Old 08-12-2013, 08:47 PM
Originally Posted by Brewster View Post
It needs work like all cars (master cylinder, front right fender, radiator & hoses, cowl seal, trim, valance, trunk mat...)
If you're going to have the paint gun out anyway to do the right fender, why not remove the non-original rear appendage and fill/repaint while you're at it?
I really like the way this car was optioned. That's one of the cool things about Formulas, too - so many more combinations and permutations available.
I'm not as knowledgeable about '72s... were the Rally IIs part of the handling package?
cheers,
keith
  #42
Old 08-12-2013, 08:51 PM
Brewster's Avatar
Brewster Brewster is offline
The car sports over 100k miles so nothing will surprise me. Mike, can you help out on the decal or a file so I can make one? Also is the pan original or not and how does one tell for this year?
Is the Master cylinder suppose to have bleeders in 1972?
  #43
Old 08-12-2013, 08:52 PM
The Boss's Avatar
The Boss The Boss is offline
I've got at least one extra unitized ignition that would work with your dates if you need it.
And go racin' in the street.
  #44
The Boss's Avatar
Need to see the inside of the pan to tell the year.
  #45
Old 08-12-2013, 09:38 PM
Held for Ransom's Avatar
See post #30. I can't remember if they went back to the '71 style right before the shutdown or not.
Shhh ... the decal is in the works and should have been done by now, I just can't get verification.
  #46
Old 08-12-2013, 10:20 PM
Brewster's Avatar
Keith, If I do go for a complete paint job I most likely would fix that rear appendage. Just because I like the originality of an item not necessary because of a particular look. The spoiler actually looks great on this silver car.
See, My Dad bought a new Formula back in 75 at Penny Pontiac and it was silver with a spoiler. Maybe that is why this one looks so good to me?
Either way its staying for now.
  #47
Old 08-12-2013, 10:25 PM
Brewster's Avatar
Please, I'll pm you my personal info for future communications.
Thanks, Brew
  #48
Old 08-13-2013, 07:11 AM
The Boss's Avatar
I'll take a look for them later today Brian & let you know what I've got.
  #49
Old 08-13-2013, 07:12 AM
The Boss's Avatar
I know we've hashed it out before but I don't think we ever had conclusive evidence of the studs being used in 72 or not.
  #50
Old 08-13-2013, 08:49 AM
Brewster's Avatar
So its possible it is correct or should I start looking?
  #51
Old 08-13-2013, 09:34 AM
3tas4me's Avatar
3tas4me 3tas4me is offline
Is the Master cylinder suppose to have bleeders in 1972?[/QUOTE]
Nice car Brew! Yes on the bleeders from what I have seen.
1970 Trans Am
1971 Trans Am
1974 Trans Am
1978 Y88 Trans Am W72/auto
1979 10th Anniversary Trans Am
1984 Trans Am
1996 Trans Am WS6
1999 30th Anniversary Trans Am
2001 10th anniversary Firehawk #104
  #52
Old 08-13-2013, 11:59 AM
RicksGTO's Avatar
RicksGTO RicksGTO is offline
I wouldn't be surprised if your air cleaner just had one vacuum pod/bracket replaced over the years. My 12B built '72 Formula has the correct ram air cleaner that appears to be the original and both vacuum pod brackets have the studs. I believe they couldn't mount the support brackets to the engine in '72 due to the new position of the temp sender in the drivers side head so the studed cleaners were just remaining inventory. When I replaced both my vacuum pods, the replacement pods came with non-studed hold down brackets, so I reused my original studed brackets. If I remember mine correctly, the original hold on brackets for the vacuum pods will say Thermac AC in raised letters or something like that next to the stud and the replacements do not. Will look at mine and post a pic tonight if it will help.
'72 Formula 455HO TH400, Revere Silver, black deluxe
'74 Trans Am SD 4 speed, Admiralty Blue, blue deluxe
  #53
Old 08-13-2013, 02:42 PM
PB's Avatar
PB PB is offline
Brew, it does look like your pass side vac was replaced at some time, and the units looks like a factory original from the inside to me. I've reproduced the correct 455-HO sticker from an original, your is probably one of the first repop stickers. I've outlined the correct wire routing for 1972 HO engines on my web site. I also have an extra 72 thermal intake switch if you need one. I can rebuild your unitized ignition wires with new date coded wires too. Learned it from Steve's thread, if you don't want to tackle that yourself. I have a couple harnesses I can rebuild if you don't have any. Looking forward to more pics.
Pat Brown
The Following User Says Thank You to PB For This Useful Post:
  #54
Old 08-13-2013, 03:02 PM
Norwood's Avatar
Norwood Norwood is offline
Pat, Brew needs one of those GREAT shirts of your......
  #55
Old 08-13-2013, 05:08 PM
PB's Avatar
PB PB is offline
Yeah....I need to sell more of 'em! ..can't tell from the pics, but he may need your new 72 HO stove and elbow set up too!
Pat Brown
  #56
Old 08-13-2013, 05:15 PM
RamAir's Avatar
RamAir RamAir is offline
Pat, I'm down for a large shirt
  #57
Old 08-14-2013, 07:37 AM
Brewster's Avatar
Pat, will you be at the nats next weekend?
  #58
Old 08-14-2013, 10:06 PM
PB's Avatar
PB PB is offline
I would like to, but I won't be in attendance.
Pat Brown
  #59
Old 08-15-2013, 01:09 AM
2manyT/A'S's Avatar
Thanks for all the nice comments guys. The car is a big hit with the family including the wife that even took it out on her first solo run.
It needs work like all cars (master cylinder, front right fender, radiator & hoses, cowl seal, trim, valance, trunk mat...)but its major components are all there.
Car came out of Boomershine Pontiac out of Atlanta, Georgia. Not sure complete history less it ended up in Michigan, Illinois and now Wisconsin. Will be working on that!
Its performance is not 100% but still puts you back in the seat. The SD/HO thing is all about how dialed in any one given cars is. There all a hand full if running correctly and this one will be soon. Plan is to pull the drive train this winter for rebuild, fender, misc items and ready for fun summer 2014.
Not making a show car just a fun car that is as factory correct as I can make it.
There are allot of differences between 72-73 and will need help for a bit so please feel free to shark tank the ride. Been there done that.
Thanks again, Brew
VERY NICE!
You'll get used to the lighter,FASTER ride....before you know it.
Eye Candy......garage band?
Go full screen & turn it UP!
  #60
Old 08-15-2013, 12:41 PM
OVERULD's Avatar
OVERULD OVERULD is offline
Congrats Brian - car looks nice in that color combo! Gonna be hard to get used to seeing you in something other than Brewster Green. Once you've you had some HO, it's hard to go back!
BJ
