I have 7 years on my Comp Hyd rollers and Crane springs..no issues.
466 Mike Voycey shortblock, 310cfm SD KRE heads, SD "OF 2.0 cam", torker 2,generic one inch open spacer 373 gears 3200 Continental Convertor best et 10.679/127.5/1.533 60ft 308 gears best et 10.76/125.64/1.5471 |
Thinking here...there has got be a reason why the Hyd rollers are not durable. P-Dude had a big hyd roller in 535 shifting at or above 7k rpm. He swore by hyd rollers. Is it the brand? Is it the spring pressure? combo of both? KRE says on their website they have used Lunati Hyd Roller lifter with good success. What about an isky product? I guess my thought is, if you are going to run a hybrid setup then why not just run a street solid roller and make a lot more power? |
I have no clue on the spring pressure.I did have to shim the springs when I assembled the engine since the heads were setup for a Comp 290b solid originally.
I don't think there is a lot of experience with solid street rollers and certainly no guarantee that a lot more power would be made. At least not a lot that I could find. However, many have run the OF/Hybrid and the results are well known relative to HP,TQ, 1/4 mile times, RPM range, vacuum and idle quality. Not to mention we know what lifters, springs etc that work with this combination. I don't have a need to be a "pioneer" with a $1000 investment that I really didn't want to make in the first place.
71 Formula 433, Splayed cap 400 block, 4" stroke Scat forged crank, 6.8 Eagle rods, custom Autotec pistons. SD 295 KRE D ports, Old faithful hybrid roller, Torker II, Holley Sniper Stealth, Tribal Tubes, TKO 600, 3.73 Eaton posi. |
The Comp Magnum HR lobes have been proven over & over to turn at least 6K RPM with the dreaded Crane 99893 spring with SR lifters. One could run a 160/450 spring for that warm & fuzzy feeling but why run 200/600 and have to replace/rebuild lifters regularly unless you like that sort of thing?
John,I talked to a guy at Comp I have been dealing with for close to 20 years.They had issue with the last co making their hyd roller lifters.They took control of the mfg of all the parts and he said there has been almost no issue with the new ones.I think any actually MFGed in the last 3 years are the new version.Waiting for a set as we type.Tom
I have not actually set them my self.The last 3 engines were put together by diff people.2 by Joe Sherman racing and one by Walker Automotive.I will ask.Tom
Spring pressure really helps and proper oil.Most run too heavy oil with them.Im going to run 180 on the seat with my 421 SD engine.Tom
"I don't think there is a lot of experience with solid street rollers....."
There have been examples of street Pontiac's with solid roller cams in High Performance Pontiac magazine and Pontiac Enthusiast magazine ever since I've been involved in the Hobby. The last hydraulic flat tappet cam I bought was a Comp 280H in 1990, it wasn't long after that I changed to a Crower 60450 solid roller cam and have been using nothing but solid roller cams since then. .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) Best time 5.13 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE Last edited by Steve C.; 01-18-2016 at 12:33 PM. |
I have run 200 on the seats for more than 15 years on the comp hyd roller cams!That was what I was instructed by Comp to do.This has been argued for years.Nothing is better for both lifters and cams to control lifter bounce.Tom
Is this the one with the failed lifter? How many street miles?
FYI,said to be the best solid roller lifter is Jessel,their pontiac lifter is a SBC with diff link bars as I think most pontiac lifters are!Tom
Another of Pontiac Dudes comments.....
"Faster ramps require higher springs to keep the lifter on the cam at rpm. Having built quite a few track championship hyd cammed roundy round engines, I here about float. Not the lifter 99% of the time, it's not the right spring package." I'm wracking my brain to try and remember the fellow that posted here on PY about his longevity using solid roller cams in his Pontiac. If memory serves me right he had over 20,000 miles and two, maybe three, Hot Rod Pour Tours with the car. And I know of others with even more miles on their solid roller equipped vehicles ! COMP CAMS.... At the same time, we greatly improved the steel used for the axle while providing stricter control of the needle sizes to better distribute the load. The second part of the solution was to develop new profiles and springs for street roller use. These new profiles work great in the 2,000-7,000 rpm band while requiring far less spring pressure than the older race profiles. Together, these changes make it so the only maintenance consideration in buying a street roller from Comp Cams is whether or not you want to have to set and check lash. I recommend going through and checking the valves along with your oil changes. If you run Poly-Locks, this is probably overkill. Once you know what the engine sounds like, you will most likely be able to distinguish the tick of loose lash." .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) Best time 5.13 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE Last edited by Steve C.; 01-18-2016 at 02:20 PM. |
[QUOTE=Steve C.;5519826]Another of Pontiac Dudes comments.....
"Faster ramps require higher springs to keep the lifter on the cam at rpm. Having built quite a few track championship hyd cammed roundy round engines, I here about float. Not the lifter 99% of the time, it's not the right spring package." True,for race set up. I'm wracking my brain to try and remember the fellow that posted here on PY about his longevity using solid roller cams in his Pontiac. If memory serves me right he had over 20,000 miles and two, maybe three, Hot Rod Pour Tours with the car. And I know of others with even more miles on their solid roller equipped vehicles ! COMP CAMS.... The second part of the solution was to develop new profiles and springs for street roller use. These new profiles work great in the 2,000-7,000 rpm band "while requiring far less spring pressure than the older race profiles."
I think the failed lifter was actually a Isky,been so long and have tried so many diff cams in that engine over the last 20 years.I know I had them rebuilt and are still in the engine.First can was a Isky solid roller,second was a 245-252 comp hyd roller,think the one in now is 236-244 hyd roller.Both comps were their high lift hyd roller lobes.Tom
they probably dont run enough spring pressure!Tom
Tom, do you ever feel we are beating a dead horse !
Valve springs are one of the most critical and most overlooked components in your engine. Proper selection of the valve spring begins with identifying the application and selecting all of the valve train components to achieve the engine builders’ goals. .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) Best time 5.13 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE |
They generally run much more than we do. Probably has more to do with that funky porcupine geometry and bigger,heavier valves. SBCs get away with much less pressure.
