#41
That was from Ultra -Carbon.
Just got a text saying not to use them.
First Pontiac powered street car in the 7's 7.940@170.84. 3460#s |
#42
I say go for it jack it sounds likes there is more pros to it then cons
#43
This looks period-correct and doesn't require cutting a hole in the fender.
https://encrypted-tbn2.gstatic.com/i...G-CRe6-a5-Wulw JMHO, Eric
#44
with fender exits there is a problem getting the desired primary lengths and collector extensions. One ends up with something like this for an early bird.
#45
What is min weight for your combo in the class you run? You cant let that car stay at 3500 frickin pounds.
John Marcella Marcella Manifolds Inc. john@marcellamanifolds.net ph. 248-259-6696 |
#46
Like the Headers in Post #43 and would look cool on your car, Jack.
You have to build new stepped headers for your heads anyway, A good fab guy could knock them out for you no problem. You could still run removable exhaust pipes/mufflers to the rear for Beer Runs. 45 seconds to drop the exhaust with Marmon flanges and an air tool. Ask me how I know. Tom Vaught
#47
I got it down to 3400# last year.
#48
Posting these for Lil Jack...
East Coast Mafia TTFMF Making CVWHAT's great again. I guess it took a deplorable ECM member to do it! Quote:
Fastest Blow-thru Pontiac powered car in the Country 8.440@166.97 (3465lbs) Fastest Pontiac CV-1 car on the planet with only 6 passes on the combo: 4.80@147.65/ 7.49@180.12MPH (3365lbs) |
#49
Easy fix, 1 3/4 primary with a 110 deg angle. Some 3" collectors and you're done!
EHTTFMF! Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead. BEING STUPID WORKS THE SAME WAY! The rest of us suffer. |
The Following User Says Thank You to mike leech For This Useful Post: | ||
#50
looks like you don't have much of a choice! start plumbing pipe out the side!
#51
Whts the weight of those hunks of billet?
1969 carousel red firebird 455, richmond 5 speed 1964 540 gto 1971 lemans sport convertible 1972 Maverick under slow construction |
#52
Around 40# bare each. I think my E heads were 34# assembled.
#53
Looks like Ron is about to get creative, I'm sure they're going to look great and function great when they're done.
The Following User Says Thank You to cmpgto For This Useful Post: | ||
#54
Headers should be very close to a bbc abody right? I'm sure looking at some lemmons large tube chevelle headers should give some in sight
#55
Just go up with them and stick em out the hood like a mudbog truck.
#56
Ditto
ECM member. 2008 Outlaw Pontiac Drag Series Champion MANDRA Do it now fool! Life is short. 69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'. Going back to track with pump gas engine.... My 60 Ventura retired to street/strip duty.. |
#57
Please tell me you will get to the 3000 lbs this year, if not your crazy.
#58
gonna need glass fenders just to offset the extra weight of those heads!
man those are huge! look cool though lol
-Rob 67 LE MANS in pieces... 68 gto 84 grand prix twin turbo 496 pontiac 25.3 cage |
The Following User Says Thank You to lemans411 For This Useful Post: | ||
#59
IMO Street cars don't have fender exit headers. I'm sure your chassis guy can work it out and build you a conventional header.
James 1970 Trans Am Spotts Built 484" IA2, Highports, EFI Northwind Terminator X sequential EFI fabrication and suspension by https://www.funkhouserracecars.com/ |
#60
Maybe if I drive by remote control.
The Following User Says Thank You to LiL Jack For This Useful Post: | ||
