#41
As has been pointed out, and I agree with, the motor is not overheating and cooling fine. I believe in doing things right but at the same time using the "KISS" theory. It's not necessary to make a mountain out of a mole hill.
Andrew, if you want to pull all of that apart that's up to you but I don't think you'll gain much of anything. Your time would probably be better spent working on something else but that's up to you. The only issue I was pointing out is the sensor in that position isn't correct. Cliff, my good friend, you get validated more every day! |
#42
Like I said before, I've been experimenting with this lately, and had the sensor mounted in the bottom of the radiator on the hot side where it would never be uncovered with coolant, and it just didn't like it when the car was in motion. Worked perfectly sitting in the garage and idling for 30 minutes and watching the fans kick on at 185, off at 175 where we had the rheostat set, and it would pull the engine down to 175 in 30 seconds. I'd watch this cycle go on several times without a hiccup. But out on the road when the car was moving the fans wouldn't kick on until the engine reached 195 degrees and then struggled to pull it down, temp creep started making my dad nervous. I surmised that all the air moving across the radiator was doing funky things with the sensor. I ended up turning the rheostat down all the way and forcing the fans to run continually until we got home, which resulted in the engine staying around 185. But shouldn't have to do this, fans won't last long like this. So I decided to move the fan switch to the engine at the water cross over. So far now, while driving, the fans kick on and off as they are supposed to and it has done a good job at keeping the engine around 185 while driving. My only issue is I'd like to see the fans not kick on at all, or very little, while moving down the road at 50+ mph but there just doesn't seem to be enough radiator to do so at the moment. Once heat soak sets in on an hour long drive the fans have a hard time pulling the engine down below 185 and it just stays in that range. Once stopped and idling, it will cool back down. Opening up the shroud for more airflow while the car is moving has seemed to help this some but I think more is needed or maybe a change in design. But in a nutshell, moving the sensor to the engine definitely helped the scenario. |
#43
One member said it was fine and you wasn't experiencing any problems. I/We DK, so you need to tell us. Quote:
230°F~240°F oil temps are fine for the VR-1. Need 220°F to keep water out of the oil. That's water from normal combustion process. Past 260°F the oil gets to thin and breaks down fast. If you're seeing a big oil pressure drop at those temps...It's time for thicker oil. If oil pressure stays the same...Might consider running a thinner oil. And what you've got might be just right. Clay |
#44
Anyhow, back to the regular scheduled program. I ran that setup for 25+ years and 2-3 years ago swapped in a 4 core aluminum from champion when I put the A/C back on the car. I, like others, know heat is one of the worst things for a motor and have always ensured I had plenty of cooling capacity. I think you mentioned it previously, what radiator is Larry Sr. running now? I have no issues with cooling and most if not all of the time the flex-a-lites come on at low speed, only time they run at high speed is when I turn the A/C on which is determined by a sense lead at the control module. |
#45
Now if a 200 thermostat is in place then I would agree, the system is performing as intended. Sent from my SM-T817V using Tapatalk |
#46
Jeff |
#47
That also means if it already can't run at that temperature, pushing the car much harder may result in an actual overheat situation.
#48
Could be a whole bunch of reasons why, but technically if everything is happy and working properly, you can make an engine run at any temp thermostat you care to install. |
#50
Swapped the copper core rad in my TA for a Cold Case aluminum hoping for better cooling on the highway or in traffic with the AC on. Ended up gaining heat faster and having to use heater to control it from over heating. Noticed coolant leaking from the overflow tube below the rad cap. The aluminum tube is smaller diameter and the original hose didnt fit tight so it leaked coolant and also sucked in air on recovery. I did hear a gurgling sound. Changed to a heavy wall hose to seal better and after a couple of heat cool cycles and the air is out of the system it stays at 180.
#51
OP: Check your fuel pump divider, move your fan switch to the water crossover - not the radiator, see how it drives then. From what you're describing, it doesn't sound too dire and it just needs tweaking.
'71 Holden HQ Monaro - 3850lbs race weight, 400c/i - 11.4 @ 120 '66 Pontiac GTO - 389, 4 speed street cruiser |
#52
That's how you say it... dang...
#53
The 160, 170, and the 180 I tested all behaved nearly identical. For example the 160 actually started to open around 158, and around 162 it was beyond half way, at which point it's open enough to cool the car. It reaches full open at 165. The car I have this in actually will fluctuate 158 to 162 on the gauge on a cold day, because the stat is actually cycling, and as it just cracks open the temp will drop to 158 and close, then back open again. You can watch this as it goes down the road. Done some of this testing in computer controlled cars with HPtuners hooked up on gauge display while driving. With a 170 stat in that car it would force it to run right above at 172-173 degrees as long as I was moving. On a cold day it would run 167-168 and move up and down between 167 and 173. This stat was never fully open at 173 either, it just happened to be open enough to keep the engine cool. On a hot day the car would run 178-179 while moving. So I didn't program the fans to come on in that car until 190 and off at 185. Bottom line, from what I've found, the stats don't have to be fully open to cool the engine, especially if the cooling system is up to the task. If you have a 160 stat that doesn't fully open until 180, I'd personally be swapping it for another as that is way out of range from the testing I've done. |
#54
lol
I agree with your statements, no such thing as too much cooling capacity. If I still have your email I'll shoot you some pictures of his setup. I kind of want to change a couple things around but for now it's working for him, I just think it could be better. Comparing his to my chevelle for instance, (the 2 cars making the most power) His engine is much larger and making a good 100hp more than me. But my cooling setup isn't fancy. With 600hp/tq I also run a 4.10 gear and routinely buzz this thing at 3,000 to 3400 rpm down the highway for extended periods. Yet the engine never gets above 175 degrees and cools right back down to 165 when at a slow cruise. I mean it just never even gets close to hot. Just a simple Griffin radiator with a stock shroud and clutch fan. That Cold Case radiator looks like a nice piece, similar fin count, same amount of rows and same size tubes. Physically they are identical too, both cars being A-bodies. I can't see any quality differences in it compared to my Griffin. So his shouldn't run all that much hotter than mine in theory. I lean towards the fan setup or shroud as something that might need improvement. |
#55
I've got the dual flex-a-lite fan and in the shroud they already had two "rubber flaps" that will open as air is pushed through the areas that the fan blades don't cover. Years ago when I first made the switch from stock factory to electric I had the same challenge with cooling, the stock just worked better. In the mid 90's my factory shroud got trashed (long story) and decided to give the electric's a shot again and ended up with the flex-a-lite setup. Actually ran cooler and has worked flawlessly except for one of the fan motors died last year, so just replaced the whole assembly with a new one as I figured I got a good 25 years out of it! |
#56
Stated- "When the car is moving 40/50 mph I would think that alone should be enough air movement to cool it without fans running if the cooling capacity is sufficient."
I can confirm that. I use a Ron Davis Racing Products aluminium radiator/electric fan assembly in conjunction with a Meziere water pump. The dual fans are wired to cycle on and off as necessary and cruising down the road more often than not the fans do not come on. To confirm this I also have a separate switch that controls power to the fans, at highway speed I can turn them off and the temp stays the same. (typically around 180-185 degrees) .
#58
If the cooling system will not maintain desired setpoint, it does not have sufficient cooling capacity.
#59
#60
Still have my email? Can you shoot me a picture of your shroud? I'm curious what Ron did for yours. Everything he does is pretty much a custom deal per car. |
