| Pontiac - Boost Turbo, supercharged, Nitrous, EFI & other Power Adders discussed here. |
#41
9.01 @161mph on a soft 18 psi tune, twin turbo blow through carbs setup/factory '59 block/factory iron heads,in a 2800lb full steel street car, will run 8.40's once I've got the turbos to spool earlier so that I can launch with some boost,60 ft is a piss poor 1.85 at the mo. Will be upped to 25 psi when I 've maxed out this tune up, should run 7.90's@170mph
| The Following User Says Thank You to taff2 For This Useful Post: | ||
#42
See sig.
#43
Havent posted for a while but here is my latest best passes. best ET and best MPH, best ET was 12 psi, best MPH was 14PSI, still a stick, 4130lbs
1965 GTO hard top, Black with a red interior built to drive and Race best so far 1.45 60’ 8.77@164mph . 6 Speed manual transmission. MS3pro Fuel injection Multiport , 517cubes 10 to 1, 3.50 gears, CNC E-heads wideport 350CFM by Dave B. 4025lbs with driver!!94mm turbo. Winner of the Hot Rod Dragweek stick shoot out 2017! |
#44
Nice passes!
Do you leave at an idle? Those 60 foot's are about .4 second slow? Impressive MPH in 1/4 though.
John Wallace - johnta1 Pontiac Power RULES !!! www.wallaceracing.com Winner of Top Class at Pontiac Nationals, 2004 Cordova Winner of Quick 16 At Ames 2004 Pontiac Tripower Nats KRE's MR-1 - 1st 5 second Pontiac block ever! W.E.C moment "Every man has a right to his own opinion, but no man has a right to be wrong in his facts." "People demand freedom of speech to make up for the freedom of thought which they avoid." – Socrates |
#45
Being a stick I am leaving at 5000rpm, but I am still struggling to find the right clutch combination, Black Magic is going to build me a slipper that hopefully will do the trick, but 4130lbs is a challenge.
I will be happy with a low 1.4 60' that should get me a 8 second pass, still driving to the track and home (usually!) lol. I also am running on waste gates in 1st gear then ramping boost in second gear. Hopefully 8's next year!
#46
505 street car pump gas 11.5 compression spray 350 shot car is 3290 dot tire 8.90@ 154 converter way way to tight 8.50 with new converter..
https://www.youtube.com/watch?v=xLrufdeg2Uc |
#47
#48
Great pass and fun video!
Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft) 7.75 @ 178 pass: https://www.youtube.com/watch?v=Iez3...ature=youtu.be First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be Thanks to Paul Carter @ Koerner Racing Engines |
#49
All Pontiac 535cid, DCI-RAV heads, Twin 88mm, C16 fuel.
YouTube Channel. https://www.youtube.com/channel/UC21...TRqShGQ/videos
![]() 2023 Best ET Slip 60’ 1.224 330 3.186 1/8 4.784 MPH 152.07 1000 6.175 ET 7.347 MPH 189.92 Weight 3650 YouTube Channel --> https://www.youtube.com/channel/UC21...rWwgFdfTRqShGQ FaceBook Group --> https://www.facebook.com/groups/220092308823847/ |
