Old 08-25-2009, 10:56 PM
JLHarper's Avatar
JLHarper JLHarper is offline
Mike,
Can you buy PB BLASTER in bulk volume? I read where you poured 1/2 gallon down this eng in attempt to unstick it.
I have never seen it in large containers but dont have commercial sources some of you might have in business.
I have only seen it local in spray cans.
Thanks.....
Jeff
  #42
Old 08-25-2009, 11:10 PM
Jeff, it's available thru several sources online in gallons.
Locally our NAPA store stocks it in gallons and rattle cans.
Mike
former." --Albert Einstein
- Winston Churchill
  #43
Old 08-26-2009, 07:38 AM
2002Z4CSS's Avatar
Trans fluid will also work in the cylinders to help free up the rings.
1971 Pontiac GT-37
  #44
Old 08-26-2009, 10:11 AM
I've run trans fluid thru it mixed with PB Blaster, That's worked well for me in the past. I've been under it with Large prybars on the flywheel, broke The longest 1/2" breaker bar that Snap On makes on the balancer bolt trying to get this one loose. It's stuck tight!
I pulled a Valve cover on it yesterday to see the condition of the engine internally and it's CLEAN. Oil is clean and no metal shavings on the stick. It was obviously well cared for during it's previous life and IME those are the ones that stick the tightest, so to avoid more carnage than has already been done I'm just going to pull it and preform and autopsy.
Mike
- Winston Churchill
  #45
Old 08-26-2009, 06:14 PM
Old Goat 67's Avatar
Mike,
CD booklet scanned. Sent you a PM.
Charles
  #46
Old 08-26-2009, 07:36 PM
Got them, thanks again!
Mike
- Winston Churchill
  #47
Old 08-26-2009, 08:39 PM
Should be a total of 32 pages Mike.
If you are missing any, let me know.
Probably more than you really wanted, but.........
Charles
  #48
Old 08-26-2009, 08:52 PM
GPCONV's Avatar
GPCONV GPCONV is offline
Arrow
I had a '69 that I had picked up from a friend I knew in high school, he had the motor set up on him when he started it on a cold morning, at the time I was working at the local gas station & repair shop, we put the thing on a lift one night and wedged an ice breaker bar in the flywheel and started to let the lift down which was the old air/hydraulic post style, by the time I caught up with the lift pressure the front of the car was a good foot off the lift and the motor broke loose, she ran after that, but knocked bad and blew up 2 days later... ahh memories.
  #49
Old 08-27-2009, 12:16 AM
Charles
Charles, ?Information is a good thing, especially when dealing with an out of date ignition system that looks cool hanging on the firewall!
Thanks a lot, I'll have the wife print them out and if any don't come thru i'll let you know.
MIke
- Winston Churchill
  #50
Old 05-23-2010, 10:33 PM
Dragging this back to the top.
Pulled the engine out of this thing today. Appeared to unmolested Vin stamped on the block matches the car. Stuck tighter than hell wouldn't budge after a gall on PB blaster was dumped in the cyl's last fall and I filled the block until it was running out the valve covers with a mixture of used engine oil and kerosene. Left it sit all winter and still won't budge so out it came. Putting the engine out of my Firebird 'vert in it for now. 68 block so it'll appear to be right.
A/C still had freon in it.Oil was nasty tho so that'll get flushed.
Trans fluid ran out pink.
Anitfreeze that was left came out green, Water pump is stuck as hard as the crank is.
P/S has a cooler on it. First I've ran into that on one of these.
Carb appears to be OE.
Ink stamp still on the Steering gear, Front pump of the trans has a number ink stamped on it also.
No apparent numbers on the firewall but it's pretty filthy. I don't think I'll clean it up this time, Probably will do that when the original block goes back in.
- Winston Churchill
  #51
Old 05-23-2010, 11:42 PM
Keith Vrabec's Avatar
Keith Vrabec Keith Vrabec is offline
One guy I know swears by diet coke as a way to unstick. Must be the right amount of acid I guess.
  #52
Old 05-24-2010, 08:17 AM
1970gpsj4speed's Avatar
1970gpsj4speed 1970gpsj4speed is offline
t must have been overheated bad.I got a couple over the years filling with tranny fluid and using the starter to roll over most of the seize will be the wrisp pins and or bearing surfaces.it really dont take musch to lock one up when you are looking at .002 everywhere
BOB SLUSSER
937-286-4343
  #53
Old 05-24-2010, 11:14 AM
I doubt this was overheated it sat for 33 years without turning over. That'll stick one every time.
When I get around to tearing it down I'll update that info.
BTW, this car is a bloodthirsty bastard.
- Winston Churchill
  #54
Old 05-24-2010, 07:19 PM
GpFreak's Avatar
GpFreak GpFreak is offline
Arrow
Take a little skin off did she?
Steve Naresky
  #55
Old 05-24-2010, 10:11 PM
se428bandit's Avatar
se428bandit se428bandit is offline
Mike,I had a '69 GP with a 428 and it had also sat for a long time.The motor was also stuck,so myself and a friend pulled the engine thinking the worst.Ending up being the top of the cylinders had moisture in them from sitting.Ending up going .030 over and the crank stayed std/std.When we took it apart it ended up being the cleaniest engine the friend of mine ever pulled apart and he does that for a living,Good Luck.
  #56
Old 05-24-2010, 11:11 PM
As of right now I'm not going to tear the OE unit down. I may do that this winter or after the 65's back on the road. I've got a suspiscion the pistons have grown fast to the cyl walls.
Eventually this car will get the full treatment but for now I'm looking for something to put miles on. It'll be at the POCI convention, Norwalk, and the POSI run, Maybe a few others as well.
I'm hoping to have it running yet this week but work isn't cooperating as customer cars are rolling in on the hook in mutiples this week. I put an hr in tonight pulling the temp engine out of the 64 GTO and said **** it I'm beat.
Mike
I've got the itch to be driving one now.
- Winston Churchill
  #57
Old 05-24-2010, 11:28 PM
Stuckinda60s Stuckinda60s is offline
Hey, Mike!
I've got a couple of projects going around the place and if things don't work out right in the near future, I may bring your last year's Norwalk show car's little brother to race this year. It's a '64 Le Mans I'm putting back together; and, if I can't get the body done in time, it may rival yours (without the patches).
I've got a couple of other options but that's the quickest (and dirtiest). It ran 11.80's and should be in that range when I get it back together.
If I don't bring something, I think Keith will probably shoot me, so that gives me a little more incentive.
Rich
The real democratic American idea is, not that every man shall be on a level with every other man, but that every man shall have liberty to be what God made him, without hindrance.
Henry Ward Beecher
"The problem with socialism is that you eventually run out of other people's money." Margaret Thatcher
  #58
Old 05-25-2010, 08:20 AM
Keith's got my permission to shoot you [as long as he fixes the hole afterwards!] if you show up again empty handed!
I look forward to seeing the PA version of a rat. Hopefully we have a drier year this time around! The "tent time" was good also last yr tho.
- Winston Churchill
  #59
Old 05-25-2010, 08:22 AM
More than a little. This thing's got some of the roughest castings /sharpest edges I've ran across in a car of this generation.
Mike
- Winston Churchill
  #60
Old 05-25-2010, 10:04 AM
Rich I wouldn't shoot you....with the Remington 870 12 ga that I took the plug out and it will fire 5 shots now.....But you're gonna bring it then right....(click...chunk, chunk....)
