Old 11-07-2010, 10:27 AM
mysticmissle's Avatar
looks awesome Dil
Old 11-07-2010, 07:32 PM
marks73ta's Avatar
marks73ta marks73ta is offline
Dil just caught your build. I love it. Is this to be a street, street/strip or a strip car? Either way I love it. MArk L
My Gasser '63 Catalina build. Oh sorry, it's a Street freak. Either way it's a fun build.
Old 11-07-2010, 08:06 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
I always liked white headers, it was just a pain to keep them clean and not have the paint burn off. Wonder if there are any flat white high heat ceramic coating liek Jet Hot has. I know one of the local coaters has a satin black a friend has used.
Skip Fix
Old 11-07-2010, 08:15 PM
wd45gto's Avatar
wd45gto wd45gto is offline
looking great !!!!
this is the same kind of project i want to do with my wagon someday
64 tempest wagon 421 gasser
Old 11-07-2010, 08:16 PM
SupergasDil's Avatar
Hi Skip,
A coating like that would be nice but the budget only allows for white paint at this point.
Mark, I'm building this so I can take it to a cruise night or car show, and also to where I can go rounds without a lot of maintenance at the track to get my groove on. Somewhere in the 10's would be fine with me.
Old 11-07-2010, 08:21 PM
mechanickeith's Avatar
Cool build Dill!!! I hate to break the news to you but that spot on the back of your head,,,,,It was there long before the welding sparks got to it!!!!!!
Keith Collier
61-63 Pontiac Tempest
Tech advisor
POCI.org
Old 11-07-2010, 09:58 PM
Thanks Keith
I could always use my Dads line and say, "That's not a bald spot, it's a solar panel for a sex machine"
Old 11-07-2010, 11:06 PM
I allways help in any way I can!!!!
Keith Collier
Tech advisor
POCI.org
Old 11-07-2010, 11:18 PM
quick66's Avatar
quick66 quick66 is offline
Looks like your getting a lot done!...Love the headers..keep up the good work!!thanks for posting the pics..Gene
'66 GTO 3600lbs w/driver, e-heads,474 N/A . best 60' 1.305...best 1/8th ...6.205 @ 110.14...best 1/4 9.794 @ 136.15 through mufflers on e-85
Old 11-08-2010, 01:01 AM
GOAT490's Avatar
GOAT490 GOAT490 is offline
Thumbs up I LOVE fenderwell headers!!!!!!!
Great Build! Thanks for sharing the progress.
PHILLYGOAT
PHILLYGOAT
1965 GTO/ OEM Block, Crank & D-ports(all slightly modified of course)/
3550lbs/ Full Exhaust/ Foot Braking
1.41 60ft [email protected] [email protected](Pontiac Heaven)
More Details on GOAT http://www.pontiaczone.com/forum/vbpicgallery.php?do=view&g=379
GTO Burnout http://www.youtube.com/watch?v=nZqdcH0Ltc4
Old 11-21-2010, 05:47 PM
Some work of the steering in progress
ID:	225411   Click image for larger version
ID:	225412   Click image for larger version
Old 11-21-2010, 05:48 PM
Welding in a bolt support for the manual steering box
ID:	225415   Click image for larger version
Old 11-21-2010, 05:50 PM
Rear American Torque Thrusts and Hurst cheater slicks
Old 11-21-2010, 05:59 PM
Brian Baker's Avatar
Hurst? Tell me more, are these repops or NOS?
Old 11-22-2010, 04:19 PM
SD421's Avatar
SD421 SD421 is offline
Dil, Sweet project!!!! What size wheels and what are the slicks capped on? Im kinda going for the same look with my 66 goat but Im going to be running steel black wheels instead.
-sd421
1966 GTO
1966 421-10.1-1 comp-Race Tec 23cc Pistons
KRE Tri-Power
KRE 65cc Aluminum Heads
XE274 cam by Comp Cams
DUR 230 Int 236 Exh @.050 - 110 LSA
LIFT .491" Int .491" Exh
Tri-Y-Headers by Tribal Tubes w/ Goerlich Mufflers
1966 Muncie Wide Ratio 4-Speed
1968-72 Chevy 12 Bolt Rear End w/ 3.73 rear gears
Old 11-21-2010, 05:52 PM
The engine is getting a little taller
Old 11-21-2010, 06:19 PM
Nice Dil! Back in the late 60's one of my neighbors was puttin straight axles under all kinds ofcars. Then got into seeing how high he could get his falcon jacked up. Also learned a few lessons on center of gravity in the process. Think he went as high as 5 ft frame to ground and rigged a rope for gettin in out. Funniest car was a 62 Rambler American with a 327 and gasser look. Big INDY car tires stuck out the side of cut out rear wheelwells. Execution rather crude compared to the nice work you are doing.
FWIW Rustoleum ultra high temp ceramic silver has been flawless near 6 years now on the headers in my wifes 69 bird. one stain from something got kicked up from the road and melted on. I just sanded off and touched up. Hope your white holds as well but if not I'll vouch for the silver being ok.
Old 11-21-2010, 06:42 PM
thadeal4real thadeal4real is offline
Thumbs up LOOKN GOOD
man thats cool stuff
"The democracy will cease to exist
when you take away from those who are willing to work
and give to those who would not."
Thomas Jefferson
Old 11-21-2010, 07:07 PM
The car really looks great so far, I can't wait to see it finished.
Nice work as always.
Bart
Old 11-21-2010, 07:23 PM
looks great Dil
