Know, You'd never know there was a track on the old LACR site
The tire you choose to use out back is a big factor on how "streetable" it's going to be...
No biggie here with small 275 hoosiers, 35 spline spool and anti-roll bar... |
i have a spool in my 'bird.i drove it alot on the street and never had any of the negative experiences i expected. the thing i noticed was at low speed going around corners. its all in what you can put up with while driving.
Spools are ok but you have to remember you have a spool -dont take chances you normally might and be extra careful in adverse conditions. When you can afford the upgrade though, I highly reccomend the wavetrac. I have one in my current WS6 and in my old 98 T/A and it never let me down except for one small problem with an axle and Moser took care of it better than I could have imagined. They really stood behind the lifetime warrany without question.
2002 Trans Am WS6 - Sunset Orange Metallic Stock GM motor with a cam and intake - 10.95 at 122mph w/1.47 sixty 2011 Super Chevy Maple Grove True Street 12.00 Winner 2011 Tri Power Pontiac Nationals Chief Of The Pontiacs 2011 LSX Shootout True Street Challenge 12.00 Winner 2006 CLK55 AMG & 2005 ML500 1989 GTA & 1989 TTA |
x2 on the wavetrac...TTA850 congrats on your win at norwalk
Not a spool, but I installed a locker in a 4wd pickup that was 95% street driven. Worst "improvement" I ever made. Caused me to spin out and wreck when it was raining (going around a curve). Not cheap to fix all the damage to the truck and the car I hit. Thousands, in fact. But I saved $400 by not buying an upscale limited slip unit!!! A spool would be even worse than the locker. WAY worse. No thanks. Go with a good quality limited slip unit and keep your car rubber side down!!!
Jeff |
I have a truetrac in the rear of a stick shift 4x4 truck and it is great. That application is a 4.3 v6 though, so no real power being put through it.
I think a lot of the horror stories about the truetrac relate to the earlier version, I can't recall the specifics but they were apparently strengthened considerably at some point. They used to not warranty the truetrac for anything over a 32" tire but now they go up to 38 or something along those lines. Anyway, you are right on doing your research, all I can really say is that I've had good luck w/the truetrac in my particular application. Different application but I'll see how the truetrac holds up for street use behind a 505/muncie combo very soon, but I think the weak link in that combo (my gto) is the trans, not the truetrac (strange 60). And yes - having a 6 cylinder truck and a 505 in your car is a perfectly reasonable way to allocate your resources. |
Hey Guy.....great to see you again.
![]() Due to the current economic conditions...the light at the end of the tunnel has been turned off. Meet you at the finish line.....don't be late! |
Thanks Ron. Its good to be driving the Pumpkin again too! I know its been a long time...how have you been. Did you buy B.T.'s '65?
