Old 06-21-2014, 05:48 PM
john marcella john marcella is offline
Originally Posted by Aaron Quinton View Post
Thanks. I finished mine by hand as well. The CNC path left .005-.006" deep grooves in the rough chambers which I also removed. I would have that a 2x difference in surface area of the chamber would matter at running temps.
Mine were finished by hand cuz I made many changes to everything after I made the motor a 521. So basically they are a hand ported set of heads at this point.
It had nothing to do with removing tool path step over. Waste of time. But if it gives you a warn fuzzy feeling, go at it.
John Marcella
Marcella Manifolds Inc.
[email protected]
ph. 248-259-6696
Old 06-21-2014, 12:13 AM
David Holmberg's Avatar
Aaron, my guess is the grooves help with the swirl.
Old 06-21-2014, 03:23 AM
No, The grooves from the tool path just don't matter. IMO
John Marcella
[email protected]
ph. 248-259-6696
Old 06-21-2014, 07:48 PM
Half-Inch Stud's Avatar
Chamber grooves helping with wet flow too?
By looking; I like how the Heart Chamber keeps the plug free from wet fuel.
Old 06-21-2014, 08:32 PM
Where the hell do you guys get this stuff ?
John Marcella
[email protected]
ph. 248-259-6696
Old 06-21-2014, 05:19 PM
I did forget to mention they moved the spark plug slightly too, overall should be a nice improvement for the old E-head.
Old 06-22-2014, 07:52 AM
Tim Corcoran's Avatar
I have a set of 72cc eheads that were cnc ported by SD a few years back. During a freshen up I had the ports polished just to remove the tool marks nothing more. Heads were flowed before and after, picked up 3 cfm intake and 4 exhaust. Car picked up a few .01's and a little MPH also. I know everyone says to leave the tool marks but sometimes I don't listen. In this case I am glad I didn't.
Tim Corcoran
Old 06-22-2014, 09:34 AM
ponjohn's Avatar
ponjohn ponjohn is offline
Plus Dave has his own new comb chamber tool path.
Old 06-22-2014, 12:16 PM
Tom Vaught's Avatar
Boost Engineer
Dave B is kicking out some very good parts.
Tom V.
Old 06-22-2014, 05:57 PM
Chad Speier Chad Speier is offline
I back to backed a fully ported manifold with smooth finish vs totally burr finished at the race track. Done the work in the guys trailer. Put it back on and made more hits.
All my stuff is finished in burr. Including fabricated stuff. Finished many heads in burr only.
The biggest issue I've had is people calling me lazy because I didn't spend another 2 hours making it pretty.
Old 06-22-2014, 09:25 PM
Ken Criss Ken Criss is offline
Chad that's because you tested both ways but you can't tell armatures anything they know it all and smooth is pretty and got to be faster. Good job
Old 06-22-2014, 10:09 PM
mike leech's Avatar
mike leech mike leech is offline
Marcella has cutter finished my junk for years.....LOL
EHTTFMF!
Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead.
BEING STUPID WORKS THE SAME WAY! The rest of us suffer.
Old 06-25-2014, 06:19 PM
77 TRASHCAN's Avatar
I've got the PHR magazine, the last one...I guess ever...and have read the thread.
The end of the collector looks like about 2-2.5" dia...LOL
I've seen Tri-Y headers on a successful pontiac stock elim. car recently, close to what you guys made, but they appeared to go more for the equal length effect...
Thanks for the attitude adjustment on what size primaries, HAVE to be...LOL
My good friend, and other racing 71-72 GTO stockers (in the early 80's)(specifically 455 HO's) found out that when they decreased the primary tube sizes, the cars went faster...Hmmm.
Thanks again
Shut it off
Shut it off
Old 06-25-2014, 06:45 PM
900HP's Avatar
900HP 900HP is offline
Thanks again
Headers are 1 3/4" step to 1 7/8" primary tube with 2 1/8" secondary tube. The collector choke is 2 1/2" tapering out to 3". All lengths were within an inch of target. Not shown in the photos are the 3" collector extensions we used, I *think* they were 11" long..... Not mentioned in the article was the 8" of crankcase vacuum we could pull with the pan-evac setup
Throttle's Performance
(701) 893-5010
https://www.facebook.com/pages/Throt...70911996281602
Old 06-25-2014, 06:53 PM
900HP's Avatar
Here they are semi-finished
(701) 893-5010
Old 06-26-2014, 04:04 PM
AC445 AC445 is offline
Default edelbrock 61515
I'm trying to get more info on these heads. I called edelb. but tech couldn't tell me the distance from the top of the seal to the bottom of the retainer. Tech said the valves would handle 650# open solid roller springs. any thoughts?
Old 06-27-2014, 10:25 AM
Mark,
How did your headers compare to the chassis models???
The standard wive's tale is that one installs tri-y's to pickup low RPM power, somewhat sacrificing top end...??? (especially for a street driven vehicle)
I've seen the opposite happen on a SBC engine. I had a 292 cid (283+.060) built for a driver. Was blessed to have the builder give it a whirl on the dyno (this was 1985 mind you). He tried a set of tri-y's on my engine, that had also been tried on a 355, and 406. Each engine responded the same... sacrificing low end and making more top end...compared to his standard 4 into 1 chassis headers that he ran on every SBC he tested....
Thanks!
Shut it off
Shut it off
Old 06-27-2014, 12:43 PM
900HP's Avatar
Let's not muck up this thread anymore than we already have. The 4-2-1 headers when properly designed and built will make a much wider power band than a 4-1 with no downsides. There is so much to header design I don't know where to begin and I'm only at the tip of the iceberg.
As far as our 4-2-1's to chassis headers? There was no comparison. No comparison at all.
(701) 893-5010
Old 06-25-2014, 06:40 PM
ponjohn's Avatar
PHR is done?
Old 06-25-2014, 06:46 PM
900HP's Avatar
Originally Posted by ponjohn View Post
PHR is done?
Deceased. PHR and High Performance Pontiac along with 10 other magazines have been absorbed into other rags. PHR and HPP become part of Hot Rod Magazine now. Those with subscriptions to PHR and HPP will get a Hot Rod subscription instead to finish out the contract. That is how I understand it.
(701) 893-5010
