Old 09-08-2009, 09:20 PM
PONTIAC LARRY's Avatar
PONTIAC LARRY PONTIAC LARRY is offline
Good to know on the LSA , I had not bought a Crower 60919 yet but had planned on it..
So is a OEM Mellings 041, a Crane Blueprint RAIV , Edlebrock Performer RPM cam and the Crower 60919 are all the same? LOL Just kidding...
63 Catalina coupe 467 cid budget drag car low 11's 1/4 , 7.0's 1/8th pump gas n/a
66 Star Chief Executive 59k mile 389
67 IH Scout project 2WD "Indian Scout"
69 Le Mans 2 dr HT 350 91k mile 15 sec 1/4
69 Firebird 400 Burgandy/Black
70 Olds Rallye 350 F85 4 speed 3.91's
70 Olds Cutlass Cruiser Red Wagon 350 108k miles 15 sec 1/4 12 sec w 455
74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8
2020 RAM 1500 SLT 4x4 5.7 A8 Hemi
2008 Saab 9-3 2.0T convertible
  #42
Old 09-09-2009, 06:19 AM
Cliff R's Avatar
Cliff R Cliff R is offline
Larry, if the truth were known, the Crower, Edelbrock RPM and Melling 041 are probably the same cam from the same source. The Crane version is advertised as "computer smoothed", which reduces the seat to seat timing a bit, and takes some overlap out of it. I've known a few folks to use the Crane version, and no doubt their engines idled better than the real 041.....FWIW.....Cliff
  #43
Old 09-09-2009, 08:48 AM
71 T/A 71 T/A is offline
Default Comp 305 Magnum?
Posted on another website........
If you wanna run real fast use the COMP Magnum 305H. I'm into pontiac's pretty heavy and that is the best cam I've ever run. I've tried all the factory performance grinds RAM AIR cams,HO grinds, not even close. me and my buddy Big Block build a 455 with 6X heads, Magnum 305 cam, forged pistons, factory crank & rods, high rise intake Holley 850, 400 turbo, 12 bolt 4:11, 71 LeMans ran 10.60's at 138 mph. I'm telling ya, you won't be dissapointed.
So what about this cam?
  #44
Old 09-09-2009, 10:03 AM
He probably left off the part about the nitrous...LOL
  #45
Old 09-09-2009, 11:23 AM
Steve C. Steve C. is offline
Cliff stated- "I contacted a cam designer, who told me specifically that the seating velocity is simply too fast, and can and will cause troubles at high rpm's."
And this from a recent magazine cam article within the subject about valvetrain inertia as a whole....
"Hopefully the mass of the valvetrain and high spring pressures allow the lifter to follow the cam all the way down the ramp. If not, the lifter will bounce, which kills the valve seat and sends harmonics that destroy the springs as well as the needles in roller lifters. This reduces the volumrtric efficiency of the engine, as the valve doesn't seat properly and robs horsepower."
You must design the entire valvetrain to work as a single system. The problem is that the weight of all the parts, the elasticity of the components, and the effects of the springs all work against the cam motion at high rpm.
  #46
Old 09-09-2009, 07:36 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
I was mentioning UD cams for similar short seat duration but the same 0.050 as the crower/041. Since the XEs may have problems why not use some UD lobes?
I used one XE in my TAs original motor when I freshened it a few years back. A custom one 262/270 on a 112 LS. I was not impressed much either and never got a valve tick out of it, the seat duration was longer than Comp said even at their own lobe lift. Similar motor with a Sunnit 2801 runs better.
Skip Fix
  #47
Old 09-09-2009, 08:01 PM
Murf'sDad's Avatar
Murf'sDad Murf'sDad is offline
Here's a UD cam for you. But I'll be running it with solid roller lifters lashed at about .008".
FWIW, Stewart
Name:	UD Cam Card.jpg
1976 TA, nose converted to 1970 style, 406, ported #13 Heads, '70 iron intake without crossovers, Q-Jet - Cliff style, RARE OS manifolds, Pypes duals w/crossflow, UD 230/238 custom HR 4/7 swap cam with solid roller lifters , Hydro-Boost 4-wheel discs, 4 Speed, 3.23 posi.
“Nothing in life is so exhilarating as to be shot at without result.” - Winston Churchill
  #48
Old 09-09-2009, 08:37 PM
ponjohn's Avatar
ponjohn ponjohn is offline
I'd be willing, maybe over the winter to change cams as long as it doesn't require a pushrod change.
UD makes a HFT lobe that is nearly identical in specs to the xe 284. It would be very interesting to see the difference in idle and performance with nearly the same specs but a different mfr cam.
What are the best HFT lifters to buy, crowers with cool face?
  #49
Old 09-09-2009, 11:01 PM
mudbird's Avatar
mudbird mudbird is offline
Hey goat 2789 I remember that dyno day! I guess we are gonna be slow unless we change our cams?
FWIW I would prob pick a different cam next time. I kind of agree with Cliff.
I know people that like it but if you have a combo that can rev higher there are better choices out there.
MudBird
  #50
Old 09-10-2009, 11:42 AM
Skip Fix's Avatar
My pump gas motor has an UD 296/304 239/247 @ 0.050 in it on a 112 LS, has 12" at idle.
Skip Fix
  #51
Old 09-10-2009, 04:11 PM
Kenth's Avatar
Kenth Kenth is offline
Sounds healthy!
12" at what rpm, how much initial timing, carburetor idle circuit spec´s, in or out of gear if A/T converter stall speed?
  #52
Old 09-10-2009, 04:17 PM
Skip Fix's Avatar
12" out of gear auto@ 900rpm, fairly tight "Jim Hand" convertor. Does drop some in gear to 10-11" so the convertor is tight. Stock Holley 850 DP idle circuit. Around a 12.8-13.2 AFR at idle.
Skip Fix
  #53
Old 09-10-2009, 04:47 PM
Murf'sDad's Avatar
The AFR sounds a little rich at idle. Do you get any sign of it being a little fat at idle or off idle? Just curious.
Stewart
  #54
Old 09-10-2009, 05:34 PM
Skip Fix's Avatar
Murf if I idle it lower on the AFR a slow off idle (like a stop sign in the neighborhood with neighbors watching) has a bad bog as it needs it in the transfer slots. Not enough throttle to blast the accelerator pump shot, and squirters did not fix it. Then it was going into the 16s with that tight convertor! Remember idle circuits generally impact the carb well into the main circuits, maybe even up to 3000 depending on the set up.
Skip Fix
  #55
Old 09-10-2009, 07:42 PM
Murf'sDad's Avatar
OK, so you need the "slightly" rich idle to keep everything in order. That's cool. Maybe you should get a Q-Jet.
Stewart
  #56
Old 09-10-2009, 08:53 PM
ponjohn's Avatar
Skip-
Is that a 10.99 N/A, if not what does it run off the spray?
John
  #57
Old 09-11-2009, 05:03 AM
chris everitt's Avatar
chris everitt chris everitt is offline
Default thank you for this info. I choose Crower.
help with choosing the right Crower FT hyd camshaft for a 406. Your assistance is much appreciated. I was previously considering the XE274. Is the Crower 112 lsa 60916 a good choice for my application?
I'm building a weekend street car and I hope it will run 12's. I want it to idle like a hot rod and be able to use power brakes & ac. hyd rollers are too costly for me. feel free to kick in
75 t/a, 3800#
3.23 posi, 255/60/15, 27" dia
350thm with 2000 stall
400(0.030), balanced, forged kb flat top pistons, forged steel rods, 9.5-1 scr
#16 small valve heads, hard exh seats, studs, big valves, mild port work, port matched, performer intake, Qjet, stock push rods & rocker arms, inc. pressure springs
1&5/8" headers, 3" collectors, 2.5" dual exh w/ Xover, flowmaster series 40 2.5" mufflers
heavy duty RR leaf spring, neoprene pinion snubber
at track: slicks, open exh, no sway bar, no ac!
  #58
Old 09-16-2009, 01:37 PM
old66tiger's Avatar
old66tiger old66tiger is offline
Goat2789, my car made almost identical power and torque with that cam. I believe the results. The XE274 in my car made 326 hp and 439 torque at the rear wheels. Correcting for drive train losses, that equates to about 400 crank hp and 500 crank torque.
Skinned knuckles and empty wallet! Could I be any happier?
66 GTO Convertible. LS3-525 HP. Legend LGT700 5-speed, Wilwood 4-wheel disc brakes, Ridetech coil over front susp, PMT rear susp, Hotchkis bars, Billet Specialties 18" Dagger's (18X9 rear, 18X8 front).
2002 Ram Air WS.6 convertible Trans Am. Wife's car.
