Old 05-21-2016, 09:04 PM
Go-Tee-O Go-Tee-O is offline
Default You say the engine won't turn?
....there's your problem, right there! I knew it was bad when 'piston cheese' started falling out when I loosened up the cylinder head.
....then I pulled the driver's side head. Never seen so much junk in a cylinder!
I guess the heads are about what you'd expect.
I hope to use these #62 heads, they're just cast iron, probably be fine with a complete rebuild. Right?
Name:	pass side cylinders.jpg
ID:	428873   Click image for larger version
Name:	#1 cylinder.jpg
ID:	428875   Click image for larger version
Name:	pass side head.jpg
ID:	428876   Click image for larger version
Name:	#1 chamber.jpg
69 GTO in progress | 72 Chevy C10 Highlander | 06 Honda VF800 Interceptor | 96 Honda XR250R |
  #42
Old 05-21-2016, 09:12 PM
Meanwhile, the 428 block. I'm guessing it has maybe 10-20k on it, you can see a 'ridge' but you can't feel it. Had Speed-Pro forged pistons. Cleanup and re-ringing it is not my first choice, but if this car is going to see the road before I retire, I'm running it, unless I hit the lottery The rest of the car is going to absorb a LOT of my cash. It won't be a daily driver in any case.
I've run worse-looking and they ran fine, but that shiny line about halfway down the bore bothers me. Taking it to my machinist this week for a cleaning and Magnaflux, if it passes, a hone and cam bearings. 'Mo money, 'mo money.
Name:	428 cylinders.jpg
ID:	428879   Click image for larger version
  #43
Old 05-21-2016, 10:45 PM
GOAT WHORE's Avatar
GOAT WHORE GOAT WHORE is offline
To funny, but so true!
1969 GTO 4spd. Antique Gold/black, gold int.
1969 GTO RAIII 4spd. Verdoro Green/black, black int.
1969 GTO 4spd. Crystal Turquoise, black int.
1970 GTO 4spd VOE Pepper Green, green int.
1967 LeMans 428 Auto. Blue, black int.
  #44
Old 05-22-2016, 12:23 AM
MD79TA MD79TA is offline
Love this post/ thread keep it going . Have s California car my self and yes they rust. But you really don't know rust to you see the mid west north east salt rust. It's all about the bones and California cars usually have good bones to build off. Best luck keep pictures coming. Lots of help on this site . Money And lots and lots and lots of time is all it takes. Doug
1979 Trans Am
307 RWHP 380RWTQ
13.8@103
1979 400 Block, 1970 Heads, Unknown Cam, Comp Cam Lifters, Edelbrock RPM Intake, Hedman Headers, Holley 750 Carb, WFO Drop Base SOLD
1968 GTO convertable project. 400 auto with air. west coast car . Not started in 15 ..update now running (around block spinning tires all the way. Have a lot of cosmetic work to do winter of 17/18
1969 GTO 400 4 Speed this a complete project. Rebuild will start in spring of 2017. SOLD
  #45
Old 05-22-2016, 02:03 AM
I'm originally from Pennsylvania. Check the 'vintage photos' thread in The Lobby for pics of my first car, lol! I know all about road salt, unfortunately
  #46
Old 05-22-2016, 02:34 AM
Gtozy's Avatar
Gtozy Gtozy is offline
My #16 heads were in a similar state, and they are now perfect after an acid bath and machining.
Dave.
Check my build thread here
http://forums.maxperformanceinc.com/...d.php?t=753467
  #47
Old 05-23-2016, 10:53 PM
Degreasing the front frame. I was worried about the car slipping off the floor jack while rolling it, but I popped the saddle off the jack, and was able to bolt right through an existing hole in the crossmember to the jack! Much safer. I figure one or two more days of degreasing ahead.
Found a little of the original Expresso Brown on the cowl....the only place it has survived.
ID:	429101   Click image for larger version
  #48
Old 05-24-2016, 05:54 AM
dataway's Avatar
dataway dataway is offline
Cool ... keep us posted .... like that original brown too.
  #49
Old 06-02-2016, 11:48 PM
Got the 428 bottom end back from my machinist today. Money well spent! Deck had enough damage that one cylinder wouldn't have sealed. Got the bores straightened up. Had to have the piston pin bores honed (pistons were pretty tight), resized the rods (had the pistons off already, why not), fresh cam bearings. The forged pistons checked out fine. The nodular crank has been waiting to go back into the block since 12/8/05! (date on the crank grinder's tag)
Also got the parts (bearings, gaskets, oil pump, etc etc etc) for the bottom end. Found a decent looking timing cover on the shelf (does have one broken bolt in it). Also found a 1112070 distributor on the shelf. Still need the oil pan off the junk 400. Forgot to order our vendor's Viton rear main seal in advance, so just thread cleaning/cam fit check/block plugs until then. Oh, and file-fitting the rings (first time for that!). Now trying to find out how much $$ my #62 heads need.
Then, I need to crap out a bunch more $$ to start working on the body, so I have something to put this engine in
  #50
Old 06-03-2016, 12:12 AM
Funny how days turn into weeks then month and years . Best luck with build I'm right there wit you . Doug
1979 Trans Am
307 RWHP 380RWTQ
13.8@103
  #51
Old 06-03-2016, 01:49 PM
unclescratch's Avatar
unclescratch unclescratch is offline
Thumbs up back to life
My '65 plates expired April '01. Drove it around yesterday evening. That's how long it took me to get it going again. Glad I used zip-lock bags and notes inside them to keep the little (re-useable) parts organized. Photos are also a great help. Good Luck on this project of yours.
  #52
Old 06-03-2016, 02:44 PM
It's close . It will be going down street this summer even if I have to push it . But one thing is I can say I did it it all . Doug
1979 Trans Am
307 RWHP 380RWTQ
13.8@103
  #53
Old 06-03-2016, 11:11 PM
Nice, you guys! Realistically, barring a lottery winning, I'm thinking 2018 at the earliest for any driving (i.e. sitting on a milk crate, no exhaust, no windshield, around the block). Fortunately, I have lots of free-to-almost-free stuff to do....paint stripping, welding holes, etc.
