Old 04-06-2011, 02:44 PM
grandville455's Avatar
grandville455 grandville455 is offline
I tried a 1/2 nut last night was too big, 7 /16 ?
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,[email protected]@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected]
M/T 275/60 ET SS Drag Radial
2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's
Old 04-06-2011, 10:53 PM
6D6GOAT's Avatar
6D6GOAT 6D6GOAT is offline
I think we are talking about different things. im using a 1/2 bolt for my custom mount seen in the pic..
Vic in SoCal. Follow me on Instagram- Cloud9orbust
66 GTO clone, 467 cubic inches of Turbocharged Multiport Fuel Injected fury twisting a TH400 into 3.90's wrapped in a 12 bolt posi.
My T56 Install
My Turbo Build
My Vortech Supercharger Build
Hyd Throw out bearing
Misc Build Pics
May the Karma Gods meet you half way....
Old 04-12-2011, 07:29 PM
chiphead's Avatar
chiphead chiphead is offline
Like this??
I welded a 5/16" bolt to the underside of the tab. Without the bolt, I dont see how the tab does anything?
More importantly, will this work?
ID:	240988   Click image for larger version
ID:	240991   Click image for larger version
Old 04-12-2011, 07:35 PM
antique69lemans antique69lemans is offline
Originally Posted by chiphead View Post
Like this??
I don't think the tab does anything, unless the rubber fails. Then it is a safety.
Old 04-13-2011, 04:06 AM
lust4speed's Avatar
Couple of thoughts. For the dragstrip, I would prefer the turnbuckle because of its ability to prevent engine movement - the less stuff squirming around, the better. On the street, I would go with the chain (or preferably cable) and maintain about a 1/4" slack to prevent transmission of engine vibration to the frame, to the steering shaft, and finally to the steering wheel. This will allow the engine mount to do its job of isolating vibration, and also put a specific limit on engine lift. Only time you want the chain tight is under acceleration. If I felt any vibration at idle or normal cruise, then I would add just a bit more slack.
Mick Batson
