29 PM
Shift'n Gears's Avatar
Shift'n Gears Shift'n Gears is offline
I'm with starlightblack, That is criminal!
As far as being staged- it has sunk up to the rims and has mold(moss) growing on it with stain lines that follow rain cascading off of it. Seem like a lot of work to stage/Photoshop a pic.
So many of the 74's had SD stickers put on them who know if it is real SD-455. Hopefully it is a 400 automatic car.....
1978 Y84 4sp
1979 T/A 400 4sp Blue/Oyster (special order)
2000 T/A WS6 6sp Black/Black
Old 11-04-2019, 09:49 PM
Decals on scoop looked to high but you never know what guys at factory would do. Mine were inside scoop ,mechanic friend told me when he received car new at dealer.
Old 12-11-2019, 05:31 PM
burd burd is offline
He wants to see original tags on orig cars not tags people make. I know, we spoke on the phone.
Old 12-11-2019, 06:59 PM
77 Canamman's Avatar
Thumbs down
Good for you..
The artwork came from a NOS pump. Go back to selling your overpriced nOS crap.
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
Old 12-11-2019, 10:10 PM
gilg gilg is offline
I found in other Forum picture of 1974 Camaro Z28 with the same Decal Style as the the Low Miles 1973 Super Duty from another forum and both decals look the same
For 1974 Z28 "BK" is the correct P/S code and is stamped on ink over the decal
For 1973 SD "HG" is the correct P/S code and is stamped on ink over the decal
the correct code for P/S pump its located on BOX 32 in the Build Sheet for both Models
My conclusion is probably this decal is the same for 1973 and 1974 F-body and the codes changes was made on Ink stamp
i posted the pics what i found and also my own version of the decal.
Name:	Full page photo (2).jpg
ID:	526472   Click image for larger version
Name:	1973 TRANS AM 7.5 AUTO NW 01774 MILES RED (14).jpg
ID:	526473   Click image for larger version
Name:	Wednesday, December 11, 2019.jpg
Old 01-09-2020, 03:48 PM
starlightblack's Avatar
starlightblack starlightblack is offline
This one popped up on Dave Hall's Facebook page, unsure if he bought it/owns it or not. Neat interior, aftermarket Hurst Shifter...a fine driver. Says one owner from Florida, but those pics definitely look more like Nebraska, where Restore A Musclecar is based.
He has a knack for finding great T/As , that's for sure.
Name:	Screen Shot 2020-01-09 at 2.41.07 PM.jpg
ID:	528508   Click image for larger version
ID:	528509   Click image for larger version
ID:	528513   Click image for larger version
ID:	528511   Click image for larger version
Old 01-10-2020, 02:15 PM
Originally Posted by starlightblack View Post
This one popped up on Dave Hall's Facebook page, ... one owner from Florida
Great Car !
It's optioned pretty fancy for a 73 4spd SD too
Would like to shake the man's hand that ordered it new.
Those guy's are my Hero's .
Old 01-10-2020, 08:16 PM
Definitely a Florida car I’ve looked at it several times
Old 12-02-2019, 05:42 PM
Held for Ransom's Avatar
Ask member PAUL K
So long, farewell.
Old 12-03-2019, 08:24 PM
Thanks!
Old 12-08-2019, 06:12 PM
Hi i try to recreate the POWER STEERING RESERVOIR DECAL on 1974 Trans Am SD 455 Super Duty anyone have survivor with this original decal on the side of the P/S reservoir??? Thanks
Old 12-09-2019, 12:35 PM
RicksGTO's Avatar
RicksGTO RicksGTO is offline
Would be interested to see if this was from the factory on all/only '74 SD's, what they look like, and I would be interested to get one if you reproduce them
'72 Formula 455HO TH400, Revere Silver, black deluxe
'74 Trans Am SD 4 speed, Admiralty Blue, blue deluxe
Old 12-10-2019, 08:52 AM
Question
These?
Old 12-10-2019, 04:53 PM
Transamric's Avatar
Is '74 different from '73?
Old 12-10-2019, 08:00 PM
Red Goat's Avatar
Red Goat Red Goat is offline
Yes. '73 is different than the one shown above. I'll post a picture when I get home for reference. I had some made for '73 that look spot on.
69 GTO 400, 4-Speed, Matador Red
69 SCJ Mach 1 Mustang, 4-Speed, Drag Pack
72 Trans Am, 455HO, 4-Speed, Lucerne Blue
73 Trans Am, SD-455, 4-Speed, Brewster Green
73 Formula, 455, 4-Speed, Ascot Silver
73 Formula, 455, Navaho Orange Survivor
