I am going to attempt to attach some pics before and after the new wheels and tires. The new wheels are American Racing T71R. Fronts are 17x8 with 4" BS. Rear are 17x9 with 5" BS. Tires are Nitto 555. Fronts are 255/45/17 and rear are 285/40/17. They fit with no issues. I am stoked at how they look on the car.
66 Tempest custom
front wheels 15x7 w/ 195/60/15 rear wheels 15x8 w/ 255/60/15 Too much rake?
LJ |
79 Firebird Esprit.
301ci engine. Front springs : Eibach (-1.5"). Rear springs : stock The wheels are Torq trust M chinese reproduction from Custom Wheels Market. 17 X 8 (BS :4.5" / offset : 0 mm) on the front and 17 X 9 (BS : 5" / offset : 0 mm) on the rear. Front tires : Goodyear Eagle F1 235/50 R17 Rear tires : Hankook Ventus Sport 255/50 R17 |
No big surprise here.
My 69 GTO has the standard 14x6 Rally IIs all the way around. No problems with P225/70s on them. Rarely, with 5 people in the car and hitting a decent bump at higher speeds, a quick bottom out has occured. (I plan to stuff drag bags in to maintain more height and correct this- it spends its time taking the kids out for ice cream, etc. and not at car shows or the drag strip) I think they are a great tire up front. I want a little more height and width in back. I am refurbishing a pair a HM code 15x7s for the rear. Plan to 255/70, 275/60, or, if can find, 265/65 and see how it works. (Goal- slightly increased diameter to decrease rpms while crusing, and a touch more raise to the rear end, and a little wider tire than the 225s.) Here are the 225/70 14s all the way around. ![]() ![]() ![]()
a 275/60/15 is pretty big. If the tire shop has both, see if they will test fit them on the car to see if it's the look/profile you desire and go that route. -Dan
Dan Austin, Texas Antique Gold 1969 Pontiac GTO YS400/TH400 3:23 10-bolt 2009 Pontiac G8 GT Maverick silver/Black Interior 1997 Chevrolet S-10 |
Ok, I went from 14x6 Rally IIs all the way around with p22570s.
I kept those up front. I restored a pair of 15x7 Rally IIs (take that green party and cash for clunkers, how many of them have keep 4000 or so pounds of vehicle and parts out of the scrap yard. We are the damn environmentalists, not them. There batteries filling land fills will be the end of the environment some day.) the PMD caps are not fitting the 15x7s tight, so the arrowhead caps they came with are on for now. I went with R15 p275/60s. A classic look for muscle in my opinion is taller, wider, and a little more sidewall in the rear compared to the front. You gain about 1.5 inches in diameter/ .75 in height, 1.8 inches in width, and .25 inches of sidewall in the rear compared to the front in this combo on these rim sizes. Just the look I was going for, plus a couple hundred less rpms at cruising speed. Have not had the wife, spare, and all the kids in the trunk, and hit bumps at speed, but think I am going to be OK. My "Day Two" look I was going for is complete. You can compare to my sig for the tire size appearance comparsion. I know the hood scoops, hood tach, and spoiler are suppossed to be body color. I know it is supposed to be 14 inch rims all around, no trim rings, and PMD caps in back (which if I get them to fit tight will put on), I know it is not supposed to have "GTO 400 CID" gloss black stickers and gloss black The Judge stickers on the spoiler, extra stickers on the rear window, the split exhaust tips, etc. should be a blacked out front grill, etc. Not going for a factory correct show appearance. Going for the look you had in the 70s and 80s when you got your hands on one. ![]() ![]() ![]() ![]() ![]() ![]() ![]() these are not balloons, these are how old school muscle looks ![]() ![]() ![]() ok, maybe I do need hood pins, but that will be the last thing for appearance. I swear.
"Yes, it's a real GTO. I know the scoops, spoiler, exhaust tips, and rear wheels are wrong. Umm, sure it's the 'big block' 400, you are quite the expert. I am driving in the rain, at night, running errands, with the kids who are eating and having ice cream in the back, after going to the drag strip, burning rubber, and blowing donuts. Do you really think it's numbers matching all original?"
![]() ![]() 235/60r15 Front 245/60r15 Rear Rally I's Chrome from http://www.specialtywheelsltd.org/ 15x7's Front 15x8's Rear
Troy Rockaway NJ 67 GTO 400HO / TKX 3.27 1ST GEAR-.72OD / 3.36 POSI HOTCHKIS/UMI/BILSTEIN
Front 245/60/15 Dunlop Qualifier and Rear 275/60/15 Nitto DR on powder coated oem snowflakes.
Front and rear springs were replaced in 1987 (front cut about 1/2 turn) and Koni red. Currently looking at a set of Year One 17x9 gold snowflakes (not sure of tire size yet but definitely open for suggestions). Sorry if this is a double post. |
Rally I 14" w/Diamondback, Cooper brand steel belted radials 225/70/14 also running a 4-wheel power disc brake system (yes with 14" Rally I rims)...
http://s25.photobucket.com/albums/c90/jg093/ |
These are of my 67 Bird and my dad's T-37. My wheels are Specialty Wheel Rally II's chrome with charcoal insert. Dad's are Am. racing. Soon to be the Rally II's I painted today. Can't forget the '52 TO-30 !
This is a great thread.
Front 245/60/15 old Dunlop Qualifier Rear 275/60/15 MT Drag Radial 15x8 Snowflakes I had powder coated 15 years ago, they are effortless to clean. |
235/60/15 fronts BFG's
245/60/15 rears BFG's 15 x 7 rally 2's with 4.5" backspace stock advance auto parts front springs ,cargo coils in back CC501's Nothing rubbs ever but I want to put 17" or 18" wheels on as soon as somebody makes RWL tires for them.Then I can put on some BIG brakes. |
I wanted to keep the 'traditional' look on my Formula with the period-correct 15" tires. I also wanted the ability to rotate my tires, so it was important for me to keep them the same size at all four corners. I went with a Corvette Rallye Wheel because they were cheap, could be ordered with any offset I wanted and would allow me to run the correct size tire/wheel combination until the car was finsihed and I could move up to Centerlines in the same sizing.
Whells are 15"x8" with 4.0" backspacing. Tires are 255/60/15's all the way around. I will be cutting 1 full coil off the front springs when I swap in the tubular upper and lower control arms to drop the nose down just a little...Robert |
18 X 8 w/245 X 40 Front
18 X 9.5 w/275 X 40 Rear ![]() ![]() ![]()
I am with nkowi. I also added tubular upper control arms, poly bushings on stabilizer bars, solid body bushings, sub frame connectors, stiffer and lower springs, 17" rims (though not ghetto), 6-piston front and 4-piston rear discs with 12" slotted and drilled rotors, closer ratio and stiffer valved steering box.....
For me it is about handling. I love the original look of my car, hate its original handling characteristics. I do however also like the look of "67 LeMans 326" car. I would like to know the brake set up that fits under the 14x6 inch rims.
"Pride Precedes The Fall" 1968 Firebird Undergoing Transformation 1970 Formula 400 - Keylime Green, Stroked to 462 Cubes - Gone But Forever Remembered 2016 Mustang GT - GT with the Performance Pack, beats my former 12 Boss around the track. |
Here's my car with new wheels and tires which are Foose Legends, fronts are 17 x 8 with 4.25 bs and the rears are 17 x 9 with 5.25 bs, and the tires are Nitto 450's 255/50/on front and 275/50 on the back. I have dropped the front about an inch or so.
I have 17" wheels. 7" up front, 9.5" out back. 225 tires up front, with 325 out back.
1979 Trans-Am. 3900 + lbs. 3.42 gear, 10" 4000+ Continental, 280 cfm e heads, performer rpm, 750 Holley, 242/248 HR cam, 10.2 to 1, 11.31, 117.2 mph, 1.49 60'. |
i'm gonna mess with lowering and bigger tires in the back after paint, but this will give an idea. Rims are 17x8 and tires are sport maxx 245/45/17
Lots of 69 parts for sale, please help me fund my project . Email [email protected] if ya need anything
18 inch Boyd Smoothie II all around. 10 inch wheel, with 295/35 KDW2 tires on back and an 8 inch with 255/40 up front.
12.84 @ 106.89 with street radials. 12.63 @ 108.39 on drag radials. |
