Old 12-26-2018, 10:25 PM
beemergary's Avatar
Well im on it.Going to be 30-45 days before I know much.Tom
Having a 63 Tempest 421 with 980 heads and a 61 tempest wagon with 127 heads a Bathtub intake is on my bucket list.
  #42
Old 12-26-2018, 10:35 PM
tom s tom s is offline
Gary,I for sure wont do a early version.Go shopping for new heads!Tom
  #43
Old 12-26-2018, 11:23 PM
brut4s's Avatar
brut4s brut4s is offline
I'm in also. Street/ strip
  #44
Old 12-27-2018, 10:39 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
This guy is making some cool 409 intakes and heads especially his Z12 stuff. Might be a source to check with.
https://www.mcquilleneng.com/
Skip Fix
  #45
Old 12-27-2018, 11:05 AM
Keith Seymore's Avatar
Keith Seymore Keith Seymore is online now
Quick story -
I just noticed the other intake in the background of this photo.
When I grabbed the bathtub from under Dad's workbench it was sitting on a piece of plywood. That low rise 2X4 intake was under the plywood.
I didn't even know we had it.
K
Name:	61 62 Intake.JPG
'63 LeMans Convertible
'63 Grand Prix
  #46
Old 12-27-2018, 11:08 AM
Sounds more like a "bathtub list".
'63 Grand Prix
  #47
Old 12-27-2018, 04:35 PM
Tinindianworkshop's Avatar
Tinindianworkshop Tinindianworkshop is offline
I THINK IT SHOULD BE DONE
  #48
Old 12-27-2018, 10:24 PM
beemergary's Avatar
Having a 63 tempest 421 with 980 heads and a 61 wagon with 127 heads a bathtub intake is at the top of my bucket list.
  #49
Old 12-27-2018, 10:45 PM
Gary,have had the bathtub on my 980s for 22 years now!Tom
  #50
Old 12-28-2018, 04:33 PM
ANDYA ANDYA is offline
Tom, have you been running this manifold with air cleaners and does it all fit under a stock hood? I'd be interested in a bathtub for street/strip but I don't want to cut a hole in my hood.
  #51
Old 12-28-2018, 07:26 PM
I have it under a 63 tempest with velocity stacks with screens.I ran it under a 63 Cat with the SD type AC.Not sure it would fit the tempest with real air cleaners without the SD scoop.The factory actually made a few lower intakes just for the SD tempests.Tom
  #52
Old 12-28-2018, 08:21 PM
Yeah, I figured it would be a tight squeeze under stock hoods. I have a 65 GTO in mind, but I don't think you can fit a bathtub with air cleaners. Maybe not even without air cleaners. Would love to run one in a 63 Tempest with a SD scoop though.
  #53
Old 12-28-2018, 08:37 PM
I will drop the car on the lift sunday and will see if I can get a number from the center of the valley pan to the tops of the AFB with no AC.I do have 1/2 in spacers under the carbs.Tom
  #54
Old 12-28-2018, 09:13 PM
It will fit under a '65 GTO hood, look here to see how it fit on my '64 GTO:
http://forums.maxperformanceinc.com/...8&postcount=33
With careful work a low profile air cleaner can be fabricated, carb spacers must be limited to perhaps nothing more than thick insulating gaskets.
  #55
Old 12-28-2018, 11:07 PM
Link fixed, can now view hood to carb clearance pics.
  #56
Old 12-28-2018, 11:28 PM
Thanks B-man. Looks like its gonna fit OK. I would be interested in one for the 65 and up heads.
  #57
Old 12-29-2018, 12:02 AM
I'm hoping this thread does not disappear if I can somehow get this done.WONT be cheap,if anyone is thinking under $2000 I don't think it can happen.Just too small of run to get molds,get cast and get machined.Been told a small issue just like the factory is core shift,don't always get 100 percent machinable castings and you have 2 PC to get machined.Tom
  #58
Old 12-29-2018, 12:27 AM
Mike Davis's Avatar
Tom, do you remember if the Repop intakes had any additional material/height added to area above the port for taller ported heads or if it was like the factory bathtub?
65 GTO, Tiger Gold, Nostalgia Super Stock 421, 2-Carter AFB carbs, Stock Suspension, 3550lbs Full Exhaust-- 9.70's@135
66 GTO (Retired race car)
421 CID
66 GTO 389 3x2, 4 speed, 3.90 gear, Montero Red 33K original Miles
  #59
Old 12-29-2018, 11:03 AM
Mike,don't think so,maybe Joe will see this and jump in.Tom
  #60
Old 12-29-2018, 10:24 PM
ta-69's Avatar
ta-69 ta-69 is offline
I would be interested in 1
