#41
Brake pedal to the floor is not a low vacuum problem. You would have a hard pedal, high effort to stop with low vacuum. More likely is air in the hydraulic system,or high travel of the pads/shoes to the rotors/drums.
Good news but a different approach to the brake repair. It will all come together, and I don't think it will be expensive. ![]() |
#42
For sure on a low pedal, check rear brake adjustment. Also check for any free play in the pedal. The pedal should only have minimal free play before in engages the Master Cylinder, but it HAS to have some. If you can pump,the pedal a few times and it slowly sinks down, you could have a MC problem. If you have low vacuum, usually a high hard pedal.
1968 Firebird 400 RAII M21, 3.31 12 bolt, Mayfair Maize. 1977 Trans Am W72 400, TH350, 3.23 T Top Everyone you will ever meet knows something you don't. Bill Nye. |
#43
"I'm told that you turn the distributor to get the highest vacuum reading, then back it off 2 inches. Does that sound feasible??"
Try it and see what you timing is. Probably best to get your brakes working well firstly, then move on. |
#44
I always start with adjusting the idle screws to achieve best vacuum.Then readjust rpm, check timing. And back and forth. Adjustment of any one parameter requires adjustment of the others, until all are optimized. And you need to check the mechanical advance. If the springs are too loose, you may have mechanical coming in at idle. That's easy to check with a 'normal' old fashioned timing light.
And since your set-up doesn't seem to have a ported vacuum source, perhaps the prior owner installed an adjustable vacuum can to stop all the vacuum advance from coming in at idle. I recall needing to do that on one motor. Maybe he wasn't screwing it up- he may have been doing what he needed based on the carb he was using. My thinking has always been that if your vacuum advance is coming in, or already all or mostly in at idle, then you leave nothing extra to come in after mechanical is in for efficiency at higher cruising RPM. If your vacuum advance is all or mostly in at idle, you may as well disconnect it and just set your idle higher strictly by turning the distributor. That's the idea behind using a ported vacuum source for advance. |
#45
![]() Quote:
https://www.summitracing.com/parts/mrg-3701 My brother had a long duration solid lifter Isky cam in his Chevelle that affected his PDB and 7" booster negatively. He installed one of these canisters and, voila, he had power brakes again. An effective solution for less then $50. Hope this is of some help. ![]()
"No replacement for displacement!" GTOAA--https://www.gtoaa.org/ |
#46
![]() Quote:
http://www.gofastforless.com/ignition/advance.htm ![]()
#47
![]() Quote:
BTW, that above canister got very good reviews for what it was intended for. I think it was 4.5 out of 5. That always encouraging. Last edited by Carmine; 04-22-2017 at 06:12 AM. |
#48
![]() Quote:
I think what it comes down to with most people here is whether they can maintain a stable consistent idle that doesn't vary much in and out of gear, and some struggle with manifold vacuum in that scenario. Usually because they have a can that is too sensitive. What people forget or don't realize, is that older cars originally were built with vacuum advance at manifold vacuum. The ported idea came along for emissions reasons (less hydrocarbons), and then that was taken a step further with TCS solenoids that wouldn't give any vacuum advance unless in high gear. We are on the same page Squidward. |
