Old 07-13-2014, 02:27 AM
Gtozy's Avatar
Gtozy Gtozy is offline
This shot shows the drop offs in place and the inner guard repairs, as well as the tacked in outer wheelhouse patch. I found this all very fidly, as its difficult to be sure everything is going back in exactly the correct place, as there are several peices that all come together here.
http://i1294.photobucket.com/albums/...ps1oopbjsb.jpg
  #42
Old 07-13-2014, 02:39 AM
Gtozy's Avatar
pressure is on now, time to hit the 1/4. fairly pleased with the results. with a bit more dolly work, and some filler it will be fine (thats what im telling myself anyway)
This took so long to fit up, but its porbaby the best fit i have done. Have learnt to take several cuts before getting to the last one, as things move around a little as the fit gets better.
Thats it for now, hope you enjoy the pics
http://i1294.photobucket.com/albums/...psacrphmoe.jpg
  #43
Old 11-28-2015, 07:27 AM
Gtozy's Avatar
So a lot has happened since my last. Tho, now battling to get pics up. The 1/4ers have come up well, all in primer now and blocked.
Dave.
Check my build thread here
http://forums.maxperformanceinc.com/...d.php?t=753467
  #44
Old 11-28-2015, 03:00 PM
Gtozy's Avatar
https://goo.gl/photos/XtqRzxp9zYSo6hkH9
Ooops, Photo bucket not so easy to use,
Dave.
  #45
Old 11-29-2015, 05:59 AM
Gtozy's Avatar
i have also been busy assembling the engine, it will be started and tuned on a dyno very soon. very much looking forward to that.
Specs are:
* Stroke 4.25"
* 10:1 CR
* Bore 4.15"
* Dished pistons
* #16 Ported Heads- 72cc
* Hyd Roller Cam 236I - 242E @ 0.50 (comp cams)
* 1.5 ratio SS Roller Rockers
* Flow Kooler
* March Serpentine set
* Dougs Headers
* HEI Flame Thrower
* Custom Pro Systems Carb (based on Holley 4150 - 950)
https://goo.gl/photos/VaRHwTe2kRfYD6UJ6
Dave.
  #46
Old 12-29-2015, 07:10 AM
Gtozy's Avatar
Thought i might try to post some better engine pics.
Dave.
  #47
Old 12-29-2015, 07:32 AM
Gtozy's Avatar
Finally completing the 1/2" ss fuel lines means the chassis work is completed.
Sandblasted, and epoxy coated.
Dave.
  #48
Old 12-29-2015, 07:36 AM
Gtozy's Avatar
Rear end. Original 10 bolt, 3.08, Posi. Umi suspension.
Dave.
  #49
Old 12-29-2015, 07:38 AM
Gtozy's Avatar
One more!
Dave.
  #50
Old 12-29-2015, 07:44 AM
Gtozy's Avatar
Yesterday was a milestone day. The re "Marriage" occured with little fanfare. all bolted down nicely and door braces now removed - finally. Its been two years!!
Dave.
  #51
Old 12-29-2015, 07:58 AM
Old Goat 67's Avatar
NICE WORK!
  #52
Old 12-29-2015, 08:09 AM
FANTSTIC.....tell us about the color? Original 68 color?
  #53
Old 12-29-2015, 08:25 AM
bkmont's Avatar
bkmont bkmont is offline
Love that lift!
  #54
Old 12-29-2015, 03:40 PM
Gtozy's Avatar
the colour is Ruby Red, you may see it on current Mustangs. i wasnt to keen on the idea of a ford colour, but it really pops. It uses a red metallic base coat, tinted clear, then high solid clear. very pleased with it. car was originally Mayfair Maize.
Dave.
  #55
Old 12-29-2015, 06:28 PM
Ozzmann's Avatar
Ozzmann Ozzmann is offline
Looks awesome Dave!
Your car must be very fast !
Because you were haulin ass when I passed you in my GTO.
  #56
Old 12-29-2015, 08:49 PM
rohrt rohrt is offline
Those are the slickest door opening braces I've ever seen. Super strong, and not welded to the car. If they're any indication of your mechanical prowess, no worries!! Keep the pics coming, too.
X2.
Did you make them yourself?
  #57
Old 12-30-2015, 06:14 AM
Gtozy's Avatar
Originally Posted by rohrt View Post
X2.
Like everything else, yep. The biggest challenge was to get the angles correct so it bolted up snug, so the long sides change angle a few degrees to allow for that. they worked a treat, glad you liked em.
Dave.
  #58
Old 04-23-2016, 07:42 AM
Gtozy's Avatar
So its been a while since updates, im still on the body work, so i thought i would share some detail on the process. Both doors needed new skins and a bit of work to the frames themselves. very fiddly, but im pleased with the result.
https://drive.google.com/open?id=0B8...zJFWElmYTRDUVE
https://drive.google.com/open?id=0B8...zQ3akp2T1c2VTA
https://drive.google.com/open?id=0B8...TFsSF9tZnVpd1E
[URL="https://drive.google.com/open?id=0B8bp3uXXuZk_bHpyVzJJOFRadlU"]
https://drive.google.com/open?id=0B8...HpyVzJJOFRadlU
https://drive.google.com/open?id=0B8...Vd4UmVnWGJCQmM
https://drive.google.com/open?id=0B8...E9GRUNqajBxNUE
https://drive.google.com/open?id=0B8...TBNcGN4dHpqWE0
Dave.
  #59
Old 04-23-2016, 07:55 AM
Gtozy's Avatar
Hmm, not sure about the Google Drive pics, here are some from P Bucket instead
http://i1294.photobucket.com/albums/...ps0hxo7tz9.jpg
http://i1294.photobucket.com/albums/...pszfo0ihih.jpg
Dave.
  #60
Old 04-23-2016, 07:57 AM
Gtozy's Avatar
Dave.
