Old 08-02-2007, 07:05 PM
John Bailey (GTOKID)'s Avatar
John Bailey (GTOKID) John Bailey (GTOKID) is offline
John, what was your best MPH with the wensler2 heads? weight? for 477cid vrs 525?
  #42
Old 08-02-2007, 09:09 PM
tom s tom s is offline
just for kicks,what does 150MPH in a 3250 lb car show for RWHP?Tom
  #43
Old 08-03-2007, 05:41 AM
John Langer's Avatar
John Langer John Langer is offline
477 - 8.82 @ 154 mph weighing 3175
525 - 8.61 @ 155 mph weighing 3250 (-700' da, freaking mine shaft)
  #44
Old 08-04-2007, 12:21 PM
NHRASuperStock455SD's Avatar
NHRASuperStock455SD NHRASuperStock455SD is offline
Send a message via AIM to NHRASuperStock455SD
John,
What was the da for the 477CID best so we can properly compare the two numbers?
Lynn
  #45
Old 08-04-2007, 12:26 PM
Average Rear Wheel HP or peak Rear Wheel HP? What chassis efficiency? What air? (California Dreamin or John Langer east coast Mine Shaft air?)
Just messin' with you Tom! (Got tired of working on the SSer and was taking a break)
Our RA-V 69 TA made around 860HP(440 cu in) and went almost 147MPH (3500lbs w/driver). About 10 years afterwards I took the tires and wheels off and weighed them when I got the new SS wheels and tires. The SSer total weight for a 14.5 X 33's including 14 inch Monocoques was 42lbs. The old centerlines with slicks were 65lbs. With all the drive train technology of today that car would be well over 150MPH. I will admit that the Doug Nash 5spd helped a bunch.
Lynn
  #46
Old 08-05-2007, 09:28 PM
3250lbs/150mph 840hp on morroso power speed calculator #89650
  #47
Old 08-05-2007, 11:17 PM
Tom McQueen Tom McQueen is offline
My new Procharged street motor will get close (mid 900's). Simply running better gas and upping the boost a little would easily get me there. I figure ~29K. Flywheel to balancer, oil pan to throttle body. Procharger with drive, mount, intercooler and plumbing. All good parts. IA-2, billet crank, EFI, etc. With some parts swaps, you could do it for under 25 easily (boosted).
  #48
Old 08-06-2007, 01:20 AM
mikeb mikeb is offline
I have over $14k of parts sitting in the garage at the moment in pursuit of 1k hp turbocharged. Maybe someday i'll have what I need to finish it (about another $8k). Money is tight right now
  #49
Old 08-06-2007, 06:26 AM
8.82, da was 300'
  #50
Old 08-06-2007, 09:43 AM
Brian Baker's Avatar
Originally Posted by John Langer
you cant race math formulas.
Motor Daddy thinks you can.
  #51
Old 08-06-2007, 06:43 PM
Flyin79bird's Avatar
Flyin79bird Flyin79bird is offline
This was an expensive build for me...cant say Id do it again...but if you stop by KRE's display this weekend...my motor will be on display...havent had time to go pick it up so I bartered w Jeff to bring it to Norwalk so I coiuld pick it up and he agreed as long as he could put it on display for the weekend...its a 540 w a wenzler gustram and 2 1050's. It may disappear if I blow my motor up and I need to do a quick swap.
  #52
Old 08-06-2007, 07:34 PM
Was your motor dynoed at KRE?
  #53
Old 08-06-2007, 07:44 PM
Wareagle's Avatar
Wareagle Wareagle is offline
Talking
Originally Posted by Wareagle
Were does this guy hang--Street legal 79 T/A -No Nitrous--537 cu inch-950 hp 7200 rpm Tiger heads--IA II Aluminum block.
WOW--It sure would be Awesome to see a video of this ground pounding STREET MACHINE. Anyone.
  #54
Old 08-06-2007, 08:18 PM
kre/NA/1000?
  #55
Old 08-06-2007, 09:42 PM
Tom Vaught's Avatar
Boost Engineer
Quote by John L.:
"another vote for no, I made 991 with a single 4 intake, 525 cid and heads that flowed 380 @ 28". (2) 4's on a tunnel ram would have made 1,000."
Quote by GTOKID:
kre/NA/1000?
What do we know?:
A 380 head will make 1000+ per John.
The Kauffmans advertise the ability to create a 380 cfm head.
John L. runs high rpm
We alread know that the Kauffmans spin the blazes out of their engines. Question is will it live like a BES engine?
The engine is an engine that the Kauffmans could duplicate
Maybe as far as stroke, bore, head flow, camshaft, valve train, induction, exhaust, etc but you still have the durability factor with ANY high rpm engine.
Yep, I think that they could make 1000 HP NA.
When, how many tries, for how long, cost, all factor into the equation. Tony B obviously knows how to do it on a National Professional Basis.
Tom V.
  #56
Old 08-06-2007, 09:43 PM
Scott Rex's Avatar
Scott Rex Scott Rex is offline
Originally Posted by GTOKID
kre/NA/1000?
Hey John, Congrats.. Bruce told me about this upcoming weekend. Have a great one.
...better you than me
  #57
Old 08-06-2007, 09:49 PM
Tom Vaught's Avatar
Boost Engineer
You have your tune-up all ready to go Scott?
Tom V.
  #58
Old 08-06-2007, 10:12 PM
Scott Rex's Avatar
Tom V.
Went to Cecil County to test on Saturday, broke the trans and converter.
Jack G fixed the trans yesterday and we borrowed Langer's back up converter for this upcoming weekend. That converter was actually headed into Frank G's Grand Am, but I had to intercept it before it got to Frank. (sorry Frank)
Not sure what John's converter will do in my long stroke engine, but it's all we have right now.
Me, Langer and Bruce all broke our transmissions at Cecil on Saturday. Must have been something in the 96 degree air.
  #59
Old 08-06-2007, 10:13 PM
Thanks, Scott. My life has taken a huge 180 turn! Its been really good...I will never forget the past ...JoAnne was a great lady and Its still hard to talk about her with out tearing up. But Life moves on...I never guessed it would move this fast. Thanks again, John
  #60
Old 08-06-2007, 10:25 PM
brandon brady's Avatar
brandon brady brandon brady is offline
Scott, how tight of a coverter do you run. We have several that you are welcome to use!
