Old 10-17-2015, 12:35 PM
421-6speed's Avatar
421-6speed 421-6speed is offline
Originally Posted by hurryinhoosier62 View Post
Welcome aboard, Darksider.
Old 10-19-2015, 10:47 AM
Pontiac62's Avatar
Pontiac62 Pontiac62 is offline
Originally Posted by 421-6speed View Post
Here are a couple pics of my Bel Air, FH 348 stroked 427 crank 11:25cr solid lifter 3X2 Richmond ROD 6-speed 3:23 9.3 Pontiac/Olds Posi.
Is that the car you had at the downtown Shelton show a couple years ago? If it is, I talked to you about that alternator.
Les.
  #43
Old 10-19-2015, 11:41 AM
421-6speed's Avatar
Les.
Yes it is and I also had the white and red 61 Impala and the 64 Catiline Sunfire Red with 15,000 original miles. If I remember correctly your name is Les and you have the 62 Grand Prix, changed the interior to black with 4-speed. Also you told me about the vacuum grease.
I am running the same Delcotron Squirl Cage 62amp alternator on this rig.
Thanks Dan
  #44
Old 10-19-2015, 12:38 PM
pugslyx234 pugslyx234 is offline
Angry
Ok now that Bel Air is just too Beautiful, I,m JEALOUS
  #45
Old 10-19-2015, 02:23 PM
421-6speed's Avatar
Old 10-19-2015, 02:42 PM
421-6speed's Avatar
Les.
Here is the Delcotron 62amp alternator on the Ventura. I had to make up the lower bracket as well as the bracket attached to the left side to get the correct spacing. I wanted it to look factory.
Name:	Delcotron 62amp Alt 1.jpg
ID:	410755   Click image for larger version
Name:	Delcotron 62amp Alt 2.jpg
ID:	410756   Click image for larger version
Name:	Delcotron 62amp Alt 3.jpg
ID:	410757   Click image for larger version
Name:	Delcotron 62amp Alt 4.jpg
  #47
Old 10-21-2015, 11:56 PM
John Eiseman's Avatar
John Eiseman John Eiseman is offline
Hey Dan,
Checked with a friend about the fan shroud. He says that 60-61 should be the same. Also he thinks that Olds and Cadillac may be the same for a cross reference? Anyone know this for a fact? He will check on Friday with another man who may have one.
  #48
Old 10-22-2015, 01:02 AM
421-6speed's Avatar
Originally Posted by John Eiseman View Post
Hey Dan,
John,
Thanks for the help but, the 61 fan shroud is different as well as Caddilac and Oldsmobile. 59 & 60 Pontiac are the only fit.
the first pic is a 59-60 Pontiac fan shroud. The 2nd & 3rd are 61 Pontiac shroud.
ID:	410952   Click image for larger version
ID:	410953   Click image for larger version
  #49
Old 10-22-2015, 08:03 PM
421-6speed's Avatar
Got the body painted last week. I did a base coat clear coat then blocked it out with 1000 and shot 3-more coats of clear today.
ID:	411006   Click image for larger version
ID:	411007   Click image for larger version
ID:	411008   Click image for larger version
  #50
Old 10-22-2015, 08:38 PM
421-6speed's Avatar
Then the trunk all finished up.
ID:	411012   Click image for larger version
ID:	411013   Click image for larger version
ID:	411014   Click image for larger version
  #51
Old 10-25-2015, 04:47 PM
421-6speed's Avatar
Finished up the floor pans this morning, Acrylic Enamel with a flattner for 60% gloss.
Name:	Floorpans Painted.jpg
  #52
Old 10-25-2015, 07:09 PM
JSPONT's Avatar
JSPONT JSPONT is offline
Damn you get a lot done in a short time. You retired?
  #53
Old 10-25-2015, 07:32 PM
421-6speed's Avatar
Thanks, I pulled off of another project to do this one. I was only going to make a real nice driver but I just kept cleaning and the next thing I knew the body was off.
Yes I am retired so I can dedicate full time to the project and then some.
  #54
Old 10-25-2015, 10:02 PM
JSPONT's Avatar
Awesome job. I can't wait till I can retire and get a bunch of car stuff done. Keep the photos coming
  #55
Old 10-25-2015, 10:16 PM
421-6speed's Avatar
Thanks, this is the car I pulled of of. Hope to get back on it after the first of the year.
Name:	Body set Back.jpg
ID:	411356   Click image for larger version
Name:	Body set Front.jpg
ID:	411357   Click image for larger version
Name:	425 Switch Pich Installed in Chassis 4.jpg
ID:	411358   Click image for larger version
Name:	Exhaust Body Off 2.jpg
ID:	411359   Click image for larger version
Name:	Chassis Finished 3.jpg
  #56
Old 10-26-2015, 06:32 PM
421-6speed's Avatar
Shot the wheel tubs with truck bed liner and made up a new fuel line and installed.
Name:	Floorpans Painted Fuel Line.jpg
ID:	411440   Click image for larger version
Name:	Wheel Tub Lined.jpg
  #57
Old 10-26-2015, 08:38 PM
JSPONT's Avatar
Nice!!
  #58
Old 10-26-2015, 08:53 PM
421-6speed's Avatar
Nice!!
Thanks, pulled the masking after lunch.
Name:	Masking pulled.jpg
  #59
Old 10-26-2015, 09:11 PM
Ron Landis's Avatar
Wink Well...
No that is another car I have.
NOW you're just bragging! Seriously....magnificent attention to detail on a fabulous car...a man after my own heart. Welcome!
  #60
Old 10-26-2015, 09:13 PM
Ron Landis's Avatar
Thumbs up One...
Nasty Nailhead!!!
