Old 04-05-2010, 09:07 AM
Firedup6975's Avatar
Thanks everyone I'm sure this one will be as much fun if not more fun than all the others, something I've been looking forward too since I was 13 years old. I'm counting on you guys and or Gals to help me along on this one. As Miranda said, it will be awhile until actual tear down starts, but I will start collecting parts now.
~MaryAnn~ AKA "Stickybuns"
1969 Firebird 400 Convertible
1978 Bandit T/A Tribute
1977 RED TA
I'm the FiredUp PY bad girl
  #42
Old 04-05-2010, 09:11 AM
Originally Posted by marxjunk View Post
Heres pics, you can see its on the right/pass front side, it has all the info, like gear set code, date code..and that lillte E means Eaton Posi..do some research...a factory 4.10 code BE rear can go for 5 grand PLUS..mabe more its a COPO code
this one is BR which wad originally a 3.08 posi
Don't see anything on those pics lol. Guess we'll check that out once we get under there. Thank you for helping me understand the codes, because I'm clueless where those numbers are concerned.
1977 RED TA
  #43
Old 04-05-2010, 10:02 AM
Rob B's Avatar
Rob B Rob B is offline
Glad to see you finally got your car!
As for the so-called issue with the rear end, Keep the 12 bolt. If it has 4:10's, no big deal. It either means you have the good series carrier or some one used the fatter ring gear to make the 4:10 work (hopefully not a spacer). It can easily be changed to something more desirable for your driving styles for minimal cost. As you already know, if you need help or if there is anything I can help you with, just let me know, you've got the number. I also can get access to a true 69 TA thru a couple of the guys in Batesville. One of their buddies has one but unlike others, he's a crazy SOB and will drive it almost anywhere, anytime.
74 GTO Bracket/Street car and another 74 for the wifey to race with!
70 GTO 400, 4 spd, #'s matching and a little to nice for me to own.
Friendship is like peeing your pants..everyone can see it but only you can feel the warmth!
  #44
Old 04-05-2010, 10:20 AM
Thank you Rob! yeah I know a lot about cars, (not everything,) lol, but nothing about rears in cars, Wouldn't know a common rear from a better more valuable rear, and how to know the difference or what to look for, but as always I'm excited to learn as much as I can, as I plan on having as much hands on time on this project as all the others I have worked on. As I get into this project I'll post in the appropriate forum in the tech areas.
1977 RED TA
  #45
Old 04-05-2010, 12:21 PM
marxjunk marxjunk is offline
I can see it on my screen...oh well, ya get the idea..when you get the numbers off yours, i have a guide to break it down..
If its run of the mill, id use it, if its something exttremely rare..well...id sell it and take the money and put it back in the car...they made alot of non-posi 12 bolts....only a few 100 really cool ones...
  #46
Old 04-05-2010, 03:53 PM
71 T/A 71 T/A is offline
Agreed, but you'll have to factor in the cost a new posi and gears if you go with another rear and compare that to what you could get for the one you have.
  #47
Old 04-05-2010, 05:07 PM
It's definately a Posi, dug in pretty good when the guy got on it going up on the trailer.
1977 RED TA
  #48
Old 04-05-2010, 06:50 PM
428PHIL's Avatar
428PHIL 428PHIL is offline
Talking
MaryAnn
Since your doing a clone leaving the rear a 12 bolt is no big deal, leave it alone, your going to have a lot more issues $$$$$ than worring about it. Good luck and am sure you will do a great job in your quest.
  #49
Old 04-05-2010, 08:57 PM
FireBrdRestorer's Avatar
FireBrdRestorer FireBrdRestorer is offline
Can't get to the inside of the right tube without jacking it up, maybe this week I can get to it but here's some casting numbers I was able to see. Do these tell anything?
Mike G. (or MaryAnns Boss)
I don't have my own Pontiac yet, but sometimes she lets me drive hers.
  #50
Old 04-05-2010, 09:19 PM
theYman's Avatar
theYman theYman is offline
Congrats on your car find. It's kind of ironic though. I sold my TA clone and you found your car to build a TA clone. Good luck and have fun with the build.
Trent
The thick CLOUD of tire smoke ,the SMELL of burning rubber,and the CHEER of the crowd ....PRICELESS.
$90.00 fine for an awesome burn-out,worth every penny...
http://www.youtube.com/watch?v=iI7beXh7xW8
  #51
Old 04-05-2010, 09:32 PM
Those numbers are on my 69 rear, ..if ya look its the numbers 1 thru 9 and 0 probably an internal thing with the foundry that cast the center section
on the front side on the bottom web is another set it is the actual cast number and is shared with 67-69 67 is mono leafs 68-69 are multi its an easy way to tell..heres pics
that code on the front side tells ya date, gear,and which posi if originally equipped
  #52
Old 04-06-2010, 08:51 PM
Another pic of the numbers and letters on the front of the passengers side. looks to be a Dana, don't know how to Decode the other numbers and letters. Not sure what the circle with the line through it indicates.
  #53
Old 04-06-2010, 10:19 PM
Pontiaddict1's Avatar
Pontiaddict1 Pontiaddict1 is offline
ok here goes
cos=3.07
05 =may
12=12
G=Detroit Gear and Axle
1=Day Shift
the D apparently does indicate Dana Posi
info from three different sites but the best source was here:
http://www.rustynutscarclub.com/camaroaxlecodes.htm
*the O with slash is an O an not a zero
1969 GTO Judge;
1972 LeMans Sport GT Convertible
  #54
Old 04-06-2010, 10:36 PM
D280
the casting is April 28 1970
1969 GTO Judge;
  #55
Old 04-07-2010, 09:10 AM
PMDJIM's Avatar
PMDJIM PMDJIM is offline
Now the fun starts. I guess your going to carlisle at the end of the month. Maybe bump into you there. If not, see you at GM on Display. Do i get a ride when it's done? lol
1966 Catalina Station Wagon
1986 Fiero GT
1949 1st series Chrysler Traveler
1995 Formula Firehawk #592
  #56
Old 04-07-2010, 09:28 AM
Thanks Ron!
And Jim yes you get a ride in it when it's done You have no idea how happy this find has made me it's exactly what I needed to get out of the winter blues rut I've been in for months. Thanks again! Pontiac people helping Pontiac people is what this hobby is all about.
nah not ready for a trip to Carlisle yet, but am planning on GM on display at the end of the month.
1977 RED TA
  #57
Old 04-07-2010, 09:30 AM
[QUOTE=Pontiaddict1;3957222]ok here goes
cos=3.07
05 =may
12=12
1=Day Shift
*the O with slash is an O an not a zero[/QUOTE]
thought it might be a Q
1977 RED TA
  #58
Old 04-07-2010, 09:44 AM
Gotta love a woman who likes old Pontiacs. It was that hard to find a 69 Firebird?
  #59
Old 04-07-2010, 11:02 AM
I am VERY particular!!!! in my choices. There are a lot of 69 Birds out there, but I wanted one reasonably close to home so I could personally check it out, one that is restorable and not a rotted out barely a suitable parts car, one that had a clean clear title, and one reasonably priced. Everyone said such a car doesn't exist you need to expand your horizons. A two year wait, and a member on this board found me "THE" Car in this Car. Asking price was $6500.00, turns out I graduated HS with the guys Wife, he wanted the slotted Mags and Tires, I didn't care, I wanted this Car as my Donor Car. 10 minutes from my house, and some small talk, he was impressed how much Mike and I are into this Hobby together, as well how much I quizzed him about things, he thought it was cool I carry my love of first gen Birds on my ankle with a Tattoo of the emblem, sold me the car for $3500.00.
Let the FUN begin!!
1977 RED TA
  #60
Old 04-07-2010, 02:56 PM
79bluebird's Avatar
79bluebird 79bluebird is offline
well maryann you got a good car to start with.
you call yourself HARDCORE but are you truely hardcore
