Old 03-27-2013, 02:22 PM
Gator67's Avatar
Gator67 Gator67 is offline
Default WIW 70 Formula
Original and complete minus engine & transmission. Free of rust and dents, but in need of full resto after sitting in AZ sun. Carousel red, parchment?, 4-speed, non a/c.
Old 03-27-2013, 03:00 PM
2manyT/A'S's Avatar
Probably anywhere between $500 & 5000........Depends on how bad you want it/ what it really needs & what you intend to make it into...
You could easily drop 20-30K restoring it.....likely cheaper to find a decent original or one that's already done.
Eye Candy......garage band?
Go full screen & turn it UP!
Old 03-27-2013, 05:37 PM
That is pretty much the condition I found mine in and I paid $2800 for it in 2008. If you want to see what it will cost to do the car, you can view my thread since I posted the cost somewhere near the end.
http://forums.maxperformanceinc.com/...d.php?t=605832
Old 03-28-2013, 07:01 PM
Gator67's Avatar
I've looked through your thread, thank you for including the link. General condition of the car I'm referring to seems a little better, but not significantly so...hard to tell from photos. Your car certainly turned out terrific...I'd be thrilled with that outcome.
BTWL: VIN and trim tag indicate Formula, Van Nuys, standard sandalwood interior, carousel red (U & L)
Car has decor trim group and all is there except wheel moldings and rocker trim. Also 14 inch rally 2s, rally steering wheel, rally gauges, console...will order my own PHS
Old 03-28-2013, 10:02 PM
Told you that 70 Bird bug was gonna get you, Jeff...
Sounds like a cool car!
Old 04-06-2013, 10:09 AM
Gator67's Avatar
It's an M20 car, Keith.
The trim tag say's 65-65, see attached.
Name:	trim tag 70 formula.jpg
Old 04-06-2013, 10:59 AM
Early car... does it have a pot metal tail panel?
Old 03-27-2013, 07:55 PM
The Boss's Avatar
The Boss The Boss is offline
What's the build date on it? Does it have the 12 bolt in it? Posi? Gears?
I might be interested in it if you want to flip it.
And go racin' in the street.
Old 04-07-2013, 03:00 PM
Gator67's Avatar
Someone neatly cut away two sections where the vents should be at the rear of the hood.
Does anyone have this sectioned-out area, or a trashed hood with a good vent area section available?
...Keith, I'll check on the tail panel when I get the car this week.
Old 04-07-2013, 03:27 PM
There is a guy locally who told me he has been fixing formula hoods by cutting the vent sections out of steel hoods and grafting them into the formula hoods. I have not seen the finished product. Has anyone else done that?
Old 04-29-2013, 06:54 PM
Gator67's Avatar
I spent a couple hours on the car this weekend removing the interior. The floors and trunk need absolutely no work. The steering wheel, gauges, switches, heater ducts, a pillar trim, and headrests look to be in great shape, seats are solid but need rebuild/recover. Will need just about everything else though.
Name:	rear 70 f.jpg
ID:	321589   Click image for larger version
Name:	front 70 f.jpg
ID:	321590   Click image for larger version
Name:	trunk 70 f.jpg
Old 04-07-2013, 05:24 PM
The Boss's Avatar
THAT SUCKS! Legit 70 hood too! Don't get rid of that hood - get another and graft that section in.
Old 04-07-2013, 07:01 PM
Gator67's Avatar
THAT SUCKS! Legit 70 hood too.
Yep. Just one of those things I knew I was going to have to deal with when i decided to buy the car. I'm hoping someone has something in their stash I could use to perform the transplant. I'd also consider a complete hood.
Old 04-07-2013, 11:06 PM
Just so you can see what it will look like.
http://forums.maxperformanceinc.com/...highlight=1971
Old 06-02-2013, 12:43 PM
Gator67's Avatar
Still chipping away. Front sheet metal looks great except for some deterioration of the inner structure/bracing of the passenger fender, just the lower section in front of the door. It should be easy enough to repair, but I saw a set of perfect rust-free '70 fenders at a swap meet this morning, and I just couldn't help myself.
Old 03-27-2013, 08:10 PM
Gator67's Avatar
IIRC, 02B. Was told the original "10 bolt" is in it. I thought they all had 12 bolt in 70.
Old 03-27-2013, 09:19 PM
2manyT/A'S's Avatar
Did you check the VIN? (maybe it's just an Esprit with a hood)
Norwood build SHOULD have W66 on Cowl Tag.
ALL 1970 Formula 400's came with 12 bolts......
Old 03-29-2013, 11:04 AM
Gator67's Avatar
You were correct, Keith.
Since correct engine, transmission, rear end are all MIA, am thinking 1 of none RA4 type of build...using a cleverly disguised IA II aluminum block & e-heads, 5-speed...otherwise stock appearing inside and out. I drive my cars, and this would be fun.
Old 03-29-2013, 12:03 PM
The Boss's Avatar
That's what I was thinking but with a real WW coded block in there, M-20 & 3:73 12 bolt. Really need to have an April-June build date on the cowl to be convincing - that's when the IV TA's were built.
Old 03-29-2013, 09:21 PM
It's on my "future project list" to build something like that, too. It's a long list, though, so not sure I'll ever get there
The car you found sounds like a perfect candidate.
