#41
1973 Formula 400 4 spd 04C build date Norwood assembly plant. |
#42
It goes on dry. It's reusable too. My Advance has it out on the performance aisle. It's listed for a Chevrolet but it works fine for a Pontiac. I have been using this one I have now for over a year with three thermostat replacements on it. Part number is 738g and it's only 8 bucks on Amazon
#43
Mr. Gasket 738G Water Outlet Gasket https://www.amazon.com/dp/B000CMF20O..._DQPdzbXENPBCE
#44
Alright, I just ordered one from Amazon to have around for future in case I need it. hopefully not though.
Thanks, Karl
#45
#46
I know it isn't for Pontiac, but it was stated that it worked on Pontiac, so I thought I would try it. I wish they would make one like this for Pontiac.
#48
#49
"No replacement for displacement!" GTOAA--https://www.gtoaa.org/ |
#50
Thing is, is that I can't believe it's not the same 738G part.
#51
Steve F. |
#52
I had a tricky t-stat leak and cured it with this: https://www.google.com/url?sa=t&rct=...UXZq_FJtv7ms-A
It looks like the Ultra Gray and is much easier to remove than the Right Stuff too.
Will Rivera '69 Firebird, 400/461, 290 Eddy D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '69 LeMans Vert, XS 350, #47 heads, TH400, 10 Bolt 3.23 gears, work in progress ‘66 Lemans, 455, 310 KRE D-Ports, HR 236/245, TH400, GV OD, 12 bolt 3.73 gears - see it here: https://youtu.be/RP_s1wJKm_Y?si=K0NZxoTyaGcj8Dcb |
#53
Steve F. |
#54
Probably fits the later model Pontiac "corporate" (Chevy) small block so some ad writer assumes it fits all Pontiacs.
