Closed Thread
Old 11-26-2023, 07:17 AM
Cliff R's Avatar
Cliff R Cliff R is offline
This thread continues to drag on and at this point going no place.
I have lost sight of what the purpose of the thread was exactly, and where it is headed.
All I know is that the engine was taken apart because it has issues, noise was one of them. Multiple issues found and several modifications/repairs made to correct them.
I beleive the worst issues where a cracked harmonic balancer and some loose valves in the guides. It was also discovered that 7 out of 8 pistons are facing the WRONG direction. BIG flag goes up there as when you install pistons with factory pin offset in them backwards the pistons are wondering all over the place in the bores. Far as I know after 625 responses I'm the ONLY one with direct experience in that area actually having done it . I told Mike very clearly that my DIRECT experience running an engine for an extended period of time, which was apprx 10,000 miles with 8 pistons installed in the wrong direct REQUIRED removal of the engine to correct noise and other issues with it like too much oil consumption for my liking. Plus the engine just never sounded or ran right, but I hate to use vague blanket statements like that, but for sure I knew something was fundamentally wrong with it. It bothered me enough to remove it as it just wasn't making the grade.
I also stated that once the problem was found and the pistons installed the right direct any and ALL issues with that engine were corrected and it went on to lead a very good life in my main mode of transportation (1979 K-5 Blazer) for many years. At the time the engine was removed I was commuting from Williamsburg VA to Portsmouth VA apprx 100 miles round trip 5 days a week. This put a LOT of miles on that engine in a hurry so it was nice to have discovered the pistons in backwards deal and correct that issue. By the time I sold the K-5 Blazer I'd logged almost 200,000 miles on that engine as it frequently made 1200 mile round trips from Va to Ohio and nearly every weekend in the summer months from Williamsburg to the outer banks camping and surf fishing. It also made trips to Florida many times for vacations, and out to Colorado Elk hunting more times than I can count.
After putting the pistons in the correct direction no engine noise and oil consumption was next to nothing between oil changes.
I noted the problems with that engine and the solution but for some reason it went on deaf ears. Even worse some very knowledgeable folks came on and pretty much told Mike it's OK to reverse factory pistons in the bores which only muddied the water here and gave him the "out" he was looking for (my opinion).
So this ill fated engine goes back together with knurled valves guides (another HORRIBLE repair that I have a lot of DIRECT experience with) and thick head gaskets with a new harmonic balancer hanging on the front of it. It has more issues when placed back in service and even after the cam was put back somewhat close to where it should be IT STILL MAKES NOISE!
A REALITY CHECK is needed here. When you go into an engine, or anything else as you move thru your life and you find problems, they need to be corrected or you just might continue to have problems.....DUH?
Old 11-26-2023, 08:52 AM
TRADERMIKE 2012 TRADERMIKE 2012 is offline
Originally Posted by Cliff R View Post
This thread continues to drag on and at this point there is no place.
All I know is that the engine was taken apart because it had issues, noise was one of them. Multiple issues found and several modifications/repairs made to correct them.
I believe the worst issues were a cracked harmonic balancer and some loose valves in the guides. It was also discovered that 7 out of 8 pistons are facing the WRONG direction. BIG flag goes up there as when you install pistons with factory pin offset in them backwards the pistons are wandering all over the place in the bores. Far as I know after 625 responses, I'm the ONLY one with direct experience in that area actually having done it. I told Mike very clearly that my DIRECT experience running an engine for an extended period of time, which was approx. 10,000 miles with 8 pistons installed in the wrong direct REQUIRED removal of the engine to correct noise and other issues with it like too much oil consumption for my liking. Plus, the engine just never sounded or ran right, but I hate to use vague blanket statements like that, but for sure I knew something was fundamentally wrong with it. It bothered me enough to remove it as it just wasn't making the grade.
I also stated that once the problem was found and the pistons installed the right direct any and ALL issues with that engine were corrected and it went on to lead a very good life in my main mode of transportation (1979 K-5 Blazer) for many years. At the time the engine was removed I was commuting from Williamsburg VA to Portsmouth VA approx. 100 miles round trip 5 days a week. This put a LOT of miles on that engine in a hurry so it was nice to have discovered the pistons in backwards deal and correct that issue. By the time I sold the K-5 Blazer I'd logged almost 200,000 miles on that engine as it frequently made 1200-mile round trips from Va to Ohio and nearly every weekend in the summer months from Williamsburg to the outer banks camping and surf fishing. It also made trips to Florida many times for vacations, and out to Colorado Elk hunting more times than I can count.
So, this ill-fated engine goes back together with knurled valves guides (another HORRIBLE repair that I have a lot of DIRECT experience with) and thick head gaskets with a new harmonic balancer hanging on the front of it. It has more issues when placed back in service and even after the cam was put back somewhat close to where it should be IT STILL MAKES NOISE!
A REALITY CHECK is needed here. When you go into an engine, or anything else as you move through your life and you find problems, they need to be corrected or you just might continue to have problems.... .DUH?
Cliff, you were 100% correct with the Transmission, when you told me to rebuild it and the diagnostics of the metal "O"-rings were damaged behind the pump, this kept the oil from reaching the three clutch packs, but in my case, going the long way taught me a lot and gave me the confidence to go ahead and build my first Trans. Bonus: it actually works great!
Moving on, this is the same thing at another time, stay with me, please, I am almost there, moving in a positive direction at my own rate.
(1) We pulled the Windage Tray and found no issue.
(2) We inspected the oil filler inner tube and found no issue.
(3) My roommate explained to me how the Windage Tray works on this Motor with the built in scrapers, I have seen the race Windage Trays so I was intrigued by the Pontiac Engineers prowess.
(4) The good news is that the Rods are in correctly, fillet to fillet and round to round, Lou had to feel with his finger, each one, to come to that conclusion. The pictures he took were NFG.
(5) The new Flexplate arrived and I suspect, using my time-honored detective Enginuity, that the thin shim being out of round, at the bolt hole circle x 6 holes is moving along with the Flexplate and the 1/8" reinforcement plate, they too are without centricity or centricalness. If you multiply 6 holes x 3 parts = 18 movement areas that I intend on eliminating, most of it. First, I will use brake quiet behind the Shim and plate. Second, I will use new ARP hardware with Loctite on the threads. The ARP kit comes with ULTRA-TORQUE "fastener assembly lubricant used to precisely replicate all ARP fastener clamp load specification's", part # (100-9908). A picture of part # (100-9908) is in the attachments below with the instructions for its use in this application. New ARP bolts are coming for the Flexplate to Torque Converter soon.
It is my hope and wish that this humble detective puts another problem to rest as he has done so many times before with this second-hand machine, that has been a nightmare for the past 10 years or so. Two steps forward and three steps back it seems.
This repair, being the least of the two repair evils, VS. You're insisting on rebuilding the motor now, today and already! You ever think that I could be right or just plain lucky. Please give me the room to grow with this hobby as you have done, it's the only way that I am going to learn and Mabe save time and money at the same time.
A tribute to your knowledge, it has been very valuable and if I had it to do over again, I would have kept this Vehicle in the drive way, instead of putting another 300 miles on the broken Trans.
On the other hand, this is another story, this is a strong Engine with a few auto-curves to get around, especially when you're starting with a fresh build, which this Motor project essentially is.
Even if this current day repair doesn't fix this latest noise, it is a necessary repair, at this time, IMO. Mike out.
P.S. As was the replacement of the Harmonic Balancer...The long saga goes on, "how do you think I feel?". God, please give me a break with this project, so that I can enjoy it, AMEN.
Name:	Crank Shaft 428 ci Pontiac.jpg
ID:	623776   Click image for larger version
Name:	Flexplate Instructions 1.jpg
ID:	623777   Click image for larger version
Name:	Flexplate Instruction 2.jpg
ID:	623778   Click image for larger version
ID:	623779   Click image for larger version
Old 11-26-2023, 08:13 AM
steve25 steve25 is online now
I too am done with this string of posts in regards to this motor and refuse to offer up any more potential help or idea’s until the OP starts a new more focused post.
There another 5 year long string of post on here that needs to end and start anew with whatever different issues the OP may be having.
Old 11-26-2023, 09:06 AM
More Crank and Piston Caps.
ID:	623781   Click image for larger version
ID:	623782   Click image for larger version
ID:	623783   Click image for larger version
ID:	623784   Click image for larger version
Old 11-26-2023, 09:10 AM
Continuation Crank area ...
ID:	623786   Click image for larger version
ID:	623787   Click image for larger version
ID:	623788   Click image for larger version
ID:	623789   Click image for larger version
Old 11-26-2023, 09:26 AM
Continuation of Crank and Piston 428 ci Pontiac Motor...
I filled in a few photos of my Vehicles Interior , "why waist the Band, by not using all of it, while I am there, using it to begin with?".
ID:	623791   Click image for larger version
ID:	623792   Click image for larger version
ID:	623793   Click image for larger version
ID:	623794   Click image for larger version
Old 11-26-2023, 09:34 AM
JSchmitz's Avatar
JSchmitz JSchmitz is offline
Think ya got enough RTV on the oil pan gasket?
The Following User Says Thank You to JSchmitz For This Useful Post:
Old 11-26-2023, 09:55 AM
You will have to ask my roommate about that one, however when we put the pan back on, we can touch up the paint in that area, I have a full can of engine paint in stock for touch ups.
Old 11-26-2023, 10:57 AM
Kenth's Avatar
Kenth Kenth is offline
Looks like all but # 2 piston rods are mounted backwards with the pistons and oil spurt holes away from cam.
We all know, well almost all, what that means.
This engine is a true disaster and the owner is NOT making anything better.....
BTW, there was nothing wrong with the flexplate, shim or reinforcement ring. And, ALL original Pontiac flexplate shims has 2 oval enlongated holes.
Just tourqe it 95 lb/ft and it will NOT move (or making noises).
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 11-26-2023, 11:21 AM
BTW, there was nothing wrong with the flexplate, shim or reinforcement ring. And, ALL original Pontiac flexplate shims have 2 oval elongated holes.
Just torque it 95 lb/ft and it will NOT move (or make noises).
You said:
"Looks like all but # 2 piston rods are mounted backwards, with the pistons and oil spurt holes, away from the Cam. We all know, well almost all, what that means. This engine is a true disaster and the owner is "NOT" making anything better.
Mikes reply:
You can see that in the photos that I posted, my roommate felt, with his hands, each and every Rod and has determined that the Rods are orientated correctly. Flat to Flat and rounds to rounds?
Old 11-26-2023, 09:46 AM
A few more photos...
Name:	ARP Hardware Crank to Flexplate.jpg
ID:	623796   Click image for larger version
ID:	623797   Click image for larger version
ID:	623798   Click image for larger version
ID:	623799   Click image for larger version
Old 11-26-2023, 10:19 AM
Cliff R's Avatar
No doubt a good bit of that RTV will end up in the oil pump tube pick up screen. I've pulled down PLENTY of engines assembled with
"generous" amounts of it and much like using teflon tape on fuel fittings that chit comes loose and "snakes" it way into everything.
It's been quite a few decades since I used factory cast iron rods but going from memory here the early rods that used oil spurt holes have the bearing tang on the same side and they face TOWARD THE CAMSHAFT.
Your pics, from what I can see of them having them facing AWAY FROM THE CAMSHAFT. IF I am correct everything involved with your spinning and rotating assembly is FUBAR!......
Someone please correct me if I'm wrong here as I don't have the energy to go to out to the shop and dig up a used Pontiac factory rod and not sure I have any made early enough to have spurt holes in them anyhow........
Old 11-26-2023, 10:36 AM
JSchmitz's Avatar
I was going to post a prediction that this engine will spin bearings as a result of RTV in oil pump pickup. Way too much applied here. You can see rows os squeeze out. Ultra Black would be much better in smaller quantity.
One of my least favorite shake my head moments is seeing that people have used sealer, or tape, on flare fitting.
Old 11-26-2023, 11:26 AM
Holeshot71's Avatar
Holeshot71 Holeshot71 is offline
Just noticed this also, you are correct. Post 629 pic #4, rod is marked #6 or 8 but is definitely in hole #7 and is backwards.
'71 GTO, 406 CID, 60916, 1.65 HS, '69 #46 Heads 230CFM, 800CFM Q-jet, TH400, 12 Bolt 3.55
'72 Lemans, Lucerne Blue, WU2, T41, L78, M22, G80
Old 11-26-2023, 10:46 AM
The reason for this and other long posts that I have Posted is beneficial to me, so I don't have to be looking all over the forum for lots of posts and neither do my readers, I like to run my posts that way. You have the right to run your post any way you want. So, should I. There are others on this site with long posts, but you don't complain about them. Give me a break. In addition, if you look at the 37,784 hits that I have on this post alone, you would know why I am still here. See Mikes: "HO Information Divulged", it has 41,795 hits, last time I looked. Please don't leave, you can always skip over that which you don't want to read, at any time and your input is certainly necessary for the community, as well as me. Other people, all over the world are benefiting from the wisdom on these pages, I have had Moderators say that I present a lot of good info.
Mike out. I must start reassembling this Vehicle to see if I the people that suggested to "see the Windage Tray and Harmonic Balancer and oil dip stick tube", nailed their diagnostics. Since the Rods are orientated correctly that is a relief off my mind. How can you say that I am not making progress?
Let me experiment with this project, as I said before, I am "not" Samantha on Bewitched, that can wiggle her nose to get things done. I do "not" dispute that the Pistons being installed backwards x 7 is affecting the current issue. If that day comes, I will be the first to apologize, honorably, but not yet, not yet. Only quitter's quit, I am a winner.
Once we get humpty dumpty back together again, if any noise is evident, then I will take a video of this Vehicle running for all to see and hear from wince the noise is coming from. Which I think is a good idea from whoever came up with that one.
Old 11-26-2023, 11:11 AM
Kenth's Avatar
Your information about your car and engine is a prime example of what NOT to do and the good information comes from everyone who is trying to help you, don't believe otherwise, even if it seems like that information is not reaching you. I could be wrong, but the fact that people still look at your posts is just to see what craziness will come next. But as said, it's your car and you do what you want with it.
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
All I mean to say is at this point seperate issues your experiencing should go into new post that you start for them.
Old 11-26-2023, 11:01 AM
The last use of the oil spurt holes in the rods was in early 67 326 and 389 Motors.
The holes faced the center of the motor if the rods where oriented right .
Old 11-26-2023, 12:42 PM
Mikes reply:
I have presented a picture of the 428 ci motor with the Flats toward the Flats and the rounds facing the rounds, so how is it that the squirters determine the orientation of the Rods all of a sudden? I was told to check said info., now that I have done that, by hand feeling the rounds and flats. Will someone confirm, that at least, we don't have to worry about the Rods being in backwards. Only the Pistons, 7 of them, are now backwards, yes?
Old 11-26-2023, 01:38 PM
Kenth's Avatar
Mikes reply:
You are clearly in need of a Pontiac Service Manual.
HTH
Name:	Piston Rod Assembly1.jpg
ID:	623808   Click image for larger version
Name:	Piston Rod Assembly2.jpg
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
Closed Thread
