Old 12-16-2022, 08:04 AM
mchell's Avatar
mchell mchell is offline
it is 1.125" - too big for manual.
mchell: what car is this going on?
68-72 gm abody
71 GTO, 463, KRE 295 cfm heads ported by SD Performance, RPM intake, Qjet, Dougs Headers, Comp cams HR 246/252 ...11 to 1 , 3.55 cogs, 3985lbs.....day three- 11.04 at 120mph ....1.53 60', 6.98 1/8 mile
  #42
Old 12-16-2022, 11:16 AM
ahh.
I am using a 1974-80 GMC 1/2 ton manual master. It comes with a push rod that you can simply thread for your clevis. Use you pedal but the upper hole. Move your stop switch bracket up.
https://www.rockauto.com/en/moreinfo...t=1836&jsn=485
  #43
Old 12-16-2022, 11:33 AM
FrankieT/A's Avatar
When I was younger I always hated hydro boost. They were in trucks, Eldo's, Seville's, etc. Leakage and weird pedal.
30 years later I put it in my 71 Trans Am and absolutely love 'em. Put the system together myself for under $250 with all brand new parts except the unit itself. I won't look back...
  #44
Old 12-16-2022, 12:09 PM
Formulajones's Avatar
My 79 Chevy 1 ton had factory hydroboost. Owned that truck for about 25 years, several cross country trips pulling trailers, it never let me down, loved the brakes. I never had to touch the hydroboost system on that truck. Even on a truck with front disc and rear drum that scaled 5300 lbs that thing would stop on a dime.
Adapting them to a car to me is the ultimate if you want stopping power.
https://youtu.be/XqEydRRRwqE
  #45
Old 12-16-2022, 05:14 PM
FrankieT/A's Avatar
1000 percent
  #46
Old 12-17-2022, 01:51 PM
GOAT8U2's Avatar
GOAT8U2 GOAT8U2 is offline
Chart of brake booster size and psi to give you an idea of what happens when you move away from the 11". Problem is the Chart doesn't have the 9" dual but from my memory, it's awfully close to the 11".
I have 1 1/8 master but that was due to having 4 wheel disc brakes with 4 piston calipers, it wasn't just about pressure. The volume you need to feed those 4 big boys matters too so gotta have both on certain setups.
69 GTO Convertible, 4000lbs
462ci, 606tq/569hp - 93 oct at 34 deg (207psi)
11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10" 0 Stat, Ricks SS Gas Tank, Magna 4303, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" Headers & Borla Pro XS 3" Muffs, Alum Rad & Dual Fans, 12:1 Box, UMI Control Arms & Viking Berz Fr + Rear CO Shocks, Hella UP28 Vac Pump
  #47
Old 12-17-2022, 02:53 PM
I am not so sure about that chart...
  #48
Old 12-17-2022, 04:08 PM
Vid's Avatar
Vid Vid is offline
I had manual drum brakes on my 67 wagon and although most guys wrinkled their noses and suggested I upgrade, I never had a problem with the system or any trouble stopping when I needed to. It’s a viable option as far as I’m concerned.
  #49
Old 12-17-2022, 08:06 PM
AG's Avatar
AG AG is offline
I have a friend that put a hydroboost system in his 1971 Vette with a healthy 427 SB that makes 8" of vacuum and it works great. Personally, I don't like them because of all the extra components/lines and I don't like power brakes for anything other than keeping your car 100% stock. I prefer manual front disc brakes for the clean look of the engine bay.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule.
  #50
Old 12-17-2022, 10:26 PM
It takes only a little extra effort to hide things. I run the lines under the unit and then immediately behind the fender. The lines then come out from behind the headlight down by the frame where they go directly to the box and pump.
This requires longer lines and some different fittings so I can direct the lines where I want, so I spend a little more money on the deal but when it's finished, it's clean. In fact at first glance it just looks like it has a manual master cylinder on it.
On the Chevelle for instance, behind the driver headlight there is the washer bottle and the charcoal cannister mounted there, so you can't even see the lines running out from behind the fender over to the box.
That's how I like to do them because just like mentioned, I really don't like seeing the lines just laying on the inner fender.
