#561
Looks like another F-body under the cover in the back ground?
#562
Good eye
#563
here's my 71 firebird, in progress.
#564
^^^^awww man thats what my car looks like...but in primer
#565
Mine had been in the primer stage for a quite while before I finally got time to paint it too
#566
im saving for paint
#567
My '71 Bird as it is today. 18x9 Foose wheels (all 4), 2001 Camaro leather seats (front and back).
#568
71 Formula, what was involved in getting the rear seats to fit the 2nd gen?
#569
Removed the original latch hardware and hinges from the 2001 seat. The bottoms were easy, bend the original hoops on the bottom of the seats upward so the bolt can be vertical. After carefully positioning them (centered) with the backrest fitted mark and drill 1 hole for each bottom and bolt them to the floor. To install the back rest I fabbed up a bracket that bolts to the seat in the seat belt holes (top corners) and the wall behind the seat. This mod required holes in the wall behind the seat and two holes in the floor. Here is a link that has pages of this modification. The picturs are in reverse order for the most part.
http://s205.photobucket.com/albums/b...terior%20work/ Hope this helps. If you need more information or pictures just ask. Roy |
#570
The Bandit Rules - Make mine with a SD-455 Engine . |
#571
MAN THATS A HOT CAR!!^^^
#572
Slightly modified (Edelbrock intake and Flow Master dual exhaust)
Everything else is original. |
#573
1973 T/A Buccaneer Red L-75 A3,83k mi. #'s match 1979 T/A Atlantis Blue W-72 WS6 23k mi.survivor#'s match 1999 T/A Navy Blue 60k mi....babied ![]() 1968 442-gone but not forgotten "Oh,you can think about it,.....but don't do it!" Sheriff Bufford T.Justice |
#574
Craig you are correct, that car isn't decal'd like a '73. Either got the bird, or a plain hood, which personally I liked the plain hood. The bird always was too much for me. But I don't believe they ever put the stripes on a 73. Then again, I have never professed to know much about the 73';s./I could be wrong.. someone who really knows correct me if I am wrong..
#576
With the '73 you could either have the Big Bird, or the little bird on the front bumper and no stripe. I would have liked the stripe as an option too, but it was not to be.
#577
ok, teach me masters, what else, other than then the air cleaner makes it a 73, the grills are not 73.....
#578
The car looks straight and pretty clean. Paint job is wrong (noted above) with those strips and antenna was in the windshield that year. Looks like its has the wrong front end and springs due to its height but easy fix either way.
What's the month/year of production and options? |
#580
We have a thread buried somewhere about all the differences between a '73 and earlier years. A few off the top of my head are, bumper, grills, bird, rear bumper sits out further, seat belts, Seat Belt Trays, Fender Braces, high collar seats without seat belt loops, Trim Rings on Ralley Wheels, Front Valence, Headliner.
