Old 04-20-2014, 09:38 AM
Bentwheelbob's Avatar
My GT -37 headliner was installed by two guys. Dan and Scott, and I wish I was there to witness that. I did not look at that invoice....
But, that's a great price and the guy came to you? Was that like 20 bucks and hour?
It was more like $17 per hour - it took him about 12 hours. However, I also fed him BBQ pork. It was a deal, especially him coming to my place. One of the All Crane guys that salvaged my lift disaster told me about him. Turns out he only lives 5 minutes away. I've got him coming back to re-install some button caps on the Yellow Car's seats.
Originally Posted by njsteve View Post
I think you'll have to wait quite a while for that Rustoleum to cure since it is an non-hardened enamel, before you can attempt sanding it.
BTW you can see where I used the propane torch to clear out all the brazing from the valance to lower quarter seam. The original installer of those NOS quarters thought the gap was not supposed to be there, and filled it full of brass after installing the quarters. One side was mostly body filler but the other was a brazed up solid. I gently heated the area with a propane torch and used a wire handbrush to brush it out. It made me real nervous when I originally saw it as I thought they used steel wire to fill it and that would have taken serious grinding to get it out.
....non-hardening enamel ...Hmm....I'm doing a baked on finish. It's sitting in the sun by the smoker. Smoking a lamb roast for Easter dinner. Hopefully it will harden up enough by the time I chase my family off this evening to take a whack at wet sanding. It really looks good though. There's just a few dust nibs...
Now that you mentioned the brazed area, I can see where you cleaned it up. Looks good.
  #502
Old 04-20-2014, 02:33 PM
Default Tail Panel - It's Done
Well, the tail panel is done and so is the lamb. Now just waiting for for my family to arrive. I decided not to mess with perfection, or at least a reasonable facsimile thereof. The paint has hardened up nicely and I'm sure that I could wet sand it given enough water and 400 grit paper, but man it looks so good already. If everything went right with the sanding and final paint coat, I could make a modest improvement, however, it would be just my luck that I would get a run, sag or dry spot. I know when to stop...Hah, hah. I just hope it doesn't make the rest of the paint on the Black Car look too bad. How many cans of Rustoleum does it take to paint a car.....
I can't wait to get the new letters. This thing looks 100% better than it did, and I like the low rent nature of it.
  #503
Old 04-20-2014, 05:29 PM
The Boss's Avatar
The Boss The Boss is offline
Originally Posted by Bentwheelbob View Post
.....and I like the low rent nature of it.
And go racin' in the street.
  #504
Old 04-20-2014, 08:47 PM
One last accomplishment for the weekend before the reality of work and travel rears it's head. Along with the tail panel came the license holder/fuel door. It was in crusty shape. Interestingly. it looked like it had been dip painted as there was a clear no paint line at the top. I bead blasted it and repainted with semi-gloss black. Not sure what the correct level of gloss should be. I also replicated the no paint areas as best I could.
I hope everyone had a Happy Easter. He's a few pictures.
  #505
Old 04-20-2014, 09:27 PM
Norwood's Avatar
Norwood Norwood is offline
Those two don't work cheap.......
Bob, I wish I had your energy.......nice work
  #506
Old 04-24-2014, 08:25 PM
So I'm back home after a few days on the road and the PONTIAC letters have arrived. They look great, but they came with cheap speed nuts to attach them. The shafts/pins on the letters are short and do not have any ridges for the speed nuts to grip. In short, I need another attachment method. It seems that I remember a thread that talked about using silicone or RTV on the backside of the tail panel and around the pins as a method of securing them. Does this ring a bell? Any suggestions?
<a href="http:
  #507
Old 04-24-2014, 10:48 PM
Norwood's Avatar
they just push in.....no speed nuts
  #508
Old 04-24-2014, 11:00 PM
Not these. There is no barrel clip on the shaft, they just have a smooth shaft that is smaller in diameter than the tail panel hole.
  #509
Old 04-24-2014, 11:10 PM
Norwood's Avatar
that SUX...When you bought them from Pontiac back in the day they came with the clips on them
  #510
Old 04-24-2014, 11:55 PM
Held for Ransom's Avatar
http://www.forums.maxperformanceinc....0&#post3744670
  #511
Old 04-25-2014, 06:18 AM
That's it - thanks Mike.
  #512
Old 04-25-2014, 06:23 AM
njsteve's Avatar
njsteve njsteve is offline
The problem with the barrel clips is that the plastic panel brittles with age and the stress of pushing those clips in and then expanding them by force leads to stress cracks in the panel. I used some Home depot flat, spring clips and silicone.
  #513
Old 04-25-2014, 01:45 PM
RicksGTO's Avatar
RicksGTO RicksGTO is offline
I used a glob of silicone on the studs/holes and then pushed a small piece of 1/8" model engine fuel line onto the back of each stud to keep them tight against the tail panel. Once the silicone sets up with the tubing they shouldn't ever move or get loose.
'72 Formula 455HO TH400, Revere Silver, black deluxe
'74 Trans Am SD 4 speed, Admiralty Blue, blue deluxe
  #514
Old 04-25-2014, 03:09 PM
The Boss's Avatar
Water proof's the holes too.
  #515
Old 04-25-2014, 10:30 PM
Rick - great idea. Your suggestion worked perfectly. The only change I made was that I used windshield washer nozzle hose that I got at NAPA. It pushed on easily and once in place held the letters very snuggly (SP?) while still allowing reasonable adjustment to get all the letters in alignment. I've got it parked now allowing the silicone to set up overnight. Hopefully I can get it installed this weekend.
I've got a fairly long list of things for this weekend. I bought a new concourse door and ignition lockset from PY and I hope to get it installed. At some point the ignition lock was replaced and as a result the ignition and door locks are keyed differently. This will remedy that. While the door panels are off I am also going to install new door handles. While the doors locks and handles are removed I am going to buff out the upper parts of the doors. Then of course there is the tail panel and bumper.
Tonight I also installed the new dome light and new visor mirror. I ordered the visor mirror from Ebay from a company called Fine Sunvisors. I was really impressed with it as it was an exact replica of the original. It's a quality piece. Here's the link and a few pictures.
http://www.ebay.com/itm/370774446492...84.m1439.l2649
Are there any tricks to removing the door panels or is it straight forward? How about a little feedback please.
  #516
Old 04-26-2014, 08:40 AM
The Boss's Avatar
Just a question - was the license plate frame painted originally or was it zinc or phosphate coated and left natural?
  #517
Old 04-26-2014, 01:34 PM
njsteve's Avatar
Bob,
On the ignition switch topic: I always change ignition switches/rekey them after buying a car. It's a safety/antitheft issue since anyone could order a PHS and have your key codes in hand.
Also on the black car, the ignition switch had been replaced and someone used a crappy repro ignition switch that had no accessory position. I found an original used one and put it in the black car.
Please verify before you attempt the swap, that the new ignition cylinder you have bought will actually have a working detent position for accessory mode. You may be unpleasantly surprised depending upon where the switch was originally manufactured.
As for door panels, the black car has two non original trim screws on the top that were screwed into the vinyl (horror!) to retain the upper portion onto the door. They were there when I bought the car and I imagine the "restorer back in the 1980's did it. There are two large screws under the black plastic caps at either end of the pull handle. There are also a number of trim screws around the lower perimeter of the panel and a plastic cover plate inside the inner door lever that needs to be gently disengaged from the chrome bucket.
  #518
Old 04-27-2014, 06:39 PM
Default Two steps forward and one step back...
Well it was a pretty good weekend. Didn't get as much accomplished as I would have liked, but that is usually the case. I guess you could say I set lofty goals....
The tail panel is now installed and the lights are back in place. Unfortunately, the bumper is still garage art and has not gotten united with the Black Car. The tail panel looks great. That fine Rustoleum finish along with the new letters, bezels and polished lenses are a big improvement. The door handles have been changed inside and out, and the exterior handles have the black inset as appropriate for the Custom Trim Group. Instead of tape, I masked them off and sprayed the inset area. They look really nice.
Also, the door locks and ignition lock have been changed and now they all work from the same key. The new locks were the PY Concourse set and are really nice. The ignition lock does have the accessory position, and the keys still had the knockout inserts. However, the steering wheel is not back on yet as we couldn't get the lockplate depressed far enough using brute force to get the snap ring in place. MPD is borrowing the requisite special tool from a buddy tomorrow, so that should get remedied soon. Regrettably, we fought it so long that by the time we gave up we were both too tired and pi_sed off too even want to fool with the bumper.
While the door hardware was all off, I buffed out the doors. It's amazing how much better they look. The doors, rear quarters, rear spoiler, and trunk lid have now been buffed out and I am getting much more comfortable with the buffer. On the doors I wet sanded with 3000 and 5000 grit and it made a big difference. I'm going to go back and wet sand the trunk lid too see if I can get some of the acid rain spots out of the finish.
I'm still waiting to get the radio back as well as the jack shaft. Hopefully they will both come in this week. Once those pieces arrive the car should go back together pretty quickly. I'm looking forward to getting it on the road, and to make another burnout video...
Here's some pictures.
  #519
Old 04-27-2014, 06:54 PM
The Boss's Avatar
LOTS of progress! Very nice!
  #520
Old 04-27-2014, 07:10 PM
Norwood's Avatar
Bob, are you bringing that car to the T/A Natz?
