Old 07-15-2012, 08:37 AM
73 TRANSAM 73 TRANSAM is offline
The factory tapped it for 3/8" pipe thread. Thanks for correcting it.
Old 12-24-2017, 04:00 PM
Mr_GTO's Avatar
Mr_GTO Mr_GTO is offline
I have a 64 303hp block. Can I install a stroker crank and use modern alum heads on it? Thanks.
Old 12-24-2017, 04:09 PM
tom s tom s is offline
yes,should be no issue.Tom
Old 12-25-2017, 12:45 AM
Bermuda Blue Bermuda Blue is offline
Thumbs up
If one were to use a 59 block how would the reverse flow cooling aspect of the block be dealt with? Would the block be converted to the more recent cooling design by modifying it to accept a modern timing cover? Or would reverse flow be retained since it is superior. I would think conversion, if possible, would make head selection and coolant component sourcing easier.
Old 12-25-2017, 03:37 AM
You could either install a later model Pontiac timing cover and water pump or install the aluminum front cover sold by RARE along with a high volume SBC “long” water pump.
Dr. Thomas Sowell
Old 12-25-2017, 08:57 AM
74Grandville 74Grandville is offline
Default 389 vs 400 as basis for stroker build
Going this direction, you’d need to block off the 2 holes in the front of the block with pipe plugs I’m guessing. You’d probably want to block off the oil gallery in the deck as well and go with push rod oiling.
1979 Firebird Trans Am 301/4spd (Now 428)
1977 Firebird Formula 400/Auto
2007 Grand Prix GXP 5.3L
Old 12-25-2017, 10:39 AM
When going to pushrod oiling you dont have to block the holes in the deck.Tom
Old 12-25-2017, 11:26 AM
The coolant transfer holes drilled in the 1959 block deck would need to be modified to match a 1960 or later block. This would require drilling holes and plugging holes.
