FirebirdMI thanks for your work and time on this. I know we all are going to get alot of it. I really hope it works for you. I have been rediculously patient. I am getting the bug again. I dont want to spend 4k on wheels and tires if I think I can get a Rally II look to work.
Heres my current stance and look: http://transams.net/MariosCollection...rd_400.html#16 Heres the stance I and look I want. I would much rather have a Rally II wheel do it than aftermarket wheels. http://i168.photobucket.com/albums/u...p/DSC_0125.jpg
TransAM Depot The Judge GTO Coupe prototype, DUCATI ST4s DP, Buick Turbo T WE4 not stock. Last edited by mario65; 03-09-2012 at 08:41 AM. |
Mounted the tires/wheels and I've attached pictures (I have more but only attached those that would be the most help). Car has been lowered 2" all around.
As I feared, the fronts have a little low rider look to them. If I had a choice I would want the front to be an 8" wide rim with a 4.5" back space. I think the exisiting tire would be perfect for that rim size and the sidewall would be square as opposed to tilted in. They do not hit the fender (about .25 clearance) when the wheel is turned. The rears are nice and will not rub on the quarters if I bottom out the suspension. I could fit a 275/40 out back but the tire would most likely be flush with the quarter panel lip (see pic) and would rub if the suspension bottomed out. Also, in a hard turn at speed the inside sidewall would most likely rub the stock wheel wells. I will need to clearance the steering knuckle on the driver's side before I take her out to account for flex and suspension movement. I also took pictures of the front fitted with the rears for reference. Hope this helps others make choices for their wheel/tire combo. |
More pictures
Those are absolutely beautiful on that car. Nice work. Thanks for the documentation as well. I have to admit that while Im searching for a wheel/tire combo right now, Ive learned a thing or two based on your posts.
Dude that looks great. Much better than I thought. I don't see anything low rider at all but then I'm Hispanic. I really like what happened to the car.
So are you going to keep them? Send them back? Forget the pics I saw what I needed. I think I might make it work on mine with 275/40/17 on the back and 255/40/17 on the front. Man I like that car a lot now.
TransAM Depot The Judge GTO Coupe prototype, DUCATI ST4s DP, Buick Turbo T WE4 not stock. |
I brought myself to call YO this morning and actually got someone on the phone that was very helpful and aware of the rims and the 69 bird.
He said they mounted 255/40/17 on the 9's and they fit fine. He said they got a pair of 8's in and they mounted them on 245/45/17's and thats whats on it now. So clearly the 8's are in production because 2 are currently on the 69. He said the part has been ordered from the oversees manufacturer and they could be in the next month or 2. The part # for the 8's is PRW178GUN. He said the 8's would be 4.5" backspace. He told me the 67-68 would be a very tight fit with 9's but would work if it wasnt lowered.
Did they happen to say if other sizes would be available? Like 17x10 ?
What would be the advantage of 10's?
Paul FAST Automotive -The Pontiac restoration shop, not the fuel injection guys! I had the name first. My site... needs updated- www.fastrestorations.com 68 GTO's (RA II, RA I, HO, convert, Pro Street, Racecar, etc.), 2 69 GTO Judges, 70 GTO racecar -10.77 @ 124mph, 68 Tempest survivor, 3 03 Aztecs! |
Mario65, thanks for the info on the upcoming release of the 8" wide. I spoke with them today and they are expecting 4-8 months on delivery of the 8" wide with 4.5" backspace. The first lot had a small issue so they were rejected and the manufacturer is making a tooling fix.
I'll be first in line for 'em and then I'll have (2) 9" wide rims available for sale. I think the 235/45 tire should be just right on the smaller rim size so I'm keeping the tires. DevoBuzz, I forgot to ask about any additional sizes. |
By the way the best price on KDW's I could find were here:
discountedwheelwarehouse.com They were 585.00 plus ship
315/35/17 - if it's possible to fit under the sheet metal!
Love the 3/4 front view of the car. Shows off the deep dish of the wheels. Love them !!
Send it! It’s going home on a trailer. |
Thanks for the compliments.
For now, to fix the tie rod end hitting the wheel on the drivers side, I shimmed the steering arm out by 0.25" and reset the toe. I took it for a drive this weekend and the wheels were balanced well. No shaking all the way to 90. I like the firmer ride with the lower profile tires and there is no rubbing even when I hit bumps at speed. Once the 8" wide rims come in I'll switch over and take the shims out from under the steering arm. |
IMO 17x8x4.5 and 18x10x5.5 would be ideal if they would make them for the 68 and later A bodies
That way you could use 245x45x17 and maybe even 255x45x17 front and 285x45x18 in the rear for a 27" height I have 285x40x17 (26") on 17x10x5.5 and would like another inch back there.
Curt '69 GTO Ragtop, 455, RA, KRE SD Perf ported heads and "old Faithful" cam, Sean Murphy Q-Jet, Tremec 5spd, Moser Trutrac 3:73, Hotchkiss, Speedtech, Wilwood ![]() '64 Lemans Convertible, Tremec TKO600 |
As for tire sidewall height (diameter), I agree 26-27" dia is ideal. A 255/45R17 is 26.1" dia and is easy to come by and will fit even an early A-body, as I have on my '66 GTO as below. Here are Firestone Wide Ovals in that size: http://www.tirerack.com/tires/tires....omCompare1=yes Click on Specs to see the sizes.
These wheels are ROH ZR6's, which were the prototypes for the Impala SS. I used '69 Bonneville hubcap centers which fit perfectly in the ROH centercaps. Brakes are 13" Corvette C5 front and 4th gen F-body rear (same calipers as the C5 except they are a bolt-on to our rear axles). Wheels are 17x8.5 reverse-mount, which is what the YO Rally II's are, and caliper clearance is very tight.
Tod Hoffmann 1966 GTO Montero Red Hardtop - Holley EFI'd 462, KRE DPorts/Muncie 4spd 1990 Chevy 454SS pickup - Accel DFI/T56 6spd - Hot Rod Power Tour Long Hauler 1996 Chevy K2500 ECSB 'Poopy' 2002 Honda VTX1800C 2016 Cadillac CTS Premium My project thread: http://forums.maxperformanceinc.com/...d.php?t=516826 |
I called them yesterday and still no news on the 8"
Did they give you any time frame for the 8"?
