#41
I am in need of quarters for my car, the only bad part is around the wheel well under the molding, is their any other wheel wells that match so i can broaden my search. Thanks
Damien |
#42
73 Grand-Am and LeMans rear quarter panels are the same. Going to need to find a rust free donor car somewhere in the southwest.
#43
I need hood hindges, where can i look. what other cars share the same ones as the 73 grand am.
#44
I have a '73 455 Grand Am in my yard. I have had interest in the quarters but have been reluctant to cut up the car. I am curious if there has been any progress on actual production numbers for these cars. I am trying to decide if i want to sell the quarters off of it or not. The motor is gone, the body is typical Az and very dry but the int is trashed. I would rather sell the body shell whole but they are not bringing much. the quarters are worth more.
any new insight on '73 455 GAs? Steve Barcak www.pontiacheaven.org
Hundreds of Pontiacs in Az "Real Pontiacs only..no corporate nonsense!" Facebook- Pontiac Heaven Hosting- 23rd annual Pontiac Heaven weekend- Phoenix pending due to covid Pontiac Heaven Museum in process Phil 2:11 |
#45
![]() Quote:
So any 73 Lemans/ GTO will fit.
squire john 1967 LeMans 1973 GTO 1973 Grand Prix 1973 project X 1991 Sunbird V6 convertible (wifes) |
#46
![]() Quote:
![]() My Dad's 59. The start of my love for Pontiacs! |
#47
Steve, Jim Matteson of PHS told me years ago that a production breakdown of 73-77 A-bodies would not be possible because it would involve hand-tallying data from the microfilm records.
http://www.pontiacpower.org/ |
#48
![]() Quote:
#49
![]() Quote:
Or if you need more than that, you could also use that part of the quarter from a 4 door 73 Lemans. Not the entire quarter of course, but you may be able to get all the metal you need. It's the same around the wheel opening and is the same from about the middle of the wheel to the back. |
#50
![]() Quote:
I hope you don't cut it up. Check out www.abodysite.com . There are probably more 73-77 Pontiac a-body people there than anywhere. Post there what you have and see what kind of interest there is. However, I think if you want to get the most money for it, and who doesn't, putting it on eBay would get the most exposure. Auction it with a reserve of the least amount you'd take for it and see what happens. If you only got the value of the 2 quarters out of it, you would be ahead, since you wouldn't have had to spend the time and labor to cut them off. |
#51
I have a 73 Grand Am 400 2 barrel X4 block with the 4x heads. question- is there any difference between the block and heads from the 2 barrel engine to the 4 barrel engine? the 4 barrel engine has more horsepower I'm assuming because of the bigger carb and a different camshaft. just wondering if anything else are different? how can you tell what cc heads are on the car? I'm getting a 455 GA soon. how can you tell the difference between the 455 big cc 4X heads and this 400 2 barrel 4X head?
73 Grand Am 455 Muncie M20 4 speed 3.23 gears |
#52
I couldn't tell you. If you post your heads question in the "Pontiac-Street" forum, you should get your answer.
#53
In addition to what you mentioned, 4bbl engines used heavy duty Morraine 400 bearings and large 2.11" (vs 1.96") intake valves. 400 heads are around 98 cc. 455 heads are around 114cc, if I remember.
#54
From Wallace Racing:
Year Engine Hp Code Valve Misc 1973 400 170,185HP 4c 1.96/1.66 98cc 1973 400 230HP 4x screw-in stud 2.11/1.66 98cc 1973 400 200HP 4x,4c 2.11/1.66 98cc 1973 455 290HP(455SD) 16,X(rd port) 2.11/1.77 111cc 1973 455 215,250HP 4x screw-in stud 2.11/1.66 114cc
