Old 06-04-2008, 08:57 AM
Mr_GTO's Avatar
Mr_GTO Mr_GTO is offline
Originally Posted by 1967Clone
Too bad you can't watch their episodes on the net.
I think you can download it from ITunes.
http://www.powerblocktv.com/sites/ho...11&ep_sea=0801
  #42
Old 06-04-2008, 10:28 AM
1967Clone's Avatar
1967Clone 1967Clone is offline
I can't seem to find the link to download them?
  #43
Old 06-04-2008, 11:26 AM
Z Code 400 Z Code 400 is offline
Originally Posted by Will
Juliano,
The point is that your engine is a high compression engine, which is what that cam was designed for. It doesn't work all that great in low compression engines, there are many better choices for engines with low compression ratios.
Bumper,
This addresses your previous concerns adequately. As for my preference to use tight LSA's in low compression 400's and 350's, yes....I gave away several of those cams and everyone has reported better throttle response, higher vacuum and higher cranking compression than the K2801 or the 068 that they replaced.
No one that has used the cam is willing to put their car on the rollers, because these are basically street cars, but seat-of-the-pants is an important factor for these basically stock daily drivers.
As far as the 068 is concerned, the only thing that has been 'proven' is the cam will physically fit into any Pontiac block and work, even when mismatched with lower SCR. However, the LSA and valve events will show the profile was designed for higher SCR applications, so it isn't surprising that a tighter LSA and earlier IC event would be a better performer overall in a lower SCR application.
If you refer to Jim Hand's book, he explains this fact in the camshaft section quite well...Robert
