Old 01-14-2008, 08:25 PM
niceta's Avatar
niceta niceta is offline
Hey Steve I was going to do the same to my trim. would clear coating the trim prevent it from tarnishing or is that what the Boeshield metal protectant is?. It may turn yellow after a few years but should keep it shiny for a couple anyway?
Thanks RA111 for the measurments on the end caps
  #522
Old 01-14-2008, 08:45 PM
njsteve's Avatar
njsteve njsteve is offline
The Boeshield is a wax-like protectant that soaks into the metal. It was used by NASA to protect bare metal parts in aviation applications. It can be removed with mineral spirits. It is not a paint and won't yellow. You simply reapply it by spraying it on a cloth and wiping the part down again.
  #523
Old 01-14-2008, 10:14 PM
Brewster's Avatar
Brewster Brewster is offline
Steve, how long does last ? say if you had a bare metal sway bar and want to prevent rust? also does it leave a gloss or wet look?
Old 01-15-2008, 02:05 AM
njsteve's Avatar
I sprayed it on my bare metal drivesahft a year ago and it is still bright metal today. It doesnt really change the look at all, i.e. glossy or flat.
  #525
Old 01-15-2008, 04:58 AM
70RAlll 70RAlll is offline
njsteve-where did you get this Boeshield product??I would relly like to try it myself on some bare metal areas...thnaks for the information.......
  #526
Old 01-15-2008, 08:55 AM
Lloyd-TX's Avatar
Lloyd-TX Lloyd-TX is offline
Here you go . . .
http://www.boeshield.com/
Regards,
"455HO" Lloyd
  #527
Old 01-15-2008, 03:18 PM
cdoggy81's Avatar
cdoggy81 cdoggy81 is offline
$300-$400 per front/rear or $800 for a set, YOUCH... There has to be another company to do this cheaper
73 TA 4 spd #'s match red/white - "STOLEN" AT TERRY SPEAR's SHOP IN Columbia TN ~mid 2014
Last offical pic of the car can been seen here:
http://clubs.hemmings.com/pontiactn/...%20-%20rev.pdf
People have seen it posted FS on Craigs List back in late 2013 early 2014....
IF YOU HAVE ANY INFO ABOUT IT PLEASE CONTACT ME!!!
  #528
Old 01-16-2008, 03:02 PM
njsteve's Avatar
The body is finally at the body shop. I dropped it off last Saturday. He started on the paint and bondo removal to see what was underneath. I think we will now retitle this thread: "The Return of the Bonnie and Clyde Car." Take a look at the dent puller/bondo worm holes. I lost count at 167 on the driver's quarter.
Looks like she's gonna need a bunch of hours of metal massaging. No panel replacement plans since it is so rust free, just a whole lotta torch, hammer and dolly work in the future.
Look at photos 2 and 3. Looks like an old "Lite Brite"
ID:	118700   Click image for larger version
ID:	118701   Click image for larger version
  #529
Old 01-16-2008, 03:03 PM
njsteve's Avatar
Here's the driver's rear quarter. Very nice shape, no rust whatsoever:
  #530
njsteve's Avatar
Driver's and Passenger's side front door jamb/cowl area:
ID:	118704   Click image for larger version
  #531
Old 01-16-2008, 03:05 PM
njsteve's Avatar
A little less serious dent puller/bondo worm infestation on the passenger side quarter. There is a small rust area at the bottom of the quarter that we knew was there to begin with:
ID:	118708   Click image for larger version
ID:	118709   Click image for larger version
ID:	118710   Click image for larger version
  #532
Old 01-16-2008, 03:06 PM
njsteve's Avatar
The rear valance. This is an extremely rust-prone area on the 70 to 73 Firebirds. No patch panels are available. This one is completely rust free, just dented in below the bumper line and in need of un-denting. The upper area is supposed to look this way (the fiberglass tail panel and tail lights cover all of the area from quarter edge to quarter edge.) The only visible part is the lower valance area with the dent puller holes in it.
  #533
Old 01-16-2008, 11:42 PM
blue71ta's Avatar
blue71ta blue71ta is offline
Wow, looks like some nice sheet metal! Other than the Lite Brite area of course, but I've seen MUCH worse here in the rust belt (WI). Hopefully the body man has strict instructions to keep all of your handy work clean on the bottom side of the car?
  #534
Old 01-17-2008, 08:56 AM
FirehawkTA's Avatar
FirehawkTA FirehawkTA is offline
What method was used to remove the paint and bondo?
Johann
Iceland
'94 Trans Am Firehawk pilot car #2 of 12
'97 Grand Prix SLP ram air and exhaust, 18", lowered
'73 Firebird project
'71 Camaro project
  #535
Old 01-17-2008, 10:20 AM
njsteve's Avatar
They used a whole lotta sanding!
  #536
Old 01-17-2008, 07:21 PM
x-bird2 x-bird2 is offline
i've got a matching driver's side fender if you'd like it. matter of fact, it may have been from your car seeing how liberal they were with the drill and puller. it had 70-some holes from the nose to the wheel opening alone.
  #537
Old 01-18-2008, 08:43 AM
Steve, wow... that's pretty bad.
I would think it might be easier to just cut out the tortured section and butt-weld in a new piece. You could get the metal you need from any '70 - '81 quarter since the damaged area doesn't extend into the areas that were different amongst the years.
  #538
Old 01-18-2008, 03:58 PM
njsteve's Avatar
The bodyman sent me an email today that was titled "ready for primer". For a second there I thought he had all the bodywork finished already!
ID:	118942   Click image for larger version
ID:	118943   Click image for larger version
  #539
Old 01-18-2008, 04:56 PM
RicksGTO's Avatar
RicksGTO RicksGTO is offline
Steve, I've been following your posts closely and am trying to decide what to do and not do before paint on mine. If I'm looking at it right, yours went to the shop with the underbody, rear end and front sub-frame and suspension/core support all finished and in place? Looks like also the motor is in there and you had most of the interior out of the car? That is about the way I am trying to have mine (minus engine) before I drop it off and just wondered if that worked out well for both him and you and if he was comfortable he could keep all the detail work you have done from getting overspray, etc? Looks like he is really making good progress on yours, very glad for you that it's going good again as I know he had some dead time in there for a while. Thanks for all the posts, they have helped me a lot on my car, can't wait to see yours finished in all it's McGuyver-like glory!
'72 Formula 455HO TH400, Revere Silver, black deluxe
'74 Trans Am SD 4 speed, Admiralty Blue, blue deluxe
  #540
Old 01-18-2008, 05:41 PM
njsteve's Avatar
Right, it is a fully running car with the drivetrain intact. He knows to mask off everything and hopefully the overspray will be minimal. The entire interior is out of the car except for the dash.
I was thinking about buying one of the repro quarters just for patch panel usage on the driver's side major "Lite Brite" area. Does anyone know someone closer that has them in stock. Classic Industires has them for $139 (plus $200 freight shipping of course.) That's just ridiculous. If there was a closer dealer, I would pick them up in person. Or does anyone have a rust free body and a sawzall???
Here are the latest primer photos:
ID:	118960   Click image for larger version
ID:	118961   Click image for larger version
