1982-92 TA & FB TECH 1993-2002 TA & FB Tech is now part of the new Late Model Section of the PY Forums. Click this link to check it out.
Old 12-10-2014, 11:06 AM
mrrat1 mrrat1 is offline
new principle & Biz Administer..........the school has basically turned into a prison camp. It's hard to just take parts over, I have to go thru security and its a PIA. Watching times of arrival and departure so I can't BS and play there anymore.
Its been up & running, the class was working to get the gauges working. A/C still needs mock up. Then I need to get the exhaust hooked up at a muffler shop.
  #42
Old 12-14-2014, 03:29 PM
TimothyJer TimothyJer is offline
Send a message via ICQ to TimothyJer Send a message via Skype™ to TimothyJer
I really like to appear on forums.performanceyears.com on an ongoing basis , a lot of messages in the topic . Thank you and ... continue
  #43
Old 12-18-2014, 04:08 PM
Alvin's Avatar
Alvin Alvin is offline
Better late than never to the party here. Excellent thread. Keep us posted w updates as you can.
  #44
Old 10-14-2016, 09:13 AM
Sorry about the lack of updates.......not much happened!!
Trans is out for rebuild, upgrading to 30 spline and HD hard parts.
455 will be getting assembled, and hope to get the sub frame & built 400 out in the next couple weeks. Paint up the engine bay.........
  #45
Old 10-14-2016, 11:46 PM
Trans is done........have to get the converted ordered.
About $1200 in the trans, labor for the rebuild included.
Gonna do a Moser 12 bolt conversion and maybe alum driveshaft. I have a brute strength carrier in my parts stash purchased used here a few years ago. Gonna have that gone thru and stay with the 3.73's!
  #46
Old 11-01-2016, 02:12 PM
Trans and converter is in. I went with a TCI Breakaway they say it stalls 1000 rpm over stock. Have to get a dipstick and new Speedo cable........coming along should be test driven next week!
  #47
Old 11-04-2016, 03:08 PM
unilite distributor stopped working so I took over a standard dist to get it running.
Should be up & running Monday or Tuesday. No exhaust yet so will just be going thru the gears on the lift to confirm all is good with the new trans.
  #48
Old 11-12-2016, 03:38 PM
Runs and shifts, finish up the exhaust next week. Get the front clip back on I hope next couple weeks and then get it out for a road test..........
  #49
Old 11-22-2016, 09:06 AM
TTOP350 TTOP350 is offline
Looking good!!!
http://www.fquick.com/garages/viewga...ewimg&id=74990
"You people have stood in my way long enough. I'm going to clown college."
-Homer Simpson
  #50
Old 12-16-2016, 03:48 PM
all up and running now! Exhaust is completed but not great welding (kids), A/C compressor mounted, took up the condenser today. Needs a radiator & oil & water temp sending units.
Fan hooked up to relay goes on at 200* off at 185*. Wipers, heater working no defrost yet maybe a vac line. Radio next week, tires and alignment next year!
Might have a hood clearance issue with alt & bracket.........we'll see.
Gonna do a 12 bolt swap when cash allows........
  #51
Old 01-05-2017, 05:45 PM
New Rad in, defrost solved, A/C charged and ice cold.......needs tires & alignment.
  #52
Old 01-25-2017, 05:47 PM
Almost all parts together for the 455 build.
Bored .030, Ported 6X heads, Comp Cams 244 @ 50 & .500 lift. Factory HO intake & carb set up. I'm using the factory offset scoop hood. It was functional so gonna try to work that out also.
Seems the cam might be too big for the combo. Gonna give it a shot see how it runs on the test stand and replace if needed.
  #53
Old 01-26-2017, 02:21 PM
ponyakr's Avatar
ponyakr ponyakr is offline
If this is a street car, that's probably not a good cam choice. I've got one in my 455/6x-8 bracket engine. IMO it's way too nasty to drive on the street. I wouldn't even attempt it. And I even have Rhoads lifters.
But hey, if you just want a thumper, that cam will do it. Probably won't make enuff vac for power brakes, even with Rhoads. An 041 clone/Rhoads will. And, yes, I have run this combo with power brakes. Idled smooth, brakes worked good, launched from an 800 rpm idle, with a stock converter. Not enuff cam for most on this forum. But, still a nice, mild mannered cam, for a DD 455. IMO
https://www.summitracing.com/parts/c...w/make/pontiac
  #54
Old 01-30-2017, 12:40 PM
Thanks for the heads up!! Cliff did say it was a nasty cam!
I was thinking of retarding the cam 6* to try to tame it down a little.
What do you think?
It's going to be broke in on a test stand so if it's really too wild I can change it out.
I'll maybe put in a vacuum can......I'm not gonna be driving the car all that much.
What did you run with it? How much horse do you think you made?
  #55
Old 01-30-2017, 01:53 PM
ponyakr's Avatar
I haven't taken it to the track yet. A similar engine ran 7.30's at our local 1/8 mile track. So, this car will also run in the lower half of the 7 sec bracket. I assume that will = the upper half of the 11 sec zone, on a 1/4 mile track, as a footbraker. Or, you could obviously make it a little quicker, if you wanted to.
I would estimate the hp at 425, and the torque at just over 500ft lbs.
"...I was thinking of retarding the cam 6* to try to tame it down a little.
What do you think?
I'll maybe put in a vacuum can..."
I would not waste any time or $$ trying to use that cam for a street driven car.
  #56
Old 02-16-2017, 06:37 PM
Almost done putting the engine together! It should be going on the test stand next week!!
  #57
Old 02-23-2017, 06:10 PM
All built and on the test stand. Just waiting for valve covers!
Will be making noise next Monday or Tuesday.......hopefully just good noise!!
  #58
Old 02-28-2017, 04:26 PM
Breaking in the cam today!!
  #59
Old 03-01-2017, 01:40 PM
All broke in........and it's sounding pretty wicked. Idles pretty smooth at 750 on the stand. Will no doubt have to be at 850-900 so it doesn't stall in drive.
Doing some touch up in the engine bay should be back in some time next week!!
  #60
Old 03-01-2017, 05:08 PM
some reason file invalid wont let me load video!
must be too big a file
