Old 04-24-2015, 08:36 PM
Alvin's Avatar
Alvin Alvin is offline
Thumbs up
With all the time we've lost, he's probably finished it & bought another car already!
Yes, and kudos for the "10,000 views" to this thread too...
Old 04-25-2015, 07:12 AM
Bentwheelbob's Avatar
Bumping this thread now that the forums are back online.
BTW - What are those wheels on the NSX Bob?
Any progress on the Gold car last few days?
Thanks Alvin. The wheels on the NSX are Enkei's. Not much done on the Gold Car the last few days. Dave did get the spacers for the rear AC bracket turned on his metal lathe and made an oil pump primer out of an old distributor I had. Tomorrow we should get everything buttoned, add the oil and get it primed. Then the engine will take a little trip before getting installed...
One thing I didn't mention on the engine shots was that the Gold Car still had an original Delco Remy labeled coil cover. Although I installed a new distributor, I found a NOS Delco cap and reused the coil cover from the Gold Car. Also, though I couldn't find any correct date coded plug wires, MPD's buddy had a spool of 2Q82 8mm Belden wire I used to make the plug wires.
Yeah it seems like forever...No, I didn't buy any new cars, but I came close to buying a LB TA, but the price got higher than I think it should have and the car still didn't sell. I'll have to keep working on finding the right TA. I did get the cars rotated in the garage and the Hemi Cuda is now sitting by the door and ready to go. Took it for a little spin tonight and wow. That thing is a beast.
Old 04-25-2015, 07:41 AM
The Boss's Avatar
The Boss The Boss is offline
When you say "ready to go" is it ready for a burnout or leaving?
And go racin' in the street.
Old 04-25-2015, 08:25 AM
Alvin's Avatar
Yes & Yes?
Old 04-25-2015, 08:27 AM
Ready for a burnout...Although I admit that this is the car I always think of selling so that I can squeeze something new in the garge a little more easily. Then I fire it up and it sounds like a Nascar engine and I drive it and change my mind. It's been easy to resist the temptation because the market dropped off on cars and Mopars, but both have rallied back and I think I am back above water. I'm in it at about ~$90k and on a good day and time slot at Mecum it would probably do a good bit better than that. It is probably one of the more accurate clones out there, lacking only multiple carbs and the resonators. Correct 833 tranny, rear end, torque boxes, hemi suspension, rim blow, guages, hartz top, console, et cetera.
Old 04-25-2015, 12:18 PM
Brewster's Avatar
Brewster Brewster is offline
Hey, While your at it how about a couple donuts? Mmmmmm donuts.
Old 04-25-2015, 02:16 PM
Norwood's Avatar
Norwood Norwood is offline
I'm liking that Cuda...even in yellow
Old 04-25-2015, 03:07 PM
Brewster's Avatar
It needs a new Radiator Cap to help it reach a new level
Old 04-25-2015, 03:50 PM
Come on now, I know you love yellow. Especially in the correct context...
I think the rad cap is right, but the radiator neck is clocked wrong and need to be removed and resoldered in the correct psoition. No donuts in this car, you can barely keep it pointed straight when it breaks loose on a burnout. There is no comparison between the suspension on a Mopar E-Body and Pontiac F-Body.
Old 04-26-2015, 02:12 PM
berrygoat's Avatar
berrygoat berrygoat is offline
Bob, are they the re-pro wire looms ?
Old 04-26-2015, 04:16 PM
Alvin's Avatar
Cool
Funny, although they DO look great, I wondered the same.
Old 04-26-2015, 04:28 PM
Yes, those are the repop looms. Pretty nice actually and I would recommend them. The only issue is that all the supplied looms are for 4 wires. Originally, two of the looms on the right side were only for 2 wires. Here's a picture from the service manual. Interestingly, the distributor pictures in the service manual are off 180 degrees and show the vacuum on the wrong side.
Old 04-27-2015, 04:42 PM
transam1972 transam1972 is offline
Default LOOMS
I was loitering in this section and saw The Gold Car...WOW!!..those looms look really nice and looking good!!...brings back memories of my 1976 that had those...definitely an H.E.I. thing...bummer about no 2 wire clips...(so close)...I ACTUALLY had saved them from the wreck and toyed with the idea of adding them to the H.O. (as it had H.E.I. when I got it)...but I must have tossed them in the 1976 parts purge..and went unitized...the detail looks great though Bob...nice work!!!
Old 04-27-2015, 10:10 PM
Held for Ransom's Avatar
I know it's been a while, but are you sure you've got your distributor installed correctly? My recollection is the same as the manual. My looms when I found them packed away...
Old 04-27-2015, 11:44 PM
I'm pretty sure it is correct based on the orientation of the original distributor, and the one in the Black Car. It seems that if the vacuum is on the rights side, clocked 180'degrees different, it comes into interference with the heater hose and nipple on the right head. I would appreciate some verification from others with a running car.
Old 04-28-2015, 09:44 AM
Alvin's Avatar
Bob a quick visual of our Van Nuys built '78 W72 our distributor orientation is same as you have it installed and shown above...tach connection on passenger side w vac adv on drivers side. FWIW factory A/C car.
Old 05-03-2015, 09:49 AM
Ok, I was wrong. Watched All Girl's Garage episode and their engine was like yours.
Old 05-05-2015, 09:30 PM
6 Grrrs's Avatar
6 Grrrs 6 Grrrs is offline
If Dave is lacking the time to 'exercise' the nsx anti lock system, I would be happy to assist 😎
Tod Hoffmann
1966 GTO Montero Red Hardtop - Holley EFI'd 462, KRE DPorts/Muncie 4spd
1990 Chevy 454SS pickup - Accel DFI/T56 6spd - Hot Rod Power Tour Long Hauler
1996 Chevy K2500 ECSB 'Poopy'
2002 Honda VTX1800C
2016 Cadillac CTS Premium
My project thread: http://forums.maxperformanceinc.com/...d.php?t=516826
Old 05-06-2015, 04:23 PM
Were these girls in the garage?
No.
Old 05-06-2015, 11:05 PM
Judge - Keep the pictures coming. I need to get a buffer like that for the HRG.
Somewhere there has to be a picture of Anna K. with a gold TA....
