#41
Intakes
I'll add two more. Edelbrock victor 4150 - 20 Original Nash magnesium 4500 - 11
#42
67 Q-jet 9786286
41 pounds
"If the best Mustang is the Camaro, the best Camaro is actually the Firebird" David Zenlea |
#43
The iron intake below weighs 28lbs. With the blocks and aluminum crossover 33 lbs.....Cliff
#44
Just weighed an old Holley SD; 18 lbs., a lot of metal in those intakes.
69 Bird w/1970 400 block(409 cubes), #64 heads, hyd. roller, Q-jet by Jeff E., original interior, ps, pdb, th350, and 3.73 gears. Pump gas, street driven muscle. 3800 lbs. race weight. Best, 11.39 @118, my son's car. 79 T/A w/463, Scat crank, Eagle rods, Icon pistons, Lunati solid roller, 262/270, KRE 325 heads, Northwind intake, QF950 carb, full interior, ps, pdb, th350, and 3.73 gears. Pump gas, 3650 lbs. race weight. 10.68 @ 126 so far... no tuning yet. |
#45
1964 Tri-Power - 46 pounds completely bare with no carb studs or water fitting. Probably one of the heaviest factory intakes.
Correct cast iron thermostat housing for 1964. It weighs in at 2.00 pounds. 1966 Tri-Power - 38 pounds. Correct cast iron Tri-Power thermostat housing for 1966. It's a lightweight at only 1.50 pounds. Same factory iron 1964 Tri-Power intake freshly bead blasted, shown here sitting on a postal scale weighing in at a little over 46 pounds. This helps me to confirm that the shipping scale at my work is accurate, at least in 1/2 pound increments. Surprised me to see that my 1966 Tri-Power intake weighed in at only 38 pounds, there's a lot of extra metal in the '61 -'64 Tri-Power intakes.
#46
The tri- power intake was so clean I thought it was an alum. intake. What does the new alum. tri-power intake weigh??
#47
51.4lbs with carb intake bolts and more. Only missing the water neck.
#48
Geez, i thought the Torker l was closer to 5 LB. Motivates me to weigh the ported Torker l. |
#49
... not sure on weight, but it sure is cool ...
#50
Wish we had intakes like the AFR composite intakes that i see listed for SBC's
super light too |
#51
Some older iron.....
.....for those of us who like to tinker with the early Pontiac V8s.
1959 2-barrel intake - 38.5 pounds. 1959 Tri-Power intake - 39.45 pounds, surprisingly enough just one pound more than the 2-barrel intake. The cast iron 1959 Tri-Power thermostat housing weighs in at 2.85 pounds, a true heavyweight with the built-in engine lifting loop.
#52
The Lightweight Champ.....
.....of all the factory iron Tri-Power intakes.
1965 Tri-Power weighing in at a scant 34.80 pounds, 36.20 pounds if including the 1.40 pound cast iron thermostat housing. The bare 1965 intake weighs nearly 12 pounds less than the previous year 1964 intake.
#53
Very interesting weights - vastly different year to year.
Water pumps next?
Some guys they just give up living And start dying little by little, piece by piece, Some guys come home from work and wash up, And go racin' in the street. Bruce Springsteen - Racing In The Street - 1978 |
#54
I did not do a complete review of the intakes so this may be a second point for the Wenzler "early" aluminum Tunnel ram. 42 pounds. The Top plate is very heavy for the basic part vs say a Weiand piece.
Tom V.
#55
My aluminum repro 66 Tripower from the Parts Place is 10 lbs bare. It has been ported,so don' know if that would make much difference.
#56
Offenhauser 5499 dual quad intake 22lbs. Per the Butler web-site. (forgot to weigh mine before assembly)
#57
I am gonna do this with all my ex-girlfriends. Will post up pics and weights soon!!
The Following 4 Users Say Thank You to i82much For This Useful Post: | ||
#58
Those intakes may not work the greatest, but they sure look cool!! Show up at a Cars and Coffee with one of those under the hood and your getting ALL the attention.
#59
never cease to disappoint i8... 😂
Esquire '74 T/A 455 Y-code SD clone previously on Dawson's Creek: '74 T/A 400 '81 AMC SX/4 '69 FB 350 |
The Following User Says Thank You to kingbuzzo For This Useful Post: | ||
#60
i8 is the best.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule. |
The Following 2 Users Say Thank You to AG For This Useful Post: | ||
