Old 03-31-2020, 11:14 AM
njsteve's Avatar
njsteve njsteve is offline
I have no idea why the website is rotating my photos 90 degrees? Anyone have a fix for this?
  #542
Old 03-31-2020, 12:00 PM
It's from photobucket, offhand I'd say they are changing the exif data of the pic and PY is expecting something else?
pic originally taken with a phone?
photobucket changes the parameters of portrait/landscape of phone to their website. PY sees the pic as phone but doesn't know it's been changed to fit photobucket?
  #543
Old 03-31-2020, 12:54 PM
njsteve's Avatar
Yup, photobicket and iphone photo
  #544
Old 03-31-2020, 01:05 PM
Pepi's Avatar
Pepi Pepi is offline
Looks good Steve.
1973 Formula 400 4 spd 04C build date Norwood assembly plant.
  #545
Old 04-02-2020, 04:48 PM
njsteve's Avatar
Swapped out the speedometers today. Not too bad of a job, just tedious getting to the two speedo screws and unhooking the speedometer cable. To do it you gotta remove the lower dash panel, the A/C ducting, unbolt the inner reinforcement brackets for the dash, drop the column, before you can even attempt to remove the gauge woodgrain panel and its associated hardware. An hour of labor to do a one minute gauge swap from the pod.
Now it looks like a respectable pre-smog, top speed, gauge cluster. And as an added bonus, it even works and it's reading the same exact mileage on the odometer as before!
ID:	536136   Click image for larger version
  #546
Old 04-05-2020, 04:33 PM
OVERULD's Avatar
OVERULD OVERULD is offline
Steve, I feel you brother. I had to do the same on my 74 to swap the clock out for the tach with clock.
BJ
  #547
Old 10-08-2023, 07:15 PM
allenm allenm is offline
Default Clearance issues: 255/50xZR17
Have you experiences any clearance issues using 255/50xZR17 size tires?
I don't think this post is following the thread I am questioning. This is in regards to using 255/50xZR17 tires with the 9 x 17 snowflake wheels on a 2nd gen firebird. Thank you.
