Yes, hard to know what the car came with this many years down the road. I just know what I have observed personally and what the MPC shows. XJ code should have the 10.5 cr 670 heads according to the parts book.
I use the same method.
Those books don't always tell us right every time. I had buyers for 061 heads after the HPP flow test articles, and kept a look out for them. Only ever had that one set on the XJ engine. 73-74 #46 heads with screw in studs from 350 engines got popular after those articles too. |
| The Following User Says Thank You to thews For This Useful Post: | ||
Home porters and home builders wanted them. They didn't bring as much as 67-72 screw-in stud D-ports , but they weren't even sellable at all before the HPP articles. Going rate would have been 150-200pr . 250-300pr for 67-72 screw-in stud heads. Back then. 1970 intakes got popular , and #46 350cid heads -also- after the articles. There aren't anywhere near as many hands-on guys now as there were back then. Paying to port or fully rebuild cast iron heads now is a diminishing return compared to box stock aluminum heads for non-numbers cars. |
68 Firebird in Connecticut at $40K BIN. Prolly lots of mud in the rear flipper. Not many pics and none of the dash.
https://www.ebay.com/itm/14694566644...Bk9SR8KP4b3LZg ![]() ![]() ![]() ![]() ![]()
And now for something completely different, 1953 Pontiac Chieftain Sedan Delivery in Indiana for $30K BIN. Cool car.
https://www.ebay.com/itm/14694585089...Bk9SR6iC_cHLZg Last edited by thews; 11-06-2025 at 10:47 PM. |
Wow! 79 Firebird Formula with 27K miles at $25K BIN in Ohio.
https://www.ebay.com/itm/22706445796...Bk9SR6ST8ZbMZg |
Interesting build sheet on this 74 GTO sold in Canada. Bench seat 4 speed, but the build sheet says it's an automatic? $43K in Michigan with 64K miles.
https://www.ebay.com/itm/39721944631...Bk9SR4iPxr7MZg |
Nice 74 GTO, interesting that it had a vinyl top. Too bad about the black window moldings.
My Break Away Squad 1969 Fbird (base OHC, 350, 400HO & Sprint Cvt’s - 400HO & TA ht’s) 1969 Custom S 2dr ht 1969 LeMans (2dr & 4dr ht & Cvt) 1969 LeMans Safari wagon 1969 GTO (2 Cvt, 2 ht & Judge ht) 1969 Cat (3 Cvt’s & a 2dr ht) 1969 Ventura wagon 2 seat 1969 Exec 4dr post 1969 2 Bonnie Cvt's & 2 wagons 1969 Bonnie Brougham (4dr ht & Cvt) 1969 Grand Prix 2 SJ’s 1969 2+2 2dr ht (Canadian) |
nice 74 but how did that subframe get so beat up?
Everything comes and goes Pleasure moves on too early And trouble leaves too slow |
The center section of the subframe isn't supported on the inside so when you use it as a jacking joint, it bends like shown. I've corrected several of them over the years by cutting it out, straightening it in a press and welding it back in.
1969 TA RAIII M40 Auto Cameo White/ Std Blue Int 1970 TA RAIII M21 4-spd Lucy Blue/Std Black Int 1971 TA 455 HO M22 4-Spd Lucy Blue/Deluxe White Int |
| The Following User Says Thank You to RAJ7395 For This Useful Post: | ||
Never heard of the Willow Run plant in Michigan before. That's interesting.
Have a 74 GTO 4spd #s car that turned into a parts car after a falling tree accident. No idea where it was built. |
75 Trans AM 4-speed in Ohio at $11K NR. Says it's Buccaneer Red, but it looks a little orange. Prolly a good buff out on the paint would bring it back. Ad also says it runs and has a rebuilt 400. A set of 15" honeycombs on this car would up its value. I'm not sure what impact taking the picture in a parking lot full of fresh burnouts makes. Does it scream the car is fast, or the owner beats the crap out it?
https://www.ebay.com/itm/35787696161...Bk9SR7zGt-3MZg ![]() ![]() ![]() ![]()
69 GTO in Michigan at $26K BIN. Silver with a green interior, it was originally a Limelight green car, which is a very cool color combo. Poor pics in the ad.
https://www.ebay.com/itm/31746765806...Bk9SR7iy3pLNZg ![]() ![]() ![]()
Some projects are much harder than others. I would call this one difficult with a lot of good parts. 81 Trans AM in Texas at $500 NR. Chevy 454 with a 4-speed.
https://www.ebay.com/itm/30659314845...Bk9SR8rqv7PNZg ![]() ![]() ![]() ![]() ![]() ![]()
68 Firebird convertible in NY at $65K. Nice car, but $65K buys a lot more than this car. The little stuff stands out, like the unpainted hood tach. The original 350 engine was an odd choice to build up that much. I removed the 350 in mine and installed a 400.
https://www.ebay.com/itm/15745284698...Bk9SR8rqv7PNZg ![]() ![]() ![]() ![]() ![]() ![]()
77 Trans AM 5-speed in Kansas at $58K BIN. Beautiful car with what I think is an amazing paint job. I like the stance too. Externally stock looking, but go faster stuff throughout.
https://www.ebay.com/itm/12748301192...Bk9SR6LI74LOZg ![]() ![]() ![]() ![]() ![]() ![]() ![]()
